Question about Haier Heating & Cooling
Aircondition er turns on starts to cool then shuts off and only the fan is on
  • 190 Answers
Dear nchase
This problem generally occurs due to the following reasons. I've included the solution too.
1.Windows and air vent wings maybe open .Close windows and vent wings
2.The compressor belt is slipping. Try to Tighten or replace compressor belt
3.Heater is on. Shut heater off
4..Condenser is clogged with debris. Clean the condenser .
5.Refrigerant has escaped through a leak in the system. Have system checked .
6.Receiver/drier is plugged. Have system serviced.
Try these solutions. Do respond with your comments please.
With regrads
Posted on Jul 09, 2008
  • Ajith Kumar Jul 10, 2008
    Please Rate the Solution.. Thank You..
HEIL HVAC, fan blows but no heat or AC
Your airconditioning system may be out of cooling gas, and if it has sufficient gas, the compressor might not pick when you put on the AC, and if the compressor did not pick ie start, you cant experience cooling effect, the fan will only be blowing.
Jan 18, 2013 | Cars & Trucks
Cooling doesn't stay on
The outside and inside coils may need cleaning. Clogged coils cause excess pressures and heat of the freon that can cause safety switches to shut er down. Eveen a faulty power relay in the outside unit.Otherwise you may need a serviceman to locate the cause.
Jan 21, 2012 | LG LS-L1210CL Mini Split Air Conditioner
We just had the regrigerator installed today. It was cooling and then we put the food back in and shut the doors and the readout now on the display where the temperature is says ER and CF. The water does...
If the unit was just installed you would call for service. Error Code Er CF -The unit will receive signals from the BLDC fan motor in the freezer compartment during normal operation. If more than 65 seconds pass without a signal from the fan motor, an "Er CF" error message will be displayed. The Cooling Motor Error is usually an indication of a faulty fan motor or loose leads. Customer service should be contacted immediately. IF you have any further questions message me back Thanks Rick
Sep 08, 2011 | LG LFX28978
When i press the cool button the air turns on for one or two minutes the shuts off
I Have a aircondition Tempstar PGAD36D1K, on the thermosta the target temperature is 78F but aircondition star working at 85F and stop at 82F.
We want to kwow how we can fix that. This is the second thermostat the we buy and we still hace the same problem.
Jun 09, 2011 | Heating & Cooling
How to check the radiator fan in the engine for x type 2.5 2003
While idling in park, turn the airconditioning system on high (make sure the "snowflake" light is green on the climate control panel). This will cause the cars engine managment computer to turn the cooling fan to the high, or fast speed (this is so the a/c condensor can properly cool the refrigerant). If the fan does not come on when you do that, there is a problem.
Jan 11, 2011 | 2003 Jaguar X-Type
Fuses were replaced first. Fan on airconditioning unit won't keep
It sounds like the run capacitor of your condensor fan failed. When it fails, it can prevent your fan from starting unless you manually spin it to get it going, then it could run for awhile before it overheats.
Apr 06, 2010 | Heating & Cooling
Mercedes benz airconditioning
You might check the cooling fans on the condenser to see if they are running when the ac is on.If they are not check for blown fuse,or bad cooling fan relay.Do you notice if the ac cools better when running constantly,and the ac is not so cool when in traffic,stopping and going,and running slow?If so the cooling fan,or fans are not working.If the fan fuse and the relays check out fine,then replace the fan,or fans.If I can help any more please
Aug 19, 2009 | 2004 Mercedes-Benz C-Class
Cooling fans stay on
your fan will also come on when the defroster is on and when the airconditioning is on so it could be something to do with the inside temp controls
Jan 25, 2009 | 2003 Nissan Maxima
Heating & Cooling Logo
73 people viewed this question
Top Haier Heating & Cooling Experts
Tom Chichester
Level 1 Expert
Vincent Schnittert
Vincent Schnittert
Level 1 Expert
Are you a Haier Heating and Cooling Expert? Answer questions, earn points and help others
