Question about Kenmore 27182
We have a kenmore front load washer at work model#27182 that every once and a while you have to advance the timer by hand so it will start it's fill cycle
Buffalo12980
  • 625 Answers
SOURCE: Maytag top load washer leak
underneath the agitator is a graphite seal ring and nut that seals the inner tub and the outer tub. a suitable spanner wrench or a 6 inch channel lock plier will remove this locknut. replace the seal.
Posted on Sep 02, 2007
dididsaythat
  • 291 Answers
you have a bad water valve.. replace the valve where the hoses are hooked to your washer
jsrock516
  • 5911 Answers
SOURCE: Kenmore Elite Washer Problem
This is a common symptom of a defective lid switch. If you try opening and closing the lid and do not hear a distinctive "clicking" sound, your lid switch may need to be replaced. Some lid switches are located on the right-hand side of the lid opening with a small slot. It is activated by a plastic piece called a “lid strike” on the lid itself. Make sure the lid strike is not broken off. This will keep the switch from not working. On some model washers the lid switch is located on the left-hand side, in the rear, mounted under the casing near the lid hinge. It is activated by a rod on the lid hinge. Sometimes the rod can be adjusted if it is not making good contact with the switch. In either case, if the switch is not activated, it will allow the washer to fill and maybe agitate, but will not start the rinse or drain cycles. If you diagnose it and wish to attempt the repair yourself, the switch costs about $35 and is fairly simple to replace if you follow the steps below:
First of all, unplug your washer. You will need to remove the console in order to get to the lid switch. I believe your washer has release tabs under the console at each front corner. Simply slide a putty knife straight in from the front at each corner and push in while lifting up. You should feel the release tabs push in and the console will pop up. Or, you may have a console that has removable end caps. They can be removed by gently prying up on the top of them from the rear on each side. You may have to use a small screwdriver for this. The caps should pop right off. Once removed, you will need to loosen a screw under each cap. Once you have the console loosened, carefully lift it up and lay it back over the rear panel of the washer in its resting position. Be careful not to damage the small plastic hinges that hold it in place.
Now you will need to perform the following steps:
1. Under the console you will find the lid switch connector. Unplug the switch from the connector.
2. There will be two brass colored clips. You will need to remove these to remove the machine casing. Place a flat blade screwdriver straight down into the opening on top of the washer and into the groove of the clip. Push the screwdriver away from you while holding into the groove and the clip will release.
3. Open the lid of the washer and place your hand under the front rim of the opening (DO NOT grab the wash tub). Now pull the case from the frame by lifting from the back first.
You do not have to remove it all the way from the frame. Just enough to gain access to the switch. All there is to the switch is a couple of screws holding it in and a ground wire. It's a pretty easy repair job. NOTE: You DO NOT have to drain the tub to repair the lid switch.
Once you've completed your switch installation, make sure you get the case back on the frame correctly by following these steps:
1. While looking down through the lid opening, place the front lip of the machine case UNDER the washer frame and start leaning it back onto the frame. There are four small cleats that must fit into four slots on the case or the washer will vibrate. Make sure the frame is seated properly, lean forward from the front of the washer, grasp both sides of the rear panel and pull towards the case. The rear panel should be seated and flush with the casing before inserting the retaining clips.
2. Insert the brass-colored clips into the slot on the washer rear panel first, then push straight down into the opening on the top of the washer with some force. If you have the case seated correctly, the clips will snap back in.
3. Make sure you plug the connector from the console back into the lid switch receptacle and close the console.
I hope you find this helpful. If you have any questions or need help locating the correct part, please let me know by posting comments.
Posted on Apr 08, 2008
SOURCE: kenmore stack washer and dryer
gabehart....sounds like belt is slipping. Replace it. The water pump is on a separate smaller motor so is not affected by the agitator/spin motor.
Posted on Aug 11, 2008
mumma_1
  • 903 Answers
SOURCE: front load washer leaks from the detergent drawer in the front
try taking the drawer out and clean it thoroughly, including the underside of the drawer, then clean the inside of the machine where the drawer fits into. Sometimes a build up of dertergent can casue this problem
Posted on Dec 28, 2008
Washer ills with water with sensing light on but does not switch to wash cycle
The timer gets it's information from the fill sensor, so it it doesn't start and you are sure the fill sensor is signaling the timer correctly, then I would look for a timer problem. Try advancing the timer a little after filling and see if it takes off.
Feb 01, 2017 | Kenmore Washing Machines
My 21882 top load Kenmore washer will start the cycle but stops after filling up; i can restart the cycle by pushing the knob in and going a little further in the cycle then starting again. But after a...
When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
  • Jan 29, 2011 | Kenmore 24032\24036 Top Load Washer
    My wahser just stopped working it filled with water and then started agitating and then all the sudden stopped please help
    Kenmore 431423 won't advance cycle, won't agitate
    not sure why he would replace the shocks this is clearly a timer/control issue. Replace the main control
    Jun 11, 2010 | Kenmore 43142 Front Load Washer
    Will not stop agitating, timer will not advance
    First, see the Sears parts site for your washer:
    http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?pop=true&modelNumber=110.20922990
    As you say, I'd also suspect that the timer is not advancing.
    Following is the Whirlpool / Kenmore service manual for top load, direct drive washers.
    https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
    Oct 28, 2009 | Kenmore 22062 Top Load Washer
    Door locks, but will not fill up with water. Alarm sounds and lights flash once every minute or so
    There is a rectangular magnet attached on the inside of the drawer for the detergent. Located on the right hand side near the front of the drawer. This magnet had come loose. Some glue and caulking worked well and the washer is working fine now. Meant to post this weeks ago.
    May 12, 2009 | Kenmore Front Load Washer
    Washer wont stop filling
    There is probably a plastic tube running from the tub to a pressure switch which controls the water level cutoff on control panel. One can locate this by taking the backcover off and looking at the water level switch and following the tube to the connection on the tub. Tube must fit on level switch tightly for it to work properly.
    Apr 27, 2009 | Kenmore 46462 Front Load Washer
    Kenmore cycles not working
    Agitating as it fills, definitely sounds like a timer problem. The contacts inside the timer have likely shorted and fused together.
    Replacing the timer will fix it and it's not too difficult do replace yourself.
    Depending on your model, you can try removing the timer and opening it up. Once opened, use a small screwdriver to gently pry the shorted contacts apart. This may work for a while but once the contacts have shorted, it will possibly happen again.
    Post your model number and I'll try to assist you if you need more help.
    Mar 14, 2009 | Kenmore 24032\24036 Top Load Washer
    Won't start
    We have a kenmore 27182 that has a very bad wabble in the spin mode. any suggestions?
    Dec 22, 2008 | Kenmore 27182
    Washer stops suddenly and water isn't drained out
    Hi tieuvodanh; Sounds like the timer has gone out. If you can advance the selector dial manualy, and the machine continues to operate as it should, then this is the problem. Replacing the timer will require some advanced knowledge of washers and the ability to use a box of hand tools. A good handy man will be able to repair this for you. Best regards; HELP2DIY Please don't forget to rate my answer.
    Jul 10, 2007 | Kenmore 22422 Top Load Washer
    Kenmore 27182 Logo
    47 people viewed this question
    Sal De GO PATS
    fordexpert
    Ed Mac
