Question about Hitachi Deskstar T7K250 (0A30777) Hard Drive
Hi there, i purchased a Hitachi Deskstar model: HDT722516DLAT80, it has alot of old photos from when my nephew was a baby and it used to work perfectly fine, then one day it stopped appearing in mycomputer, it shows in disk management but it says its not initialized, when i try to initialize it, it only has two options to try, when trying both, it comes up with an error message saying 'Incorrect function' i dont know how to get it to appear and i cant assign a drive letter as its not initialized, hope you can help as i dont want to lose these memories! Rachael
  • 2,509 Answers
I feel for you! It's awful losing your photos. You need to find someone with a caddy or Pata or Sata to USB adapter. Your particular drive could be either as that model is available in Pata or Sata, HDT722525DLAT80 or HDT722516DLAT8 are Parallel ATA HDT722525DLA380 or HDT722516DLA380 are Serial ATA, so I don't know which you have
mount the drive on the appropriate adapter or caddy. If you can recognise the drive it may be that your partition and files will be visible, if you can recognise some sort of partition but your files are not there you can then run data recovery software on the drive to try to get your files back. I know this sounds crude but it may well be that the drive is stuck, and a brief mechanical tap as you connect the drive to the power can sometimes free it up long enough to get the files off. Try to ascertain if it's spinning, only try the mechanical shock if it isn't spinning after connection to the power look here http://free-backup.info/data-recovery-software.htm for data recovery software or just google free data recovery software. Sorry I can't be of more help.
Posted on Jan 03, 2011
  • Hitachi Master
  • 27,725 Answers
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ?
hope this helps
Posted on Jan 02, 2011
  • TechRx Inc http://techrxgb.com
    I would recommend TechRxhttp://techrxgb.com This drive is "quite" interesting; and that lack of initializing is due to a corrupt System area. This is the area on the hard drive that stores the hard drive's boot information. Without it, the drive will not detect by the computer. It's not something you can fix on your own. However, your data may still be there.
  • Brian Sullivan
    Brian Sullivan Jan 29, 2011
    click start control panel administrive tools computer management then select event viewer depending on what operating sytem you have this may vary
    extend the events there you will see errors in red you will no what exactly what the error was and at what time it occured you might have to uninstall then reinstall the program and its files
    If it’s a ntdll.dll error the ntdll.dll error only displays when you use a specific software program,
    uninstall the program, reboot your computer, and then install the latest version again from scratch.
    until you know what the problem is you cant fix it or you might try
    you could run the check disk utility
    click start run type cmd then type chkdsk/r/f which will scan for and attempt to repair any bad sectors and automatically fix any corrupt files on your hard drive this should schedule to happen when you restart your computer then defragment your hard drive
    have you replaced those leads i suggested from the motherboard to your hard drive if just one of those is faulty this problem will occur
    i hope you get those photos back
    hope this helps
How do u use this thing? i found awhile back but dont know how to use it. its a hitachi deskstar hard drive. model number HDS721616PLAT80, P/N 0A32722
You can install this hard drive into an USB hard drive adapter case and use it as an external USB hard drive for back ups and file transfer from one computer to another.
Oct 26, 2012 | Fujitsu HITACHI DESKSTAR 7K160...
I purchased my old computer in 2009 and it came with the Hitachi HD, HDS721010CLA332 (0F10383). That computer has failed and I purchased a new HP Pavilion. Can I take the old Hatachi HD and make it a slave...
Hi there.
Since your hard drive is a SATA drive, there is no such thing as master and slave drive anymore.
All you need to do is plug it into your new computer (assuming there is an extra slot for a hard drive in there). You will need an extra plug from your power supply that will plug into the hard drive as well as a SATA cable that will plug your hard drive into the motherboard.
Another thing you can do is get an external hard drive enclosure and put it in that. Just make sure you get a SATA one, not an IDE one. I hope this helps.
Sep 08, 2011 | Hitachi HDS721010CLA332 Deskstar 7K1000C...
Bad driver
trying to install vista 64. computer can't find hitachi HDD hdt72103sla360. It is in BIOS, but not in vista
Dec 07, 2009 | Hitachi Deskstar T7K250 HDT722516DLAT80...
My hard disc purchase date is march, 2006, It is not working can I replace it
Most drives are under warranty for three years from purchase date.
You can check to see if it's under warranty from Hitachi HERE.
Nov 24, 2009 | Hitachi Deskstar® 7K80 80 GB SATA Hard...
"hitachi deskstar 160GB hardisk how many head as this got
This depends on the model. Please provide further details.
Mar 30, 2009 | Hitachi Deskstar 7K250 Hard Disk 160GB,...
Recover Data from Hitachi Deskstar (Model: HDP725050GLA360)
IDE and ATA are synonymous to one another for the most part. It will work. Jason
Feb 28, 2009 | Hitachi Deskstar 7K500 500 GB Hard Drive
Cannot see drive letter for deskstar 7k250 in usb enclosure winxp
Add a letter for this HDD in "control panel\performance and maintenance\administrator tools\computer manager=ment\disk management"
Feb 16, 2009 | Hitachi Deskstar® T7K250 250 GB Hard Drive
HITACHI deskstar hardrive. model HDS722580VLAT20
Send it to TechRx, Inc. we are a data recovery company in Wisconsin. We offer free shipping and estimates. I have specific tools (hardware) that will SA emulate Hitachi drives; and that makes for easy recovery of your data. http://techrxgb.com
Nov 15, 2008 | Hitachi Deskstar T7K250 160 GB Hard Drive
Hitachi Deskstar T7K250 (0A30777) Hard Drive Logo
290 people viewed this question
Top Hitachi Computers & Internet Experts
Alun Cox
Are you a Hitachi Computer and Internet Expert? Answer questions, earn points and help others
