Question about Canon PIXMA MX850 multifunction InkJet Printer
Canon MX850 gives error 5010 code after it is ready to print and I press the start button
SOURCE: ERROR 5010
solucion a email stnilton@hotmail.com the error 5010
Posted on Mar 28, 2008
greg_margo
  • 1959 Answers
SOURCE: Canon pixma MP600, error code 5010, what does it mean
There are a few things you can try:
  1. Power reset; press and hold the Power button until it the machine starts a diagnostic mode; if this doesn't turn on the machine, unplug it for 10 minutes and upon plugging it back in, see if the error reset itself
  2. Unplug all USB devices (including the printer) and reboot the computer. Once the computer has rebooted, plug in the printer, allow it to install (it should install automatically) and see if the error is corrected. Sometimes there can be a temporary conflict and the only way to solve it is to remove all other USB devices (this can work for external hard drives too).
The overall issue with error code#5010 is a scanner malfuntion. If the problem returns, check the ribbon cable as it runs from your scanner to the main logic board. If all is secure and you still have the problem, the printer may need a new logic board.
Posted on Nov 09, 2009
Testimonial: "Thenk you very much for your assistance, I will try your solutions. regds Robert"
  • 1335 Answers
SOURCE: my canon pixma mp830 shows error code 5010. what
The scanner lock switch may be in the locked position. Lift the cover and check the slide switch located on the top front left. If this is not the problem, you will have to have a service center look at the problem.
Posted on Dec 19, 2009
SOURCE: canon MX850 - paper feed
Look carefully because it is a cassette on the bottom of your canon mx850... so the solution is: or you fill that cassette or you switch your canon (it is a button for that) to take the paper from the top...
Posted on Feb 15, 2010
SOURCE: Canon pixma mp145 service error 5010 How to
i have error code 5010 showing?
Posted on Jul 24, 2010
B200
Hi there!
If you're getting the error code B200 when you try to print on your Canon PIXMA MX850, there is nothing you can do except to have it repaired. This error code indicates a Voltage High Error of the Canon printer. If the printer is still under warranty, please contact Canon for further assistance.
Jun 26, 2011 | Canon PIXMA MX850 Multifunction Printer
Error code 5010 on cANON MP600 ALL IN ON PRINTER
"Issue: ERROR LCD: Error Code 5010
Solution: Press ON/OFF switch to reset the multifunction device
Reset the device when it is not functioning properly.
If the device is not functioning properly or to clear memory, reset it.
1. On the operator panel, press and hold the <ON/OFF> button for one second. (The display will go blank.)
Note: It may be necessary to unplug the power cord if pressing the ON/OFF button does not shut off the printer.
2. Wait approximately ten seconds and then press the <ON/OFF> button again.
3. Wait until the device has completed its cycling process before submitting another job request."
Jun 16, 2011 | Canon PIXMA MP600 all-In-One InkJet...
I can't make my canon mp460 do anything. little used i've just taken it out of it's box again and changed the ink cartridges but nothing. error 5010 showing.
hi
1. On the operator panel, press and hold the button for one second. (The display will go blank.)
2. Wait approximately ten seconds and then press the button again.
or
go to following link you will have more solution
http://www.subnixus.com/error-codes/error-5010.html
May 26, 2011 | Canon PIXMA MP460 All-In-One InkJet...
Canon mp600 pixma; it just started doing this when I tried to print; now I can't seem to be able to do anything with it. I assumed it was due to one of the ink cartridges being out and so I replaced...
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
May 20, 2011 | Canon PIXMA MP600 all-In-One InkJet...
Canon mx850 Error code 6A00
Hello thank you for using FixYa.
The 6A00 is a Canon generic code for paper path jam.Some where in the paper path a sensor is activated indicating paper jam so the printer will give off a 6A00 code.As a Canon technology,I usually find the code almost 90% of the time it is related to the purge unit being jammed with something and not being able to move.Moving the print head assembly will not clear a purge unit if its jammed with paper,paper clips,push pins,screws,cookie crisp,flower bud pods etc.
I have found all those things in a purge unit.The offending item needs to be removed or the purge unit needs replacement.A
Canon Pixma MX850 Printer would still be under Canon warranty, get it into a shop and save yourself the hassel.
Incidentally, the 6A00 error pertains to all Canon printers made in the last several years, its not just used in one model & its always a paper path error or purge unit
I forget myself so here goes, the purge unit,called a spittoon assembly,where the print head assembly parks when not in use, also its other job is to clean and make sure the print head is clean and open for printing.That is why you will find the print head assembly parked on top of it. It also has a an electrical pump to milk the print heads and test for ink flow
For Further assistance, I am here to help.
Thanks and Keep exploring FixYa
Mar 25, 2011 | Canon PIXMA MX850 Multifunction Printer
Error code 5100 on my canon mx850 How do I clear this?
Hi Hope this help you
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not,
press the Power button once more.
8. Your printer should respond as normal..
Techbelkin
Nov 02, 2010 | Canon PIXMA MX850 Multifunction Printer
Error code 5010 is showing on my printing and i don't know how to fix it.
I pressed the reset button - as recommended for the cartridge to be detected and ..miracle: the cartridge problem vanished as well as the error 5010 message!!!!!!!! I printed a document with no problem...
Hope this has helped you... Thanks...
Jul 20, 2010 | Canon PIXMA MP600 all-In-One InkJet...
Error code 5010
Error Code 5010: Canon recommends resetting the machine. Unplug the power cord for 10 seconds. Then press the power button to turn the printer back on. Wait until the device has completed its cycling process before submitting another job request.
Dec 04, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Printer will not print, error code 5010 is
5010 is a scanner error, either worn out scan lamp or sensors. Canon only replaces the entire scan assembly, if you like I can get part number and price.
Jun 23, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Error code 5010 and 5C20
on't know this error code, but this info might help
With thanks to a canon tech Ok Well again I will repeat this answer with a titch more detail.
The 6A00 is a Canon generic code for paper path jam. Some where in the paper path a sensor is activated indicating paper jam so the printer will give off a 6A00 code. As a Canon tech, I usually find the code, almost 90% of the time, is related to the purge unit being jammed with something and not being able to move. Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like. And yes I have found all those things in a purge unit. The offending item needs to be removed or the purge unit needs replacement. A Pixma MP830 would still be under Canon warranty, get it into a shop and save yourself the hassel.
Incidently, the 6A00 error pertains to all Canon printers made in the last several years, its not just used in one model. And its always a paper path error or purge unit.
I forget myself so here goes, the purge unit, called a spittoon assembly in an HP, lexmark, and other inkjet printers, is where the print head assembly parks when not in use, also its other job is to clean and make sure the print head is clean and open for printing. That is why you'll find the print head assembly parked on top of it. It also has a an electrical pump to milk the print heads and test for ink flow.
Procedure to reset Printer canon MP145 and Canon MP160 with Error Code Message for Printer Canon MP145 and Canon MP160, you can find error code message the end of this post:
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding the Stop/ Reset button.
2) When the Power is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a service mode. (Waiting for menu selection)
4) When the on/off lights in green, press the Stop/Reset button the specified number of time(s) according to the function listed in the table below.(Each time the Stop/Reset button is pressed, the LED lights alternately in orange and green, starting with orange.)note: press 4 times for waste ink counter reset.
The number of the Reset
button pressing
LED Function Remarks
0 time Green Power off
1 time Orange Service pattern print
2 times Green EEPROM print
3 times Orange EEPROM reset
4 times Green Waste ink counter reset
5) Unplug cable power. (for MP145 / MP150)
6) Turn Off Power. (for MP160)
Error Code :
E2-2 = No paper (ASF)
E3-3 = Paper jam
E4 = No ink
E5-5 = The ink cartridges are not installed or a non-supported ink cartridge is installed, or the ink cartridges are not installed properly
E8 = Waste ink absorber full, or platen waste ink absorber full
E9 = The connected digital camera / video camera does not support Camera Direct Printing
E14 = The Ink cartridges whose destination are wrong
E15 = Ink cartridge is not installed E16 - Ink remaining is unknown
E16 -E19 = Failed to scan head alignment sheet
E22 = Carriage error
E23 = Paper feed error
E24 = Purge unit error
E25 = ASF(cam) sensor error
E26 = Internal temperature rise error
E27 = Waste ink absorber full or platen waste ink absorber full
E28 = Ink cartridge temperature rise error -
E29 = EEPROM error
E33 = Paper feed position error
E35 15 = USB Host VBUD overcurrent error - USB
E37 17 = Abnormal motor driver error
E40 20 = Other hardware error
E42 22 = Scanner error
May 14, 2009 | Canon PIXMA MP610 InkJet Printer
Canon PIXMA MX850 multifunction InkJet Printer Logo
410 people viewed this question
old marine
old marine
