Question about Price Pfister 01-81BC Savannah 3 Handle Tub/Shower, Bell Shower Head With B
Our shower head is very similar to the Price Pfister Savannah model. Recently we were forced to replace our water heater. As a result several faucets were blocked up with debris. We suspect that is the problem with the shower head but I don't know how to disassemble it to check.
The simple method is to take the faucet head off the extension pipe that comes out of the wall. It will take two pair of pliers and a firm grip to take it off. Using a wet/dry shop vac at the supply end and a garden hose at the shower end, force water backwards through the faucet head.
Posted on Jan 02, 2011
Testimonial: "Thank you! We are in WI so we will have to wait a bit to try this...but we'll let you know when we get a warm spell."
Price-Pfister shower clogged after work elsewhere on water lines
remove cartridge blow out water lines be careful
Feb 09, 2013 | Price Pfister Home
3 handle shower - handles tap/ block each other
It sounds like you have the wrong handles for this faucet assembly. Did you recently purchase new handles?
Jan 17, 2013 | Price Pfister 01-81BC Savannah 3 Handle...
Price Pfister tub/shower facuet needs much force turn on and off
put water off at mains . step 1.-open your i box mixer. step 2-u will see a 2 mm pin. mabe yours looks difrent. bt there were u change between bath and shower that button... that nob wil have a pin at the back. try to put q20/oil in there or sope. if that dosent work u will have to get a plumber in to unscrew the mixer and clean out the inside. not recomended if not a plumber bt if u do wane try it ur self and the sope and oil dident do the job let me know im a plumber will walk u threw it
Jul 04, 2010 | Price Pfister 07-81PC Savannah 2 Handle...
I turn on the spout for my tub and i turn the dial for my shower head to come on and it does, no problem, the shower head shoots water at full force, great water pressure, but there is still water coming...
I would look into the spout being the issue. The spout is a bypass when the shower is on and yours seems to be letting water get through. I would replace the spout..
Apr 27, 2010 | Price Pfister 01-311 Shower Head, Tub...
1 handle pull and turn bath room faucet no hot
a common fault if the handle is forced the spindles get worn best to replace
Sep 12, 2009 | Price Pfister Home
My shower head leaks
for some reason the cartridge set up does a sporadic drip which is infuriating but replacing the insert will not fix it
after the cartridge there is just an empty hose to the shower head and no pressure
Nov 13, 2017 | Price Pfister R897EBK Brushed Nickel...
Price Pfister Shower--No water to shower
Does the tub spout water flow stop when the shower knob is pulled?
Was the systems pipping flushed before the shower head was installed?
It may be clogged, remove the shower head and then attempt to operate. If it is clogged you will see debris trapped in the screen at its connection point. The shower head can be disassembled - cleaned - reassembled
Is the shower head an adjustable type, that may be in the off position?
Good luck
Aduz
Mar 26, 2009 | Price Pfister Hanover 950-102S Soap &...
Swaping Pfister Shower leaver handle
it must be the same model number,most models come in different colors and styles.
Feb 27, 2009 | Price Pfister 01-111 Shower Head, Tub...
Price Pfister ashfield collection shower single lever.
This sounds like a proper with your water heater. If you just installed this new shower head. First take it off and make sure that the hot water valve is opening fully if that checks out then go to the water heater and make sure the pipes check out ok and also that the heater is ok. Try putting a water heater blanket on it. Also try getting some pipe cover and cover the hot water line so on really cold days or not you will have warmer water
Feb 13, 2009 | Price Pfister Ashfield Single Control...
Price Pfister 01-81BC Savannah 3 Handle Tub/Shower, Bell Shower Head With B Logo
176 people viewed this question
Top Price Pfister Home Experts
Mike
Tim Whalen
Are you a Price Pfister Home Expert? Answer questions, earn points and help others
