Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
How do you reset your code on the outside touch pad for garage door when you dont no the 4 digit code from previous owner
    Novelist:
  • 128 Answers
Get all the remotes together.
On the end of the GDO (where the wires are) is a "Smart" button.
Press and hold the smart button for 10 seconds (until the LED goes off). This will clear the memory.
Now press and release the smart button, take one of the remotes and press one of the buttons (usually the top, largest one). The light should flash on & off.
Perform this same procedure for all other remotes. Also do the same with the keyless entry. Always press the buttons slowly on the keyless entry. It is easy to mispress a button.
Posted on Jan 03, 2011
Batteries need changing in the garage door remote control. It requires the code to be reset but the previous owners of the house left no information. It is a Wayne Dalton, Magic Touch, Model Number...
Using a step stool reah up and remove the plastic light cover from the garage door opener and the the code setting instructions are written on its panel. Or seach on LiftMaster.com for help.
Jul 26, 2011 | liftmaster Remote Light Control Garage...
Tried to reprogram security code for outdoor key pad on 1/2hp craftsman garage door opener according to instructions online, pressed learn button- put in new 4 digit code-held enter. Lights did not flash...
Seems you've done everything right. Press and immediately release the smart/learn button and then walk over and key in a 4 digit code and press enter. If you are sure the battery in the keypad is good then I think your keypad is on the fritz or the wrong one for that opener.
Apr 19, 2011 | Sears Craftsman LiftMaster Chamberlain...
All I want to do is to change my code on my outside key pad to my craftsman garage door opener key pad.
Here is what you do.
Locate the smart/learn button on the rear of the motor unit near where all those white wires go. Press and immediately release this and then walk over to the keypad and key in any 4 digit code you like and press enter.
Nov 21, 2010 | Sears Craftsman LiftMaster Chamberlain...
I have a chamberlain/craftsman garage door keypad from previous home owner and do not know the old password to reset my own. How do I reset the password without knowing the old one?
Oct 22, 2010 | Sears Craftsman LiftMaster Chamberlain...
How do I change the code on my outside touch pad?
  1. Press the four buttons for the present PIN, then press and hold the # button. The opener light will blink twice. Release the # button.
  1. Press the new 4-digit PIN you have chosen, then press ENTER. The motor unit lights will blink once when the PIN has been learned.
Test by pressing the new PIN then press ENTER. The door should move.
Sep 18, 2010 | Sears Craftsman LiftMaster Chamberlain...
I can't get my key pad for my garage door to open. can i reset my key pad to open my garage door???
You can reset the code but it sounds like it may have just failed. Make sure the battery is good and try more than one just in case. To reset the code:
Locate the smart/learn button on the rear of the motor unit near where all those white wires go. Press and immediately release this and then walk over to your keypad and key in your 4 digit code and press enter.
Mar 03, 2010 | Sears Craftsman LiftMaster Chamberlain...
We just moved into an apartment the previous occupants didn't know the code for the garage door opener and just used the FOB we need to access it from outside without the FOB, how do we reset the...
You will have to have access to the outside keypad and the motor head. Make sure there is a new battery in the keypad. Press the 3 -6-enter buttons at the same time to erase. Then press 357-prog, then press the 4 digit code-prog. Then go up to the motor unit and press the learn button. Go back to the keypad and press the 4 digit code followed by the up/down button, press the up/down button 2-3 more times and the door should move. If you have a black keypad this will not work, ask again with this info if needed. Thanks BB
Dec 14, 2009 | General Electric GE 13-438 Overhead Garage...
How can I reprogram my keyless pad?
If you mean wireless keypad it is like this. Locate the smart/learn button on the rear of the motor unit near where all those white wires go. Press and immediately release this and then walk over to your keypad and key in your 4 digit code and press enter.
Oct 19, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door pad
You need to press and release the learn botton (don't hold it or you will clear all the codes)
If the light bulb(s) on your operator are on the front and/or back, the learn botton is on the back of the operator. If the lights are on the sides of the operator then the learn botton is on the right side (looking from the back of the operator and facing the garage door).
After you press the learn button you have about 30 seconds to press in the new 4 digit code in your key pad then hold the enter button until the light on the operator blinks (about 2 seconds). If this does not work check the battery and try it again.
Aug 04, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
405 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
