Question about Polk Audio PSW10 Subwoofer
I have a Polk Audio PSW10 sub and the power light is red constantly. It has its own outlet and proper connection. The reciever is on but the light wont change green and submit sound. Any ideas. had it for a year and never had a problem
4 Suggested Answers
SOURCE: Polk Audio PSW10 not working
I just read this same problemin a psw10. It was recomended to remove back panel and there should be a fuse behind there. Check it out.
Posted on Feb 13, 2009
Grubhead
  • 5487 Answers
SOURCE: Polk Audio PSW10 electrical board smoking
I should just replace the parts that were burning, it will cost a lot less.
Posted on Jan 17, 2010
SOURCE: I have my Polk Audio
HI, I have the same problem with a MINX subwoofer, can any one help.
Posted on Jan 25, 2011
Can I add Polk Audio PSW10 10" Powered Subwoofer, 35Hz-200Hz, 50W Continuous Power, Single with my Yamaha ATS-1050 Sound bar?
Yes. Connect a standard rca cable from the audio out jack of your yamaha to the input of the Polk sub.
Aug 18, 2016 | Yamaha Audio Players & Recorders
My receiver has one pre-out will a psw10 work
yes but a sub woofer out is better. You may have to crank up the sub response. If it has a level on the sub with a crossover set the cross over to around 120hz. And set the bass on your receiver as you feel appropriet.
Nov 09, 2013 | Polk Audio PSW10 Subwoofer
My polk audio psw10 subwoofer has a concent sound coming out of it even if the reciever isnt on or even plugged from it the only way to stop it is to plug it from the wall
The capacitors in the amplification module on the back side of the subwoofer unit (unplug and unscrew amp unit) usually are the second components to check after the fuse. They look like black batteries with white text defining their ratings. It appears to be a commonly under ratted capacity for those that challenge the upper limits of their surround system capacity. (Poor neighbors) These act very much like a battery but quickly build a charge and then release a charge. These can be replaced with higher capacity units that are larger in size and may need to be relocated with extended wires to handle the power demands by the user. They can be ordered online and replaced after discharge and soldered into the proper terminals. The Proper Positive and negative terminals must be followed for proper function when replacing.
Feb 02, 2011 | Polk Audio PSW10 Subwoofer
Optimum set up for Polk Audio PSW 10?
Run 2 RCA cables from the two Purple connections on your Receiver (Labled "PRE OUT SUBWOOFER") to the Red and White connectors on the back of your Sub (it does not matter which Purple connecter you plug into either the Red and White)
Set the volume control on the Sub to about 75%, and keep the power switch in the "ON AUTO" position. To set the Low Pass value, look at the back of one of the front speakers in your setup, and note its frequency range (will look something like 100Hz - 17kHz). Set the Low Pass at a value slightly higher than the low value on the back of your surround speakers.
To set the phase switch, stand in the middle of the room with some music on (something with some bass, but not over the top bass) and have someone switch between 0 Deg and 180 Deg. Listen for which setting sounds "Louder and Fuller". This is the one you want. You will need to do this each time you move the Sub, as its position may change its phase in relation to the rest of your system.
Good Luck!
Mar 26, 2010 | Polk Audio PSW10 Subwoofer
Jan 15, 2010 | Polk Audio PSW10 Subwoofer
Solution to Vibration
you might try to turn it down and maybe move it somewhere else in the room i have the same problem its just my neighbors are in another house across the yard i just have way to much power god forbid some one family or what ever be in my house.
Nov 15, 2009 | Polk Audio PSW10 Subwoofer
Best hook- up Polk psw10 sub woofer to yamaha rx-v663 receiver
You will not need to y connect your subwoofer, if you have only one RCA sub out on your receiver the other end of the RCA connector cable goes into the left input on most powered subs, there is no loss of signal, the option exist as some receiver do sport a double RCA sub out.
Feb 11, 2009 | Polk Audio PSW10 Subwoofer
Jan 04, 2009 | Polk Audio PSW10 Subwoofer
PSW 10 Not working
Your 2A 250v slow-blow fuse is blown, located under the back pannel. Mine just did the same thing. Problem is the problem with my PSW10 goes beyond the fuse. I have contacted Polk tech support to help me trouble shoot.
Sep 06, 2008 | Polk Audio PSW10 Subwoofer
Polk Audio PSW10 Subwoofer Logo
290 people viewed this question
Top Polk Audio Audio Players & Recorders Experts
 Grubhead
Grubhead
kdigby
kdigby
Level 1 Expert
Are you a Polk Audio Audio Player and Recorder Expert? Answer questions, earn points and help others
