Question about Kenmore 3.8 cu. ft. HE3t Front Load Washer
Front load washer is collecting water while not in use
  • 15,935 Answers
It appears your dual inlet water valve has failed in this instance... or there is sediment preventing the valve from closing fully.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa
Posted on Jan 02, 2011
  • 69 Answers
SOURCE: What causes water collection in a front load
If machine is filling with water when not in use, it is probable you have a faulty inlet valve-the valve is not shutting off properly, and slowly leaking water into machine. Best to replace inlet valve/valves- relativley inexpensive part.
Alternatively, check your drainhose is not too low, and getting water flowing back into machine from waste pipe.
Posted on Aug 09, 2009
  • 1531 Answers
SOURCE: Water filling up in Front loading Whirlpool washer
sounds like you have a faulty water valve that does not close when the power is not supplied to the machine.or a problem with the cotrol board supplying power to the valve when the unit is not in use
Posted on Sep 15, 2009
Testimonial: "thanks for the fast response"
  • 4088 Answers
SOURCE: LG WM1814CW Front Load Washer rubber seal on front
Use some detergent plus baking soda and mix it in with the water--rub it around (with an old toothbrush) to loosen the mold. Let sit for a while, then wipe water, mold, and cleaner away. Finally, rinse with clean water and wipe dry. Leave the door ajar to air out after each wash. It will help to remove the standing water each time. Don't poke a hole in the seal to drain the water out, because water will then run out of the bottom of the washer.
Posted on Sep 28, 2009
  • 36 Answers
SOURCE: the gasket at the front door collects water and
you may need to replace the door gasket .. it may be sealing properly. that green slime you speak of i s called algea, same fungus found in swimming pools.. you can use algicide to remove it . Pleas were gloves
Posted on Oct 11, 2009
  • 92 Answers
SOURCE: Kenmore HE2T Front Loading Washer Leaks From Door
there is a dispenser hose that goes in the tub.alot of times a sock or something gets inside that hose.that would cause your trouble.take the boot off the front and look up and left to see that hose.it comes out of the tub pretty easy.
Posted on Feb 04, 2010
Frigidaire Affinity Glacier Stackable upright washer. Washer will not agitate and makes a buzzing sound from the pump that extracts water from the drum. Water collects and remains in bottom of washer.
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 29, 2010 | Frigidaire Affinity ATF6000ES 3.5 Cu. Ft....
LG WM1814CW Front Load Washer rubber seal on front door collects water underneath and now has black mold, and a strong odor, like cigarette smoke.
Sep 28, 2009 | LG WM1814CW Front Load Washer
Sep 15, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Water collects during non-use
The only thing that can make the washer fill with it turned off is a bad fill valve. Replace.
Aug 22, 2009 | Whirlpool Duet GHW9150P Front Load Washer
What causes water collection in a front load washer when not in use?
Aug 08, 2009 | Frigidaire ATF6000ES Front Load Washer
Water collects in the seal....
Just replacing the gasket.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Mar 17, 2009 | Kenmore 44102 Front Load Washer
Water is collects in drum after a few hours after cycle is complete
no your inlet water valve is defective, youll need to repalce it, part number 8181694. in the mean time just turn off water in beween usages.
Oct 29, 2008 | Kenmore Elite 45986 Front Load Washer
Clothes are soaking wet at end of rinse cycle
Awesome website, fixed my problem. Thank you, especially in these times where I can't afford to just call the repair man:)
Jul 09, 2008 | GE Energy Star WCVH6260F Front Load Washer
Washing Machines Logo
230 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
