Question about Dryers
I have a Heller CD55 clothes dryer, it turns on, draws in air (i think) but doesnt turn or dry my clothes
  • Anonymous Dec 01, 2008
    Hi there i have one that is doing the same thing and once i opened the back i saw that the belt has broken off hope than has helped you.
  • shaun_belle Jan 04, 2009
    I have the same problem the dryer turn on but the drum does not spin, i have pulled the back covered off and found the belt was broken does any one know where i can get a belt? and possiblhy the diagram to show me how to fit the belt?
Sounds like a broken drum drive belt.. Ours does this about once every 6 months.. When it was in warranty the first few times we'd wait the 3 weeks for Heller to post the belt (and the second time, a replacement overheat-cutout sensor, as I was getting sick of having to open the back up and reset it) to the local service place.. Then I got sick of that, and we just take teh 15 min drive to our local appliance parts place, and pickup a 'CPD 7 RIB' (part no 0198300011) belt from a fairly new model simpson dryer, which has exactly the same belt..
I probably wouldn't suggest trying it if you're not a home handyman, as it means pulling the back off, and disconnecting a few wires and undoing a few mounting bolts to get the new belt around the drum, but it's only a 10 minute job if you know what you're doing..
If you want to take it to your local service place, just make sure they realise that they don't have to go to the hellar importer to get the replacement belt - a current model simpson belt fits fine :)
PS, they're 192cm long, 1cm wide, 7 'ribs'..
--DG
Posted on Jul 06, 2009
  • maggiemac77 Mar 16, 2012
    If ours spins, and air is coming from the vent but doesn't dry clothes as doesn't seem to get hot enough, what might that be?
  • Damien Gardner Mar 16, 2012
    Maggie: does it get hot at all? if it's not actually getting hot, then dollars to donuts, it's the overheat cutout switch inside the back.. If you're confident with a screwdriver, *DISCONNECT FROM POWER*, then remove the back panel, see the little black push button at the top just to the left of centre - press it down, and you'll hear it click. Re-install the back panel, and reconnect to power, and it should be good to go.. You may find that it'll blow again next time you have a big load, or it fills with fluff.. Ours got to the point that I drilled a hole in the back cover to get at the button - but that's not overly safe, as that button is *LIVE* when power is connected.. We ended up selling ours for 50 bucks on ebay, and buying a 'real' brand.. :)
You can get a belt from this number 1300 767 041 or they can tell you where to get it, but be careful we put our own belt on now the dryer keeps losing it heat, there is some button in the back, like a saftey switch that keeps setting off.
Posted on Mar 26, 2009
Mine broke too and i cant find the drive belt for it anywhere online. does anyone know where to buy one?
Posted on Jun 20, 2009
Im looking for a picture of a heller cd55 dryer with the back off it. Mine has a broken terminal and not sure where it goes its the 2 light blue wires.
The thermal cut out device on the left of the picture which I see only one wire going to, should have a second terminal on it. It is similar to the one on the right with the red and orange wires.
May 03, 2016 | Dryers
The dryer wont heat up the clothes dont get dry everything eles works on it the drum turns ok the timer works also it just wont dry the clothes
Hello,Sam
The usual reason a dryer will heat yet not dry the clothes is going to be a air flow problem. What ya need to check is for a blocked vent and or lint build up in the blower assambly.
By far though a leading cause of that on Maytag dryers is a broken blower wheel and therefore no warm air is being drawnthrough the clothes,to check that remove the front panel and the front drum support and in the lower left corner will be the blower asm. check to see if it moves free and doesnt seem to be attached to the motor shaft.
GENE
Sep 20, 2011 | Maytag MED5770TQ Electric Commercial Dryer
It gets hot but doesnt dry
you will need to remove the front cover,by removing 2 kick panel screws at the base of the front of the machine,remove front cover and make sure blower wheel is turning,if so,then remove any heating ductwork and vacuum out all lint,this sounds like a restriction inside the machine for air flow
Mar 05, 2010 | Whirlpool Inglis IP8200 Dryer
The dryer does not turn, but will turn by hand, how do you unlock heller cd55 dryer?
It won't tumble If your dryer doesn't tumble, check these: Belt Motor Door switch Belt Dryers have a drive belt that turns the clothes drum. If the belt breaks, the drum stops rotating. Then you need to replace the belt, and often the idler pulley, because the pulley tends to wear out at the same time. Click here for a belt installation diagram Motor If the dryer motor only hums when you press the Start button, the motor may be burned out. Here's how to test the dryer motor: Remove the belt. Check for obstructions in the blower fan housing. Manually rotate the shaft of the motor. If the motor is very stiff, or impossible to rotate manually, and the blower fan housing is clear, you need to replace the motor. If the motor rotates freely, run the motor momentarily with the belt removed and the blower in place. If the motor runs fine with the belt removed, there may be a problem with the idler pulley or the clothes drum. Try to rotate the drum by hand. If it is very difficult to move, correct any problem with the rollers or pulley, and then reassemble the dryer and try it again. If the motor hums but doesn't rotate on its own even with the belt removed--yet you can turn it freely by hand--you usually need to replace the motor or the motor start capacitor. Door switch Your dryer can't operate at all if the door switch is defective. It's inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. If it's defective, you need to replace it.
Dec 31, 2009 | Dryers
The dryer doesnt get hot enough to dry clothes
Pull the dryer out and remove the lint hose . Turn on the dryer and feel if there is good air flow and if you feel heat . If there is good air flow and heat , dry a load of clothes , to see if they dry normally .
If there is not good air flow , then the blower wheel is probably stripped and needs to be replaced . If there is good air flow and heat , then the problem is in the vent ducting , between the dryer and to where it vents to the outside . Dryer could be pushed back too far , causing the hose to " kink " , restricting the air flow to the outside .
Remember , a dryer either heats or doesn't heat . If no heat , then a dryer problem exists . If heat , but dryer does not dry , then a vent problem is the cause ( except for maytag , which the blower wheel sometimes strips out ) .
Nov 08, 2009 | Maytag PYE2300AY Electric Dryer
Maytag gas dryer wont turn off when done drying in auto dry regular fabrics. does turn off in air fluff and auto dry perm. press. model # d3382
auto dry relies on a moisture sensor to say when its done. so your clothes arent dry enough according to sensor. perm. press. doesnt dry the clothes as much
Aug 01, 2009 | Dryers
Does not heat
"Steam drying will get how but the air that comes later to actually dry is cold so the clothes never dry"
I am assuming "how" means hot in this sentence, if so, I think I can help! There is no "steam drying" phase for your dryer so what is probably happening is; the wet clothes are being heated properly [as a result causing steam] however if this steam does not escape frum the dryer it will simply condense back onto the clothing [leaving them moist/wet].
Check your flexible tube from the dryer and the vent on the outside of your home to make sure they are unobstructed. Hope this helps!
Oct 13, 2008 | LG DLE2514 Electric Dryer
Dryers Logo
1,600 people viewed this question
Top Dryers Experts
