Question about Dewalt DC920KA Heavy Duty Xrp 18V Cordless Drill/Driver
Is there someone (a professional) who will accept porcelain plates to drill to make a 2 or 3 tiered serving piece? Preferably on the east coast (near Philadelphia?)
  • 2,527 Answers
You can do it your self stay away from the cordless drills get a carbide drill bit and a tube fill it with some water so it covers the peice of porcelain you want the hole in. Ihave know idia what a 2 or 3 tiered serving piece is. But if its made out of porcelain but if you have a high speed drill and bit and you can keep the peice cool you can drill perfect holes in it. It may take some time if the hole is 1/2 inch or more depending on how thick the meteral is put a peice of wood under the peice so you don't drill through the bottom of the tube. But small holes 1/4of an inch are much quicker to do. I dought you can find anyone else to do this for you And it sounds vary artsy but this how its done with tile and you can drill perfect holes in porcelain just go slow and steady and keep it under water at all times. good luck
Posted on Jan 02, 2011
Holes missing from 5 tier bookcase metal Putting shelves together. Can I drill Holes in metal?
Yes you can, you just need a drill, the correct size SHARP drill bit, a pin punch - important!! - (to punch a dent in the exact place you want the hole to be - this will hold the drill bit in place when you start drilling)..take you time..use a piece of wood (2x4) to back up the piece your are drilling into... then deburr with a file..
Jul 02, 2017 | Drills
Where can i find a 5/8 in. chuck for a Pit Bull CH-16NF Drill press
Take it to a local engineering sales shop. They are all basically the same and fit into the shaft with a morse taper. You just need the correct taper.
  • 5/8 in. Keyed Drill Press Chuck ' Princess Auto www.princessauto.com/en/detail/5-8-in-keyed-drill-press-chuck/A-p...
    • 4.5/5
    • 2 REVIEWS
    Email Signup. Never miss a sale and receive special online only offers.
  • King Canada KDC-58M Chuck, Drill Press, 5/8" JT6 for ... https://eastcoastpowertools.ca/chuck-drill-press-5-8-jt6-for-milling King Canada KDC-58M Chuck, Drill Press, 5/8" JT6 for Milling At East Coast Power Tools
  • 5/8 in. Keyed Drill Press Chuck ' Princess Auto www.princessauto.com/en/detail/5-8-in-keyed-drill-press-chuck/A-p... Help others make a decision about this product by sharing your experience.
  • Related searches for 5/8 in. chuck for a Drill press
  • Woodstock D3455 Drill Chuck, 5/8-Inch by JT33 - Amazon.ca https://www.amazon.ca/Woodstock-D3455-Drill-Chuck-8-Inch/dp/B000HRXOLS This item: Woodstock D3455 Drill Chuck, 5/8-Inch by JT33 CDN$ 47.71. In Stock. Ships from and sold by Amazon.ca. FREE Shipping. ... (Canadian Tire) Drill Press.
  • 5/8 Drill Chuck ' eBay 2q== www.ebay.com/bhp/5-8-drill-chuck Suitable for drill presses or lathes spindle accepts R8 shank. Chuck key and R8-JT33 arbor are also included in the package. Special quenching treated ...
  • 5/8" Drill Press Chuck [MAG-DPC58] - $29.99 : KMS Tools ... https://www.kmstools.com/5-8-drill-press-chuck-2990 KMS Tools & Equipment from Vancouver BC 5/8 ... Home > Metalworking > Lathes and Milling Machines > Chucks and Taper Adapters > 5/8" Drill Press Chuck 5 /8 ...
  • 1 32 5 8 Heavy Duty Drill Chuck with Chuck Key and R8 Arbor Amazon com
    Jun 05, 2016 | Drills
    The plate is separated from the stem (stand) - my client wants me to fix it. I am not sure if it is glued together or other?
    Depends on the plate. If it is porcelain then it was fired as one piece, if it is glass then it was fused together. For fixing it I am guessing you do not want to pay someone else do repair this in the manner that it was created. My suggestion is Gorilla Glue. Works great and holds well.
    Aug 05, 2015 | Motorcycles
    How do i fix my fan speed problem. I lost 1 of 2
    It may be a defective switch, loose or corroded contact connection point, where the wire meets a terminal. If these check out good, then the fan motor is defective and needs to be replaced with a new one.
    May 29, 2014 | Coleman Mach III Air Conditioner
    What are the different type of plate shapes?
    Rim-shaped plates originated in Europe. In the West, food portions are cut into bite-size pieces at the table, and the rim-shaped plate is made with a well that collects the juices that flow from the food.
    Coupe-shaped plates have no rim and accommodate the way food is cooked and served in the East. In the East food is cut into bite-size pieces in the kitchen and cooked quickly over high heat.
    To allow space for the courses on one plate, the diameter of the coupe-shaped dinner plate is approximately 1 inch larger than that of the rim-shaped dinner plate.
    -http://www.etiquettescholar.com
    May 06, 2013 | Home
    I need instructions to put Wilton's 3 tier party stand together
    According to Wilton:
    You should have 8" plate, 10" plate and 12" plate
    Match the sizes with rings and legs on table.
    Attach legs to serving rings,twist threaded end securely into housing on each serving ring. Tighten using wrench.
    Attach 8 1/4 Serving ring to Center Footed Base Ring -Position serving ring with footed leg out. Line up the other 2 legs with the correct housing on the base ring, the width between housing should be same as that between legs.. Insert end of legs into housing.
    Next attach 10 1/4 Serving ring to Base Ring, You will need to move clockwise around base ring to attach this ring. line up legs and insert legs and tighten.
    Attach 12 1/4 serving ring to base ring. Insert legs into last pair of housing on the base ring.
    Position plates so lip edge rests inside serving ring.
    Apr 16, 2013 | Wilton WHITE 3-TIER CUPCAKE STAND...
    How do we replace the seat on a Kohler K-3386-0 Rialto one piece toilet? The screws/nuts holding the seat down are inside the toilet and aren't accessible. Is there a way to replace the seat without...
    Kohler will try to sell you $46 anchor bolt kit 84999 & also there special tool. You should expect that for a $400 toilet.
    Try this instead:
    1. Use 1/8" drill bit and drill and drill around the bolt until the anchor material can be removed.
    2. Carefully clean hole with 11/32 drill to remove all remaining acchor material.
    3. Go local hardware store & buy a 10 - 32 3/8"X3/4" rubber expansion plug (make certain threaded part is brass & has shoulder on 1 end), a 10 - 32X1.5" Phillips bolt and couple of small fender washers fit the seat.(about $4 for 2)
    4. Assemble carefully not to over tighten and crack the porcelain.
    Hope it helps
    Oct 06, 2010 | Kohler K-3386-0 Rialto one-piece...
    I changed the Navigation disc to west side and can't get it to accept the east side navigation Disc? Is it possible? How?
    eject the disc and reset the radio. then try to insert the east coast disc again. should work again after reset
    Feb 06, 2010 | Pioneer AVIC-N2 DVD/CD/navigation receiver...
    Is it possible to drill into a Kohler cast iron shower pan, without cracking the porcelain? I need to secure a track for a shower door. -- Thanks!
    Yes you can but you've got to buy a special bit. Porcelain will dull a brand new bit in seconds. You've got to get a carbide tipped or concrete drillin bit. Also while you are making preperations to drill put a piece of wide masking tape over the spots to be drilled. Don,t push down too hard and let the drill do the work. Good luck.
    Sep 08, 2009 | Home
    Where to buy in los angeles replacement bulb ryobi drill/flashlit
    Try King Power ph#323-262-3517 or Minit ph#323-264-7006. You might also try some of the bigger box stores or lumber yards Hope this helps I am on the east coast
    Jan 14, 2009 | Makita 6233DWBLE Factory Reconditioned...
    Dewalt DC920KA Heavy Duty Xrp 18V Cordless Drill/Driver Logo
    83 people viewed this question
    Top Dewalt Drills Experts
    Jim Thurston
    Are you a Dewalt Drill Expert? Answer questions, earn points and help others
