Question about Refrigerators
Compressor is on permanently
Standard freezer, compressor is on permanently. It is quite old, 10 years.
  • 284 Answers
If the compressor is on a long time then prolly one of two thing,
1. its no longer good
2. the radiator is dirty.
theres also a fan, make sure is moving and dust free.
but im sure freon is mostly depleted, as you might have a small leak.
you could have the freon replaced and maybe have it checked for leaks.
also if the compressor is extremely hot, it might be time to replace it. off to the shop.
you are looking at 300 or more bucks, price tag most likely
Posted on Jul 09, 2008
Hums seconds only does not freeze
If it hums then quits and hums and quits and just keeps doing this then either the compressor start relay is burned out or the compressor is seized. Unless you are capable of diagnosing this you should have a tech check it out. If it's just a relay they are relatively cheap, but if it's the compressor it could cost more than the freezer is worth.
Dec 03, 2011 | Kenmore 12.8 cu. ft. / 362 liter Chest...
My Amana 26 cu ft side by side quit cooling entirely in the freezer and the refrigerator. Is it worth it to get a repairman or should we just get a new frig. This one is 6 years old
I suggest get help with repairman.6 year old is not very old.Refrigerators have life more then 8 to 10 years.The problem can be temperature not set properly or any of fridge or freezer door not closed properly and cool air is getting leaked out. These are basic possibilities which first need to be checked. But if these possibilities are checked ok and still the problem is same, then its weak compressor issue. Click the link below for more details:---
This will help. Thanks.Helpmech.
Oct 24, 2011 | Amana 26 cu. ft. Side-By-Side...
Freezer has quit freezing only a little over a year old. manufactor date 6/2009 compressor is running will only cool down to 50 degrees thermostat set on coldest.
Is the compressor continually running? If so then there could be a leak in the system or the compressor is damaged. If it's running then stopping, the cold control (thermostat) could be damaged.
Mar 06, 2011 | Kenmore 15 cu. ft. Chest Freezer 16542
Kenmore upright freezer quit freezing would work intermitantly and then quit cooling altogether, Approx 10 years old trouble shooting advise or most likely cause would be appreciated
Sorry to read about your problem. you can have many different problems.
Here are some areas to troubleshoot
1. Bad temp control
2. Failing compressor
3. Defective start cap
4. Defective overload protector
5. Defective control board
I suggest you call a service company. for compressor issues
I have tried to help you. Please help me, by Vote/Rate my response. Thanks.
If you live in the Denver area, I can help you.
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Jan 04, 2011 | Kenmore 16.7 cu. ft. / 473 liter Upright...
I have cleaned the coils this morning, but the refrigerator section does not appear to cool. The freezer seems fine. This is model eti18PKXGWI ser no. 042 9086 eemingly c. 10 years old.
Your freezer fan has probably quit. On most refrigerators the freezer is the only compartment actually cooled by the compressor and coils. The refrigerator compartment is feed cold air from the freezer compartment by way of a small fan. If you have you refrigerator turned all the way up and the door open you should here the fan running and be able to feel air moving somewere in the refrigerator compartment.
Sep 05, 2010 | Whirlpool Refrigerators
My kitchen aid (5 year old)fridge keeps quitting--no cooling.
Please change it Compressor because The pump of it compressor is not working properly
Apr 13, 2010 | KitchenAid Architect KBRA20ERSS Bottom...
My freezer not getting cold. it is about 10 yrs old and after Hurricane Ike it stop freezing.
if the fan run and does not freeze, possible compressor or compressor start kit. Start kits that a beating in stormy weather. Start kits consist of a relay, capicator and overload sensor. These 3 parts can be ordered seperately or a generic start kit with all the of these made in one. if the compressor is bad on a 10 year old freezer you might want to look at a new freezer
Feb 28, 2010 | Kenmore 65802
I have a 10+ year old Kenmore side by side that quit cooling
the starter unit of the compressor can be bad EZ fix if it is that...its the element conected to the compressor :)
Dec 29, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
I have a 10 year old Kenmore top freezer that clunks when it shut
its the compressor,
i would not spend a dime on it,
a compressor is around 200 to put it in could cost up to 200 more, then its a long shot with who will be doing the work
10 years is the avergae age of this unit so count your self lucky
and invest in a replacement
the old one may
last a year, but it will go
your loosing the center seal
sorry its not beeter news
Oct 05, 2009 | Kenmore 64802 Top Freezer Refrigerator
Compressor bad on my freezer. can this be fixed
The compressor can be replaced but it's often not worth doing. If it's under a year old it should be fully covered under warranty. If it's under 10 years old, the parts may be covered under warranty. In that case the labour is probably worth paying for. If you have your manual check in there for your warranty information. Good luck!
Apr 27, 2009 | Refrigerators
Refrigerators Logo
46 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
