Question about Kodak EasyShare C633 Digital Camera
Memory card problem
My camera came with a 512MB SD IMPACT memory card.  That card continues to work fine in my camera.
However, I have been using a 1 GB SD IMPACT memory card, which has worked fine until recently.  I have taken many pictures on it and put them from the camera onto the computer without problems and have deleted many pictures from the camera.  My 1GB card said on the camera that it would hold 900 and some pictures, but the day that it said it had over 200 pictures left on it, it quit working.  I went to review my pictures for that day and found that the last 10 or 12 pictures I had taken were not on the card.  Worse yet, my screen was red and said that the card has the wrong format and press okay to format the card.  I did not press okay for fear I would lose my vacation pictures, right?  I have taken it out and put it back in, but that didn't help.
How do I get the pictures off the memory card now that it says it has the wrong format without losing them?  And why, after all this time, does it say it has the wrong format?  If I just hook up the camera to the computer, will it let me print them off?  I haven't tried that, because I really don't want to take the chance of losing the vacation pictures.
Thank you for your help.
my memory card keeps saying it need to be formatted but if i do that i am gon loose my vacation pictutres
    Problem Solver:
  • 16 Answers
Sometimes flash memory can be exhausted, so to speak, and will stop functioning. This is all you can do to get your pictures back. After that try running a format and then the error check tools under the tools tab in the right click properties window.
Download a program called FreeUndelete from here and install it but before you open it, connect your MP3 player or insert your SD card. After you start the program up, select the drive letter that represents the memory you want to scan for deleted files.Click the scan button above the list and wait. If there's too many results, then look near the bottom of the window. There should be a"Filter found files" line where you can enter in the file type of the photos you lost. It probably should be this: "*.jpg" Once you have found the files you want to recover, create a folder you want to save them to in your My Documents folder and copy the path to that folder by right clicking on it then clicking properties. The path you need to copy is the line called Location (don't actually copy "Location: ".Just what's after it :p ) Now paste it in the line called "Undelete selected file(s) To" under the "Filter found files" line. Make sure you paste over the existing text. Finally, click the Undelete button to the right and Viola! check the files out in the folder you created in your My Documents folder.
Posted on Jul 09, 2008
I have a Pentax Kx and recently bought an 8Gb memory card. However I get a lot of blank images with the error message 'image cannot be displayed' especially if I use the continuous shooting mode....
Dear,
First of all you need to confirm that what kind of memory card your are using. The officially recommended type and brands are here
Toshiba *SD Memory Card - Capacities: 512MB to 2GB *SDHC Memory Card - Capacities: 4GB to 32GB
Panasonic *SD Memory Card - Capacities: 512MB to 2GB *SDHC Memory Card - Capacities: 4GB to 32GB
SanDisk *SD Memory Card - Capacities: 512MB to 2GB *SDHC Memory Card - Capacities: 4GB to 32GB
rather than these might be problematic or not compatible...
Check this first
Best of luck!
Jul 10, 2011 | Pentax Cameras
Nikkon coolpix L1 After downloading memory card .. then putting back into camera. Reading says "cannot read memory card." Checked card out at store verified that it is good. Why does it not work in my...
A couple things you might try.. remove the card carefully and check the position of the "lock" tab. Make sure it is fully in the unlocked position - not locked or a point between the two positions. Reinsert and try again.
It sounds lie you're using a card reader to download the pictures - try formatting the card while in the card reader via computer. The card should be completely empty when the format is complete. You can even try copying files to and from the card to make sure its ok and format again. When complete, try again in camera.
If the problem persists, check to make sure the card is on Nikon approved memory card list for use with the Coolpix L1 (provided below):
The following is a list of approved memory cards for the Coolpix L1 digital still camera. These cards have been tested and approved for use with the Coolpix L1.
The L1 uses SD (Secure Digital) memory. Sandisk:
  • 64MB, 128 MB, 256MB, 512MB, 1 GB, 256MB*, 512MB*, 1GB*
Toshiba:
  • 64MB, 128MB, 256MB, 512MB, 1 GB, 128 MB*, 256MB*, 512MB
Panasonic:
  • 64MB, 128MB, 256MB, 1 GB, 256MB*, 512MB*, 1GB*
* - Cards rated for 10MB/s (high speed) Other cards have not been tested. For more details on the memory cards listed above, please contact the manufacturer.
The list came direct from Nikon Support. Other cards may work, but only those on the list are approved. Successful use of other cards can not be guaranteed.
I hope this helps!
Sep 30, 2010 | Nikon D60 Digital Camera with 18-55mm lens
Using a disk with more memory
Yes you can use any same type. However if your using a older digicam, they might not recognize some of the newer cards. ig. You have a 512MB card (SD) and you want to upgrade for more storage on a 2GB, it should work. The catch is make surere its just a SD card and not a SHCH (only the newer/newest models can use this type). Other than that, if I'm right, your canon should work fine.
Jun 11, 2009 | Optimus Cameras
Z3 will not accept a 2g card
The Dimage Z3 accept SD cards up to 1GB (Minolta says 512 Mb, and sold it with 16Mb). This camera is 4MP , and uses less memory on card, therefore a 512MB card will be enough for it.
SanDisk Flash memory card - 512 MB SD Memory ...
from $13 - 20 stores
PNY Flash memory card - 512 MB SD Memory Card ...
from $3 - 2 stores
SanDisk SD Industrial Flash memory card - 512 ... from $14
Here 1 Gb, try at your risk, but they normally work:
1GB micro SD memory card for Konica Minolta ...
£6.90 - www.mobile-laden.co.uk
1GB Flash Memory Upgrade Card for Konica ... £3.44 - Memory Express
Here review: Steves Digicams - Minolta DiMAGE Z3 -
Mar 31, 2009 | Konica Minolta DiMAGE Z3 Digital Camera
Memory Card
make sure that the memory card you bought is a secure digital (SD) memory card. the kodak memory you have might not be an SD card.
Aug 25, 2008 | Vivitar ViviCam 3785 Digital Camera
Maximun SD Storage card size
http://www.mymemory.co.uk/compatible-memory/Digital_Cameras/Kodak/Kodak+EasyShare+C330_Memory_Cards
Jul 12, 2008 | Kodak EasyShare C330 Digital Camera
Memory card problem
wheather you check in computer repair shop is their any virus present in memory card? format your memory card! check virus is present in your computer or not! ?Try it!
Jul 11, 2008 | Nikon Coolpix S3 Digital Camera
Memory card problem
Assuming your camera acts like a removable drive when connected to the PC try the following.
  1. Right click the removable drive(your camera) in my computer and go properties>tools>error checking>tick both boxes>ok
  2. Wait till it finishes and check if you can now view the contents of the card. And copy to safe place straight away.
  3. Try http://www.officerecovery.com/freeundelete/ to recover any deleted files or fragments of damaged files.
  4. Let me know if any of this works.
Oct 22, 2007 | HP Photosmart M525 Digital Camera
"This card can not be used"
I experienced the same problem with a 1Gb card. The Vivicam 4000 only supports SD cards no larger than 512Mb. My solution to the problem was to simply repartition the SD card into two equal 512Mb partitions using Cute Partition Manager...http://www.cutepm.com. You should be able to do much the same thing except you will have to create 4-partitions, each no larger than 512Mb. When doing so, use the FAT 16 format option. As a word of caution, after repartitioning, do not use the fomat option on your camera, or it will restore it to a single partition 2Gb format. Also, when using whichever partitioning software you choose, be sure that you have selected your SD card, and not your C-Drive. Hope this is as successful for you as it was for me.
Sep 25, 2007 | Vivitar ViviCam 4000 Digital Camera
Optio 30 SD Card Max Size
You can now get up to 2.0 Gigs (that's 2048MB) of storage on a MiniSD card and all you would need is a SD Adaptor. The following site has MiniSD cards that are 1.0Gig (1024MB) or 2.0Gig (2048MB) and they come with FREE adaptors! http://www.flash-memory-store.com/mini-secure-digital.html As technology increases so will the story size. They are talking about making MiniSD cards that are up in the 5.0gig (5120MB) area. Enjoy!
Aug 30, 2005 | Pentax Optio 30 Digital Camera
Kodak EasyShare  C633 Digital Camera Logo
82 people viewed this question
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
