Question about Sport & Outdoor - Others
HONDA ATV 2003 TRX 250 CARBURETOR DIAGRAM. A HOSE IS HANGING FROM CARB BOWL. BIKE IS TURNING OVER BUT NOT STARTING. HAS FUEL. BOTTOM OF CARB HAS OPENING FOR HOSE, STILL WON'T START. FOLLOWED HOSE COMING OUT OF FUEL TANK SCREW CAP, CAN NOT TRACE IT. GOES DOWN NECK OF STEERING COLUMN. PLEASE HELP, DISABLED VETERAN, I USE BIKE TO PLOW SIDEWALK OF SNOW, LIVE ON A CORNER, POSSIBLE TO GET FINED IF I DON'T CLEAR WALK. VERY RESPECTFULLY, ROB
    President:
  • 1,450 Answers
The hose coming out of fuel cap going into steering column is just a vent hose. the fuel hose will be on side bottom of tank where the fuel on/off/reserve switch is fuel line comes off this valve down to carburetor. the fuel bowl also has a vent hose that hangs down below engine so if float stick fuel can run out and not on hot engine. makle sure the fuel bowl is getting gas in it try tapping on bowl lightly with a screwdriver handle if float is hung this may drop it down
Posted on Jan 03, 2011
Why is bike flooding and pushing gas out top over flow hose on carb after it runs for a min or two. Carb float been replaced still doing it.
Hi, Paige and the usual suspects are:
1. Damaged or restricted fuel tank venting system.
2. Loose float bowl screws.
3. Damaged float bowl o-ring.
4. improper fuel level in the float bowl.
5. Worn or dirty inlet valve or seat.
6. Damaged or leaking float assembly.
7. Particle contamination in inlet fitting cavity.
For more information about your issue please visit the websites below. Good luck and have nice a day.
My carb leaks fuel out of the overflow hose at the bottom of my carb
Carburetor is leaking gas out of overflow tube need help
Carburetor Carb Leaking Gas How to Fix Repair it Motorcycle Honda DIY..
Carbs leaking Here is how to fix it
Mar 28, 2016 | GAS Motorcycles
Why is fuel leaking near carburetor when the bike is running?
Hi, Stephanie check # 5 first and the usual suspects are:
Carburetor Carb Leaking Gas How to Fix Repair it Motorcycle Honda DIY...
http://www.suzukigsxr.cz/docs/Suzuki_GSX-R_600_K4+K5.pdf
Dec 13, 2015 | 2003 Suzuki GSX-R 600
2005 Honda CRF 250 R carb overflow
Hi, Anonymous and the usual suspects are:
8. Damaged petcock diaphragm allowing fuel to flow through the vacuum line into the combustion chamber.
9. Contaminated fuel tank.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
06 crf250r leaks gas when turn it on General Discussion
RePost 04 CRF 250 oil overflow hose
Honda 2004 CRF250R Service Manual
http://www.partsfish.com/page/oem-parts-for-honda
HONDA CRF250R 2005 Owner Manual
Jun 21, 2014 | 2005 Honda CRF 250 R
Honda trx 300ex
If gas is leaking from the tube on bottom of carburetor, the needle valve is worn inside the float bowl on the carburetor. You should also check to make sure there isn't gas in the oil and in the air box before starting and running your ATV. Let me know if you need any more help, Daniel.
Oct 19, 2013 | Garden
Honda CB250 will not start. It will turn over and there is fire on the plugs and when I look at the plugs after trying, they are "wet" with fuel. What am I missing?
Valve clearance or camshaft timing. If you have no clearance on the intake valves at top dead center, then you will have no compression = no start.
Nov 29, 2010 | 1994 Honda CB 250 Nighthawk
Need to see the carburetor diagram for a 2000- wont start
I could not locate a diagram of your machine's carburetor. I can tell you, for certain, that the carb does have a rubber drain tube that goes from the bottom of the float bowl and vents to atmosphere beneath the vehicle.
There are three required ingredients required for combustion: fuel, compression, and a spark (at the right time). Try to find out which of these are missing. Loosen the drain screw on the float bowl. Is fuel present? Check the compression - you've got to see at least 140 psi for anything to happen. Pull the spark plug and crank the engine. Is there a spark?
If it has sat for an extended period of time (more than just a couple of months) then the carburetor will be plugged with fuel varnish. It is very easy to think you've got everything cleaned, when the jets are still plugged up. I would take the carb apart and remove the jets. Hold them up to a light source and look through each one. If you can't see through them, there's the problem.
Jan 09, 2010 | 2001 Honda CL 400
Honda cr125 idle issues, wont idle not sure whats going on????
ALWAYS have a fire extinguisher on hand when working on carburetors.
Remove the water trap bowl at the bottom of the petcock, (gas valve). Is there any water or trash in the bowl? Drain a cup of gas from the tank. Is there any water or trash in the cup? Dump it, clean it and re-mount it, ( not all bikes have a water trap bowl ).
Drain the carburetor. There should be a screw on the lower side or a plug on the bottom of the carb float bowl. Remove the screw/plug then replace it after the fuel drains. Remove the carburetor from the engine.
Remove the float bowl and clean the entire carb with a spray carb cleaner from the auto parts store. Wear protective goggles to avoid getting spray in your eyes. Spray into all the little airways and fittings in the carb. Remove the idle screw and the air screw on the outside throat of the
carb and spray into the screw holes as well. The diagram below depicts the problem area. The bike will idle properly once the pilot jet and related passageways are cleared.
< < READ CLOSELY > >
Be sure to put these two screws back in the same hole they came out of. IMPORTANT > do not tighten these two adjusters down. Only screw these in until they LIGHTLY seat. Now turn each adjuster one and one half turns outward. Put the
carb back together, clean the air filter and install the carb. Let the float bowl fill then start the engine.
Please rate this solution. Thanks!
Aug 08, 2009 | Honda CR 125 R Motorcycles
Went to reserve fuel - then motor backfiring and loss of power -
Condensation in the gas tank collects at the fuel petcock. Get enough water in there and it gets into the carbs. ALWAYS have a fire extinguisher on hand when working on carburetors.
Drain the carburetors. There should be a screw on the lower side or bottom of the carb float bowl. Remove the screw then replace it after the fuel drains. Turn the gas back on and wait a minute for the carb to fill with gas. If the bike doesn't start and run properly then shut off the gas and remove the carburetor from the engine.
Put the carb back together and install the carb. Let the float bowl fill then start the engine. This process should get you back on the road.
Jun 18, 2009 | 2004 Honda Shadow 400
Fuel Leak from the Carburetor
Remove the water trap bowl at the bottom of the petcock, (gas valve). Is there any water or trash in the bowl? Dump it, clean it and re-mount it, ( not all bikes have a water trap bowl ).
Drain the carburetor. There should be a screw on the lower side of the carb float bowl. Remove the screw then replace it after the fuel drains. Turn the gas back on and wait a minute for the carb to fill with gas. If the bike doesn't start and run properly then shut off the gas and remove the carburetor from the engine.
Remove the float bowl and clean the entire carb with a spray carb cleaner from the auto parts store. Wear protective goggles to avoid getting spray in your eyes. Spray into all the little airways and fittings in the carb. Check the float as they can go bad and fill with gas such that they no longer float. Remove the idle screw and the air screw on the outside throat of the
Be sure to put these two screws back in the same hole they came out of. IMPORTANT > do not tighten these two screws down. Only screw these in until they LIGHTLY seat. Now turn each screw one and one half turns outward. Put the rest of the
carb back together, clean the air filter and install the carb. Let the float bowl fill then start the engine. The idle speed will probably different so adjust the idle screw to get back to where it was. This process should get you back on the road.
Apr 23, 2009 | 1987 Honda CBX 250
Bogging
Remove the water trap bowl at the bottom of the petcock, (gas valve). Dump it, clean it and re-mount it, ( not all bikes have a water trap bowl ). Install an inline fuel filter.
Drain the carburetor. There should be a screw on the lower side of the carb float bowl. Remove the screw then replace it after the fuel drains. Turn the gas back on and wait a minute for the carb to fill with gas. Install a new stock NGK spark plug and try to start the engine. If the bike doesn't start or run properly then shut off the gas and remove the carburetor from the engine.
Remove the float bowl and clean the entire carb with a spray carb cleaner from the auto parts store. Wear protective goggles to avoid getting spray in your eyes. Spray all the little airways and fittings in the carb. Remove the two screws on the outside throat of the carb and spray into the screw holes as well.
< < READ THIS CAREFULLY > >
Be sure to put these two screws back in the same hole they came out of. IMPORTANT > do not tighten these two screws down. Only screw these in until they LIGHTLY seat. Now turn each screw one and one half turns outward. Put the rest of the carb back together, clean the air filter and install the carb. Let the float bowl fill then start the engine. This process should get you back on the road.
Please rate this solution as " FixYa " if all goes well. Thanks
Mar 29, 2009 | 2005 Honda CR 250 R
Sport & Outdoor - Others Logo
554 people viewed this question
Top Sport & Outdoor - Others Experts
Bill Eager
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
