Question about Whirlpool Dishwashers
Dishwasher will not drain the water in the bottom
  • 1 more comment
  • mauimad1 Jan 02, 2011
    How do I clear the drainhose or drain pump filter?
    Kevin
  • mauimad1 Jan 03, 2011
    We took the hose off and there was a little water that ran out of the dishwasher. We took the drain hose off of the garbage disposal and ran a weed whacker plastic line through it to the dishwasher and a few globs of goo came out. What's next?
    we ran a cycle and it drained. Thank you
    Kevin
  • Whirlpool Master
  • 1,902 Answers
Hello & Welcome to FixYa
Dishwasher not draining completely problem usually occurs due to clogged/blocked drain hose or the drain pump not working. First try to clean the drain hose and drain pump filter for any clogs, then check drain pump operation. If the problem returns after cleaning then it is the drain pump that needs replacement. Please get back to me if you have any other questions.
Kevin
Posted on Jan 02, 2011
  • Kevin White
    Kevin White Jan 02, 2011
    Take off the bottom access panel to clean the hose and pump.
  • Kevin White
    Kevin White Jan 03, 2011
    Great it worked...just checked your comments
Water did not drain from the bottom
Hello Cheryl, There are a couple of possibilities. When the dishwasher drains the dirty water it is a time based function. This leads me to believe it is a blockage or partial blockage in the drain hose.
Here is an example. (If your dishwasher drains into your garbage disposal) washing dishes you put scraps into the disposal and forget to turn it on after you are done. The disposal is filled with scraps this restricts the flow of dirty waterfrom the dishwasher. If the flow is restricted less water is being drained per second from the dishwasher. This is why the dishes still looked clean and there was still water in the bottom of the dishwasher.
(if your dishwasher drains into a drain pipe) there is blockage or partial blockagein the dishwasher drain hose. if the sink drains slowly the blockage is in the main line
Hope this helps
Joe Connolly
Nov 02, 2011 | Frigidaire Dishwashers
Dishwasher not working.... when i close the dishwasher and turn it on i can not hear any water running and there is a pool of water at the bottom that will not drain
Hello, How long has your dishwasher been do this? Have you washed dish's in it? Also, these German made dishwasher run on less than 2 1/2 gallons of water. These German manufactured dishwasher machines run really quite. Because of the German water conservancies laws. They limit the amount of water dishwasher and washing machine can use. Also, there is no storage hot water system in there homes, it on demand hot water. You can't hear the motor running and about the only thing one can hear is maybe the water washing the dishes.
Now, the water at the bottom of the dishwasher, if the drain isn't connected up under is the sink drain and trap area or the garbage disposable in the sink. but some place lower on the drain pipe. You will not have a spiffing effect on the the bottom of the dishwasher, it the same with washing machines. One the discharge pump starts sucking air, it will not drain the dishwasher. The siffen effect works if the water is below the outlet for the drain. Example: Home owner have the new washing running and continue fill with water. Why, because the drain pipe end is below the the bottom of the washing machine tub. It fill up with water and siffen action continues emptying the tube will it still filling. One heck of a water bill.
GB...stewbison
Aug 25, 2011 | Bosch 18 in. SRS45E02 / SRS45E08 Exxcel...
Our Bosch dishwasher has water filling back in bottom of dishwasher after cycle is complete. You can empty dishwasher and no water will be in the bottom, but several hours later the water has filled the...
Check the drain line underneath the sink.
It should be suspended just below the counter top.
If it is too low,water from the sink will back fill into the dishwasher.
If the drain is OK,then the dishwasher water valve is defective.
Mar 26, 2011 | Bosch SHU3306UC Built-in Dishwasher
My bosch SGS3062GB is not draining the water away - the water is stagnent in the bottom of the dishwasher. I ran the rinse cycle and it left about 2.5inches on water in the bottom of the...
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. Check the drain hose for any visible clogging, remove if present. If no visible lint is present then remove then turn off the dishwasher and remove the drain hose and check for any visible clogging. If still not visible then the drain filter or drain pump is clogged and you'll need to clean the drain filter and drain pump.
Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Daniel
Dec 13, 2010 | Dishwashers
Water is left in the bottom of the dishwasher after completing a cycle
When you find water left in the bottom of the dishwasher... most of the times there is an "Intake/Drain" flashing, or some other type of fault indication. The dishwasher has faulted out, in the middle of a selected program. The dishwasher won't even bother to drain the water out. If it's not a drain fault, then you can drain the water out by: switching the dishwasher off and on again; selecting a program; and closing the door. Open the door after 15 seconds and see if the water has drained out. If it didn't drain, there is a drain problem. If it did drain, then it can be several things. To better determine the problem, you will have to pay close attention to when the dishwasher faults out.
Nov 20, 2010 | Miele Premier-Plus Built-in Dishwasher
Will not pump water out of the bottom of dishwasher
UNPLUG THE DISHWASHER. Inside the dishwasher is a covered drain, usually covered with a plastic guard to prevent large objects from getting into the drain. Remove the blades in the bottom (careful but on my GE they come off with a firm pull) Remove the drain cover and see if the drain is plugged. If it does not appear to be plugged, you may have a bad drain pump. This usually requires you to remove the dishwasher but on some you can access it by removing the bottom plate. You then can disconnect it from the dishwasher drain by loosening a band that holds it firmly to the pump housing. Be ready with something to catch the water as it drains out. If the water inside drains out then your pump is bad. Because the water inside drained out, that tells you that the drain to the pump is clear. Your dishwasher has a drain pump that moves the water out. You will need to remove it, check it for obstructions and replace it. If it still does not work, you will need a new pump. There are two water connections to the pump, one for the flow from the dishwasher and another for the flow out. There are two electrical connections that you will have to remove.
Jul 29, 2009 | Dishwashers
Water in bottom of dishwasher, can't get it to drain
pull your water drain line out and place in a bucket on the floor. then try to drain it again. alot of time the hose get an air gap or blocked with gunk.
Feb 16, 2009 | General Electric Adora GHDA670N Built-in...
try pressing the cancel/drain button.Do you hear water draining into sink freely?? if not i would disconnect drain undersink look for a clog right there first
Feb 22, 2008 | Kenmore 24 in. 17482 / 17484 / 17489...
Water is not draining
Your drain pump might be bad/disconnected. Check the underside of your machine for disconnected wires.
Dec 17, 2007 | Whirlpool 24 in. GU3200XTP Built-in...
Hi You have a drain problem, Your house drain may be restricted the dish washer pumps out with more pressure then the water just falling down your sink.I would snake it or have a plumber clean out that drain...let me know if this helps krazytech
Aug 24, 2007 | Bosch 24 in. SGS43C12 Classixx...
Dishwashers Logo
258 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
