Question about Dell Latitude D600 Notebook
No boot device available -cardbus nic boot failed What is the fix?
5 Suggested Answers
SOURCE: cardbus NIC boot failed
Please give us more details. Not sure what you mean.
Posted on May 09, 2012
1alexh
  • 484 Answers
SOURCE: How to configure theh bios to boot to cd
Try getting into the BIOS setup routine. It may take F1 or F10 just after you start the power and hear a single beep. Then hit the Function key. Once you get into the BIOS setup, look for the setup area in which you can determine in what order your PC will look to boot. As in 1-HDD, 2-FDD, 3-CD, 4-USB Flash Memory and so on. You may have the CD boot turned off altogether, and will need to simply toggle it back on.
Good luck,
-a.
Posted on May 22, 2009
SOURCE: Cardbus NIC is failed
If you are saying your NIC is bad then you will have to have it repaired.
You could use an alternative method of getting a nic instead of repairing. You could use a device that plugs into your usb port that gives you a nic connection. You could also use a device that plugs into the pcmcia slot that gives you a nic connection.
Try Tiger Direct for purchasing alternatives for under $20
Below is a link to a usb to nic
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=443248&CatId=589
Below is a link to Pcmcia to nic
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=308770&CatId=588
bronk50
  • 27725 Answers
SOURCE: I have a used dell laptop. It wouldn't boot so I went into the boot sequence utility. It has the primary boot path as NIC CARDBUS. I wen to change it and there is a password on it. I have no idea
The most common way that most of us know on how to reset or clear the BIOS password is to
physically remove the power from the computer by disconnecting the power plug and then
removing Cmos battery for 30 minutes from the motherboard.
You need to open the PC case, then look for a 20mm (3/4") shiny lithium button cell.
some motherboards cmos batteries are soldered in
Another way is to reset the clear CMOS jumper on the motherboard itself.
Both of the 2 methods mentioned works because most motherboards use a battery to sustain the
BIOS/CMOS settings for the motherboards PROM chip.
So by cutting off the battery power, the BIOS/CMOS settings will be erased.
cmos battery Under the keyboard or bottom of laptop -
If you are working on a laptop computer the location of the dipswitch
(almost never a jumper) can be under the keyboard or on the bottom of the laptop in a compartment such as the memory compartment.
http://www.corenetworkz.com/2009/08/forgot-bios-passowrd-how-to-reset-bios.html
hope this helps
Posted on Jul 15, 2012
Cardbus nic boot fail
Go to BIOS settings and check what is the order of BOOT devices there. Ensure that you have HDD as the first option if you want to boot from a hard drive. You can accordingly chose the 2nd and 3rd options to fit your requirement
Dec 29, 2013 | Dell Latitude D610 Laptop Computer -...
hope this helps
Jul 14, 2012 | Dell Inspiron 2200 Notebook
Cardbus NIC boot failed
May 08, 2012 | Dell Lattitude D600 Notebook
May 08, 2012 | Dell Latitude D600 Notebook
My computer keeps trying to boot from another source
You would have to go into your BIOS by hitting the F2 key as it is turning on. Then go in, and under Advance settings, make sure that the only place that it boots from is the Hard Drive. Make that the primary.
If it still has an error coming up, then it might be a file system issue with the OS.
Apr 04, 2011 | Computers & Internet
Who to uninstall and reinstall the nic card driver
I believe your question is how to uninstall and reinstall the nic.
Go to control panel->system->hardware->device manager
alternatively type devmgmt.msc in the run dialog box
click on the plus sign infront of network adaptors right click on the network card present click on uninstall. You will get a warning that you are about to uninstall this device from your system, select OK and once that device is gone restart the system go to the action tab on the top in device manager and select scan for hard ware changes the network card would be reinstalled automatically.
Jun 21, 2010 | D-Link Wireless CardBus NIC 802.11G [...
Network card not detecting in RHEL4 & 5
The solution proposed by user 'Solutions58' seems to be about windows box since he is talking about 'Device Manager'
RHEL4 or 5 detect compatible NIC cards during boot up process automatically. Sometimes NIC may be detected but may not work properly due to lack of proper driver (a.k.a Module - in Linux culture).
Do this -
1. First find out from HP's web site if NIC for your model has Linux support. You can also use Google to find appropriate driver for your NIC. If yes then you need to follow instructions that are provided in the INSATLL file that comes bundled with the driver.
2. Otherwise buy a $10 NIC card which has Linux support. Disable your onboard NIC through your computer's BIOS and boot it. Linux should detect your NIC right away.
3. Following command can help you in your quest
As root
# dmesg | grep eth (Will show your detected NIC)
# service network status (Will also show configured & active devices)
# ifconfig -a (Will also show your network devices and related info)
# system-config-network (will let you configure your NIC via GUI)
(This would be your best choice)
# system-config-newtowk-tui (Will give you a text base interface to configure your NIC)
Aug 05, 2009 | HP Computers & Internet
when u power up the computer press "del" or F2 to enter in bios
then go t o boot option set first boot device as dvd drive then presss F10 then save all settings then it boot with dvd or cd
May 22, 2009 | Computers & Internet
XP won't boot without IBM 10/100 EtherJet NIC
Check the BIOS to make sure the machine is not trying to boot off of the network card (PXE boot) and make the hdd in question the primary boot device.
Feb 26, 2009 | Computers & Internet
Doesn't install properly on Thinkpad 760XL running WIN98 SE
Make sure you have all the drivers handy.
Uninstall the sound
Uninstall the modem
Uninstall the nic drivers as well as the wirelss nic drivers.
Uninstall all others that have conflicts.
Remove the adapters out of the pcmcia slots. (Ethernet, etc
Shut down and restart the system.
The system should detect all hardware again.
Now if this laptop has an onboard nic and modem disabled them
Shut down and restart system.
Check control panel to make sure they are diabled.
Now istall the combo card nic/modem.
If this does not work you should try diabling them in the bios.
As for the wireless nic. You normally would have to install the software prior to inserting the adapter.
Let me know what happens
Hope this helps you
Nov 02, 2007 | IBM EtherJet Network Adapter
Dell Latitude D600 Notebook Logo
1,032 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
