Question about ASUS A7S8X-MX Motherboard
When i load the sound card drivers it turns the computer off soon after and keep repeating the process over and over until i go into the bios and disable the real tech ac97 audio . please advise as this is a really old computer and have no driver cd any more.
  • ASUS Master
  • 27,725 Answers
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ?
hope this helps
Posted on Jan 02, 2011
Can't return from standby mode. the vga, sound,
Turn Off the computer, now as soon as you hit the power button, keep on holding "Alt" key & keep on tapping "F10 key,ie: Alt+F10, it will open the recovery console ,select full factory restore and follow on screen instruction. (Note:this will erase all datas on the computer) or During the boot process you will see on the screen to press a certain key to enter setup Press and hold that key during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart
hope this helps
May 31, 2011 | Computers & Internet
I download bios v 1.13 from acer website and after i flash the bios, my computer cant boot to windows. How to reset acer aspire 5935g system bios to factory setting
Turn Off the computer, now as soon as you hit the power button, keep on holding "Alt" key & keep on tapping "F10 key,ie: Alt+F10, it will open the recovery console ,select full factory restore and follow on screen instruction. (Note:this will erase all datas on the computer) or During the boot process you will see on the screen to press a certain key to enter setup Press and hold that key during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart Hope this helps
May 28, 2011 | Acer Computers & Internet
I reied resetting the BIOS by removing the battery and now no fans or other hardware are not working
by removing the battery you have lost all of the bios settings and there drivers you will need to correct this
or
During the boot process tap the f8 button three times this will boot into safe mode where the only things working will be your mouse and keyboard enabling you to attempt to repair your computer
Also you might try
also
if you are having trouble with your drivers
here is a general look at the drivers and how to update them
if your computer came with a motherboard disc the drivers could be on it
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver hope this helps
May 10, 2011 | ASUS A8V-E Deluxe Motherboard
Hi, i have a Sony vaio and it was working fine until I shut it down overnight, the next morning I tried to turn it on which started out fine but as soon as the windows emblem started loading, it didn't...
or
Also you might try
hope this helps
May 01, 2011 | Sony Computers & Internet
How to reset my motherboard - dg35ec intel
click start all programs accessories scroll to system tools from there you should see a system restore click next a sytem date should open up select the date you want to restore your computer to or if you want a full factory restore or
Hope this helps
Apr 26, 2011 | Intel DG35EC Motherboard
How to entry bios lenovo pc.
Press F1 immediately after powering on the computer.
Older IBM computers (including some laptops) may utilize the F2 key for BIOS entry.
Alternately, if these don't work, Delete is a very common key to enter BIOS for many computers.
Regards,
katharsys_i
Mar 03, 2011 | Lenovo ThinkCenter A51p (842715U) PC...
I have installed win xp and when i m installing sound driver it tells that "no audio device found"
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
Do the following steps to rectify this problem :
Step 1 .Reset the default BIOS settings:
You can try resetting the sound default in the BIOS. Here's how:
  1. Turn the PC on. When the Windows logo first appears, press the F1 key or Dell key repeatedly until you see the BIOS setup screen appear.
  2. Press the F5 key ( Setup defaults). In some other PCs depending on the manufacturer the BIOS at start-up will have one of the default options that have names such as - ‘Load Fail-Safe Defaults’ and ‘Load Optimised Defaults’.You will have to choose ‘Load Optimised Defaults’
  3. Select Yes or OK, then press the Enter key on your keyboard.
  4. Press the F10 key, then select Yes or OK to save the default settings. Press Enter.
  5. Exit the BIOS and restart your system checking for sound.
( For most PC's entering the BIOS will be the same but if it differs for your system, consult the operating manual for instructions on entering the BIOS.)
If this doesn’t work go to step 2
Step 2 . Configuring on-board sound in the BIOS:
Some computers come with sound on the motherboard (on-board), and some computers use a sound card. The on-board sound setting in the BIOS has to be set according to your particular sound configuration. Perform the following steps to correctly configure the sound in the BIOS:
Look at the back of your computer and use one of the following three items to determine the proper sound configuration and sound setting:
If the plugs for the speakers and microphones are located next to the parallel, serial, or USB ports, then the computer has on-board sound. The on-board sound setting in the BIOS should be Enabled. If the plugs for the speakers and microphone are located away from the other ports and sit in an area by themselves, the computer has a soundcard. The on-board sound setting (if there is one) in the BIOS should be Disabled. If the computer has sound plugs in both locations, a
soundcard has been added to the computer that already contains on-board sound. The on-board sound setting should be Disabled. To enter the BIOS, turn on the computer and when the first screen appears, press the F1 key /Dell key repeatedly until the BIOS Setup screen opens. Use the LEFT and RIGHT ARROW keys to select the Advanced tab. Press the DOWN ARROW key to select Onboard Audio Options and press ENTER. If Onboard Audio Options is not available, select I/O Device Configuration and press ENTER. If Audio Codec is listed, select it and press ENTER. Select either Enabled or Disabled depending on your configuration and press ENTER. Press the F10 key and then press ENTER to save and exit Start Windows and check for sound. If there is still no sound, continue to the next Step.
Step 3 . Reload the current sound driver
To do this, follow these steps
1.Click Start, type Device Manager in the Start Search box, and then press ENTER.
2.In the Device Manager dialog box, expand Sound, video, and game controllers.
3.Locate the audio device that was included with the computer.
4.Right-click the device, and then click Properties.
5.Click the Driver tab.
6.Click Uninstall.
7.Make sure that the Delete the Driver Software for this device check box is cleared, and then click OK.
8.In the Device Manager dialog box, click the Action menu, and then click Scan for hardware changes.
You should see a message that a hardware device is being installed. Additionally, the uninstalled audio device is now present in Device Manager.
9.Close the Device Manager dialog box, and then determine whether you can hear sound.
If your computer came with a motherboard CD, the audio drivers should be on the disk.
If you don’t have the CD go to your computer manufactures web page to search for updated sound driver software. Read the instructions on the download pages carefully
before installing.
If there are no updated sound drivers available, use Microsoft's Windows Update feature. Connect to the Internet and try the following items until Windows Update opens:
1.Click Start, and then click Windows Update (if it is listed).
2.Click Start, click Settings, and then click Windows Update (if it is listed).
3.Click Start, click All Programs, and then click Windows Update (if it is listed).
4.Go to Microsoft's Web site and click Windows Update from the Downloads menu.
Check if the sound works now….if it still doesn’t work then most likely the sound card might be faulty.
Mar 12, 2010 | Microsoft Computers & Internet
Install new sound card. Creative tech
Before you install the sound card, you install the drivers for it. Drivers are small 'pieces' of software, that allow the Operating System to 'communicate' with the device. If you did not, then No, Windows did not recognize your sound card.
(In essence. Read on) (Not to insult your intelligence. Windows XP, is an example of an Operating System. So is Vista)
In this instance, the device is a Sound Card. Those drivers are on a CD, that should have been provided with the sound card.
Reasoning that you install the drivers first, then the Sound card is this,
When you install a device, Windows 'recognizes' it, as soon as Windows starts up. Windows 'breaks it's neck' to hurry up, and find drivers to match the device. If there are no actual drivers, then Windows chooses from Thousands of Generic drivers it has, and matches one up.
This is No good. The device needs THE drivers for it.
Then the owner comes along, and installs the drivers later. (Or in your case, didn't)
This causes a driver conflict.
BUT, you didn't indicate you installed the CD, therefore didn't install the drivers, and Windows is using the generic drivers. Crappy quality results.
Suggest you do this. Computer off, and unplugged
from the surge protector. Press the Power On button, and hold it in. Hold it in for a count of Five seconds, then let go. (And I mean Five at least. Count, 1001,..1002,..1003,..1004,..1005)
Do this procedure two more times.
What you are doing is clearing CMOS error codes, and resetting your BIOS, back to the factory default setting.
Computer unplugged, computer case open, touch the metal frame of the computer case. (Work on a table) This will relieve your body of Static electricity. Your body always carries static electricity. Static will silently fry out, your delicate computer hardware components.
Now take the sound card out. Leave the case open, plug the computer back into power. WAIT 1 minute, then turn the computer on. When Windows has fully loaded, install the CD for the sound card, Follow the instructions.
At the end, if it asks you do you want to restart your computer, NO!
Close all windows, until you are back at your desktop screen. Shut your computer down normally. (Start>Turn off computer>Shut Down)
Unplug the computer from power. Forget this part, and you may be buying a different computer.
Install the sound card. Close the computer case. Plug the computer back in. WAIT 1 minute. Turn the computer on.
Now how's your sound?
Apr 24, 2009 | Dell Dimension 4600 PC Desktop
Access BIOS
what computer brand and model is it ?
Robert
Sep 01, 2008 | IBM NetVista PC Desktop
ASUS A7S8X-MX Motherboard Logo
37 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
