Question about Seagate 500GB USB 20 5400RPM Portable 500 GB Hard Drive
My External HDD's adapter blow and i want to know if any 12v adapter will make it work?
  • 374 Answers
Be careful, not all 12 Volt adaptors are the same. Some put out AC voltage and others DC. You need a 12 V DC adaptor. The adaptors are polralized, that is one output wire is + 12 V and the other is - 12V.. If you connect it backwards you can blow your hard drive.
If your not sure regarding correct polarity, consult a technician who knows how to use a voltmeter.
Also, the current rating of the replacement adaptor must be equal to or greater than the currenr rating of the original. Example: Old adaptor = 375 Ma. , New adaptor = 750 Ma. This would be OK.
If you have any additional questions contact me by clicking on the "Add a comment" link located under your problem description on FixYa. Also, if you believe that this information was helpful to you, please return to the FixYa website and rate my response to your question.
Best regards,
Yavacotech
Posted on Jan 02, 2011
What is the AC DC adapter spec for SEAGATE 9NK2AE-500. i lost the original adapter that came with this external seagate freeagent harddrive.
most of these external hard drive units work with a 12V 3 amp DC power supply like this one
OEM AC POWER SUPPLY SEAGATE 9NK2AE 500 Free Agent HDD
Make sure you get the correct power connector for your country.
Aug 17, 2014 | Computers & Internet
My seagate external hard drive power supply adapter had shotcircut, will my external hard disk which is 1 tb will work?
Usually there is a diode in place to prevent spurious voltage reaching the hard drive. Replacing the power supply may work. I would replace the whole enclosure.
Mar 26, 2014 | Seagate Computers & Internet
My ac adapter suddenly started smoking but i was able to turn it off immediately. will it affect ny hard drive? is it a problem with the hard drive or adapter?
Surely there is a short-circuit problem with your adapter.The adapter is propably off .You cant know for sure if hdd was affected.Dont connect the adapter to the case anymore for now.
Most external hard disks can be disassembled with relative ease.Disassemble it and check at a local store to find a case for external hdd (relatively low price) so you can see if the hdd works properly or not.
Apr 07, 2011 | Acomdata (HD060U2FE-72) 60 GB Hard Drive
External HDD Shuts Off
Could well be the power adapter. They seem to fail quite often. AFAIK, it is a 12V / 2A adapter, so it should be easy to find a suitable replacement. Just make sure that it is a switching adapter with stabilized output voltage.
Mar 19, 2010 | Western Digital My Book Essential 1TB...
I accidentally plugged a 19V adapter to my 12V WD 1.5TB Hdd, now the hdd is dead
You'll have to hope that you have only blown a fuse on your HD Drive. other wise you will have to buy a new one. Have it checked by a tech and see if the HD itself can still be salvaged.
Dec 15, 2009 | Western Digital My Book Essential 1TB...
I have a simpletech 320 gb pininforte external hard drive, and I lost the ac/dc adapter. I wasn't sure what it looked like as it wasn't shown anywhere on the box so I tried some I have around and I think...
It needs a 12V 1.5A adapter. But if the light was on for a short while, and it doesn't do anything anymore with the same adapter.. Doesn't sound very good.. I wish you all the luck with the external HDD!
Jul 07, 2009 | SimpleTech SimpleDrive Pininfarina 320GB...
Unusual Power Requirement
Should not be a problem, the theory here is Volts * Amps =Watts
5V * 2A = 10w
The alternative is to get a LM7505 ($1 or 2) from radioshack or any electronic supply and regulate the 12v down to 5v. its about 1/2 square IC chip.
Pardon my ASCII:
[_]
input 1.7V - 35V ________| | |_____ +5v (+/- 1%)
Pin 1 Pin 3
will accomodate 1 Amp (1.25 if heat sinked) for the CMOS version, slightly higher for the olde r(less effecient) version
The other pin is ground. OF course you will want to check the specs and pin assignment for the brand you buy, these are typical.
TechieJon
Apr 18, 2009 | Computers & Internet
I need to replace the power adaptor for a Maxtor One Touch 4 500 GB. I need to know the volt and amp output for it. PN:9NT2A4-500
Power Adapter for Mactor OneTouch 4
AC Input : 100 AC - 240 AC (50/60HZ)
DC Output ( V/A ) : 12V / 3.5A
Output Power : 42W
Apr 17, 2009 | Maxtor OneTouch 4 500GB External USB 2.0...
Lost ac/dc adapter for a 320 GB Simpletech External Hard Drive
I have the 320GB Simpletech External Hard Drive.
The AC adapter Model number is SAWA-05-153
The output is +12V --- 1.5A
Nov 16, 2008 | SimpleTech SimpleDrive Pininfarina 320GB...
Seagate 500GB USB 20 5400RPM Portable 500 GB Hard Drive Logo
247 people viewed this question
Top Seagate Computers & Internet Experts
Computer Links
Steve
terminalcon
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
