Question about Microsoft Computers & Internet
SQL IF ONE table contains prouduct id,total value and another table contain product sale ,date of sale ,number of product sale if the number product sale is add one more than the number of product is increamented by one,and alse totalvalue is also increamented by one ,how to wrote the query for this problem
  • 36 Answers
Select productid, numberofproduct+2, totalvalue + 1
from
table1, table2
where table1.productid = table2.productid
group by productid
Posted on Jul 26, 2008
Sum numbers in a column down until you come to a blank, then start again
Sounds like your issue can be solved readily with a pivot table.
If you give the columns of names a title like "NAME" and the number columns a name like "VALUE". All other columns should contain a unique name.
Then select the entire table, including the labels at the top ensuring that the range extends entirely over the column you need to sum the values of.
In Excel 2013, choose the INSERT menu and select the PIVOT TABLE command.
Insert the Pivot table into a new worksheet.
A new sheet will open with a strange-looking control panel on the right of the window.
Make sure that the box for NAME and VALUE (only) are checked
You will notice that Excel assumes that you want the SUM of the values for each NAME summed. The results are in the leftmost area of the worksheet.
If this works for you, please vote my answer as "helpful".
Sep 03, 2014 | Microsoft Excel for PC
How to change the date of an invoice
If you have already closed the invoices and cannot void them, then you need someone to adjust their date in the database. If you can void them, then change the date of the computer to the date you want on invoice and reenter invoice. This can't be done if it was a credit card sale however. Don't forget to change back the system date.
The first solution involves several tables in database and should only be attempted by someone familiar with SQL and RPE database. I could help.
sysadmin@ccybernet.com
Please return and give me a favorable rating if this helps or is of value to you.
Feel free to email me with more details if need be.
Dec 14, 2011 | Pc America Restaurant Pro Express
Lucky draw coding
You need two things:
1. JSP/Servlet knowledge.
2. SQL Programming basics
1. Create your PR jsp page which contain a form with method post and action to a servlet that will handle the insertion of the data to a database table i would add winners table containing ID, Frkey, thenumber
2. A servlet that will generate the number and cross check with those who guessed right and update the winners table with that data.
3. A servlet that will do an inner join with the pr and winners tables to display the results.
Good luck
Apr 05, 2010 | Sun Java Programming Language (cdj-275)
Sql queries for edit the tables dipendra
This is a generic Update(edit) statement in SQL:
UPDATE [tablename]
SET [columnname] = [new value]
WHERE [columnname] = [old value]
tablename = the name of the table you want to edit
columnname = name of column to be updated
Mar 15, 2009 | Microsoft Computers & Internet
How to create a multiple access query and put altogether into 1 SQL Scrip(.sql file)
Suggest using Union Query. Thus, you can add more queries from many table and the output will be in one (1) query. Bear in mind that all fields must have same Field Name.
For example:
tblOne contains dtDate1 fieldname. Your query will select [tblOne].[dtDate1] As myDate.
tblTwo contains dtDate2 fieldname. Your query will have the following SQL:
Select [tblOne].[dtDate1] As myDate
UNION Select [tblTwo].[dtDate2] as myDate
Thus the output will result dates from tblOne and tblTwo in a column called myDate.
Regards,
Maha
Feb 05, 2009 | Microsoft Computers & Internet
HLOOKUP IN MS EXCEL
lookup value = value searched
table array = database
topmost row of lookup array must contain the data IDs and all IDs must be sorted in ascending order.
row index number = row number containing data to be shown; first row = 1
hlookup(x,tablearray,y) will look for x on the first row of the lookup table and return the value in the cell on the yth row
if formula cannot file exact x, it will look for the value closest to. but not greater than x
Nov 13, 2008 | Computers & Internet
UPDATE DATA WINDOW IN PB 11 ERROR
It is probably a string column, being updated with a longer string than it can contain.
Date time columns may also cause this.
If you know the exact SQL update statement you can send it here.
If not, you may consider trapping it with Profiler.
*********CAUTION - if you have a production server with multiple customers depending on its availability, do not try profiler without guidence ********************
If you are the programmer, we may consider changing the field type or truncating the string, acording to the applicational needs.
Aug 21, 2008 | Microsoft SQL Server 2000 Standard Edition...
Excel counting
Use Pivot table, it might help you reach your target..!!
Aug 12, 2008 | Microsoft Excel for PC
How to compare a value in a subform with parent form's value in Dcount
Assuming that Process id is an integer, this should do the trick:
DCount("[stageid]", "Process Stages", "[Process id] = " & Me.Parent! [Process id])
Regards -- Joe (Access VBA samples)
May 01, 2008 | Microsoft Office Access 2003 (077-02871)...
Viewing ms Sql Server database on Access
Are you familiar with "Linking" tables in Access? In Access: File --> Get External Data --> Link Tables. This will bring up a dialog box which allows you to browse to your SQL server and select the table you want.
Aug 23, 2007 | Microsoft SQL Server Standard Edition for...
Open Questions:
What is Microsoft office applications? Microsoft office is a set of interrelated desktop applications, servers, and services, collectively referred to as an office suite, for Microsoft Word: a word processor included in Microsoft Office and some editions of the now-discontinued Microsoft Works Microsoft Windows and macOS operating systems. Microsoft Excel: a spreadsheet. Microsoft released the first version of Excel for the Mac OS in 1985, and the first Windows version (numbered 2.05 to line up with the Mac) in November 1987. Microsoft PowerPoint: a presentation program used to create slideshows composed of text, graphics, and other objects, which can be displayed on-screen and shown by the presenter or printed out on slides. Microsoft Access: a database management system for Windows that combines the relational Microsoft Jet Database Engine with a graphical user interface and software development tools. Microsoft Access stores data in its own format based on the Access Jet Database Engine. Microsoft Outlook: a personal information manager that replaces Windows starting in Office 97, it includes an e-mail client, calendar, task manager and address book. Microsoft OneNote: a notetaking program that gathers handwritten or typed notes, drawings, and audio commentaries. Notes can be shared with other OneNote users over the Internet or a network. Microsoft Publisher: a desktop publishing app for Windows mostly used for designing brochures, labels, calendars, greeting cards, business cards, newsletters, website, and postcards. Microsoft Project: a project management app for Windows to keep track of events and to create network charts and Gantt charts, not bundled in any Office suite. Microsoft Visio: a diagram and flowcharting app for Windows not bundled in any Office suite
Dec 28, 2017 | Microsoft Computers & Internet
Computers & Internet Logo
209 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
