Question about Hotpoint NBXR333EGWW Dryer
Only one setting puts out heat (Heavy), the rest put out cold air. Is this a heater core issue or a timer issue or what?
  • 1,772 Answers
Gf
Sorry to read about your problem.
Their is a 80% chance you have a defective heat coil or coils (Low Heat). or the heat selector switch is defective.
I suggest you place a call to a service company.
I tried to help you. Please help me and vote/rate this response thanks.
If you live in Denver area, I can help you.
Posted on Jan 02, 2011
How do I fix the heat
You have one of two problems. The heater core is plugged /
restricted or there is an inoperative internal blend door motor problem. Start the vehicle and let it reach operating temperature. Feel the hoses under the hood that go into the heater core. They should be close to the same temperature. If one is hot and the other luke warm/cold.... the heater core is plugged/restricted. If both hoses are near the same temperature, suspect a defective/non operational blend door motor that controls heat/cold/airflow attached to the heater box assembly
Dec 21, 2015 | 2003 Dodge Stratus
I have a 1993 s10 truck no heat comming out just cold air, I replaced the heater core and thermostad and heat sensor.
The water cock is stuck closed,not letting coolant to circulate thru heater core.
Feb 17, 2015 | Cars & Trucks
When I put the heat on in my car it blows warm air for a few seconds then goes to blowing out cold air.
The lack of heat in the car has little to do with the car's cooling system, other than the hot coolant is the heat source. 95% of all "no-heat" issues are related to heater controls and/or the heater core itself. Since you get some heat, and then it goes away, this indicates a probable vacuum leak in the heater controls. When you select heat, vacuum is directed to a vacuum motor. This motor operates a vacuum actuator that moves a linkage that moves a door inside the heater box to direct the interior air through the heater core. If this actuator has a leak, it will activate, then as the vacuum leaks off, deactivate. You probably need to have a part replaced in the heater actuator mechanism.
Jan 20, 2015 | 2005 Nissan Altima
Heater blows cold
To troubleshoot this types of problem,click the link below :----http://howtobyme.blogspot.in/2012/02/heater-blows-only-from-defrost.html
--------Go through the procedure to confirm the issue.------
Engine Overheats and heater blowing cold? http://howtobyme.blogspot.com/2011/11/engine-overheats-and-heater-blowing.html
---------Heat blows cold on drivers side and hot on passenger side? http://schematicsdiagram.blogspot.com/2011/12/heat-blows-cold-on-drivers-side-and-hot.html
This will help.Thanks.
Feb 15, 2012 | 2003 Buick LeSabre
My heater doesn't work. The blower comes on but no heat. Regardless of the setting (60-90 degrees) only cold air. Defrost works to clear windows but no heat.
Most likely your heater core has been clogged up with years of contaminants. The fix here is to pull the heater core, have it flushed or replaced, and put it back.
Dec 25, 2010 | 1994 Cadillac DeVille
What could be causing my heat to only blow cold air?
maybe the heater core is plugged.
some people have been able to put compressed air into the heater hose going to the heater core dislodghing the blockage, but this has the potential of blowing the heater core apart if too much air is used.
Oct 31, 2010 | 1990 Oldsmobile Ninety Eight
98 sable -no heat. changed thermostat, new recovery tank, radiator flushed. heater core clear . if i run engine at 2500 rpm ,will give some heat
Since your blower is working and it is a heat issue,thats where we'll start,First thing is have you checked the coolant level in the radiator when engine is cold,make sure it is filled to top,next verify you have coolant in reserve ,Start your van and get it up to normal operation temperature,If your heat gauge on the dash works correctly it should be 190 degrees,Now lift the hood and locate the two heater hoses going into the heater assembly at the fire wall,Both hoses should be hot to hold on to,if both are hot and no heat inside your problem will be the blend air door in heater assembly.
if neither hose is that hot you need to replace the thermostat in the engine to get it up to 195 degrees.
if one hose is hot and one is luke warm then the heater core is blocked and to blame. hope this helps you.
Dec 29, 2009 | 1998 Mercury Sable
I just changed the thermostat on my vehicle and also put a new radiator in. My car blowing freezing cold air when i have it on hot. what might be wrong with my heat?
if you had any kind of heat before you started,you probably have air trapped in the heater core in the the rest of the coolant system
Dec 20, 2009 | 2002 Mitsubishi Galant
Hotpoint NBXR333EGWW Dryer Logo
95 people viewed this question
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
