Question about Gateway 2520915 Keyboard
How do I change the E-mail key function to start a different E-mail program when pressed with a gateway CEoc78 wireless keyboard
  • edd_diamond Jan 10, 2011
    The above information worked. My guess is when the Microsoft updates are downloaded to your computer, it switches programs to their default programs. Now I know how to change it back.
  • 613 Answers
Start>default programs. Click bottom one has the settings you need. "Set program access and computer defaults" Use custom and click arrow at right. Then a menu will drop down. select the email program you want and you have an option of allowing the others by checking boxes. Do this for all of your preferences and click save or ok.
Posted on Jan 02, 2011
What do the f keys mean
The 'f' keys at the top of the keyboard are known as 'function keys' - they have special functions inside a program, an application or in your operating system. They can be pressed alone or in combination with other keys, as 'ALT', "CTRL', 'SHIFT' or 'Fn' keys, to present other functions.
In Windows, F1 generally brings you the Help for the program you're on, F3 gives you the Search box, F5 refreshes the page, F11 gives you a full page in Internet Explorer and so on. Most programs can be closed when you press the 'ALT' key together with F4.
So, inside each and every program, different functions can be attributed to the F-keys, providing you with different capabilities. For instance, you could search in Google for "Word function keys" to check how they were set up for Microsoft Word.
These keys, associated with the 'Fn' key in some laptop keyboards, can be used to increase or decrease the display brightness, start the Internet Explorer or the Media Player increase or decrease the sound volume, and even open the DVD player 'door' - it will depend of the characteristics of the different models of laptops.
Hope this helps!
Regards,
Miguel L. Martins
Nov 01, 2013 | Gateway Computers & Internet
Gateway laptop nv57h94u model Fn key is on all the time for the function keys
clean keyboard, reboot PC, press Fn key one more time, if cant help then replace keyboard
Nov 12, 2012 | Gateway Recertified - NV Series NV57H94U...
Touchpad not working gateway-6825
Locate the "Fn" key in the lower right or left corner of the laptop keyboard.
The "Fn" key typically has different colored text on it or the key itself is a different color.
Locate the function (F1 through F12) key at the top of the keyboard that disables or enables the touchpad on the laptop.
The key typically has an icon that resembles a touchpad with a finger touching it or a touchpad with a diagonal line through it.
Press both the "Fn" and touchpad Function key simultaneously to reactive the touchpad on your laptop.
Move your finger along the touchpad to verify that it works.
Press the combination at any time to disable the touchpad again.
hope this helps
Sep 16, 2012 | Gateway New P-6000 P-6822, P-6825, P-6832,...
Emachines wireless not working
Try looking in the program list for the program that starts the wireless. Click Start/Programs and look for the program that drives the wireless and open it.
Maybe you don't have your wireless turned on. Look on both sides and in front for the Wireless Switch and turn it on.
Also once the wireless switch is turned on there are keystrokes that can toggle the wireless on or off. Normally you would Press and Hold the FN function key located at the lower left of the keyboard, then hit the correct F1 thru F12 key that toggles the wireless. The correct F1 thru F12 key to hit will have the wireless signal icon )))) on it. Or it might have the icon of a tower with the wireless signal icon )))). Normally the screen will display Wireless On or Wireless Off when you toggle the wireless.
May 11, 2012 | E-Machines M5312 Notebook
Wireless on my compaq c60 is disabled but i cant find a switch to enable it. Can i use function keys and if so which?
I am unable to find a photo of your laptop's keyboard, so I cannot be certain which function key will enable your wireless adapter.
However, most laptops are very similar, so this solution should work for your problem.
1) Locate the secondary function key (probably labeled "FN") on your keyboard.
2) Locate the key which controls your wireless adapter as a secondary function. It will have the following image on the key: http://cdnsupport.gateway.com/s/Mobile/2007/Phantom/WirelessIcon.gif
3) While holding the FN key, press the wireless key
4) Your wireless adapter is now enabled. If you are still having wireless issues, the problem was not that the hardware wireless adapter was disabled.
Apr 07, 2011 | Compaq Presario CQ60-212US Notebook
I need an explanation as to the secondary function of the keys on my NB305. Mainly the top row of 'F' keys, but the remainder of the keyboard as well. What do all these little symbols on the keys mean?
F1 through F12 are called function keys because they execute programmed functions when pressed. Used in combination with the Fn key, keys marked with icons execute specific functions on the computer. The function executed by individual keys depends on the software you are using.
1. Sound Mute: Pressing Fn + ESC in a windows environment turns sound on or off. Press Fn + Enter to simulate Enter or the enhanced keyboard's numeric keypad. 2. Instant security: Press Fn + F1 to blank the screen to prevent others from accessing your data. To restore the screen and original setting, press any key or press the Touch Pad. 3. Power save mode: Pressing Fn + F2 changes the power save mode. 4. Standby: When you press Fn + F3, the computer enters Standby. 5. Hibernation: When you press Fn + F4, the computer enters Hibernation. 6. Display selection: Press Fn + F5 to change the active display device. Hold down Fn and press F5 again to change the device. 7. Internal LCD screen Brightness: Pressing Fn + F6 decreases the display brightness in decrements. 8. Internal LCD screen Brightness: Pressing Fn + F7 increases the display brightness in increments. 9. Wireless setting: If your computer has both Bluetooth and Wireless LAN functions, you can press Fn + F8 to select which type of wireless communication you want to use. 10. Touch Pad: Pressing Fn + F9 in a windows environment enables or disables the Touch Pad function. 11. Press Fn + F10 or Fn + F11 to access the integrated keypad. When activated, the keys with gray markings on the bottom edge become numeric keypad keys (Fn + F11) or cursor control keys (Fn + F10). The power on default for both settings is off. Press Fn + F12 (ScrLock) to lock the cursor on a specific line. The power on default is off. 12. TOSHIBA Zooming Utility (reduce): To reduce the icon size on the desktop or the application window, press the 1 key while holding down the Fn key. (13. TOSHIBA Zooming Utility (enlarge): To enlarge the icon size on the desktop or the application window, press the 2 key while holding down the Fn key.
Jun 15, 2010 | Toshiba 310CDT Keyboard
Where is the wireless switch located?
Try to examine your laptop keyboard.
  1. Look for a Function Key (F1 ... F12) with the wifi icon below it usually printed in orange or blue.
  2. Now press and hold the Fn key and press that function key with the wifi icon.
  3. That softly turns your wifi ON.
Feb 26, 2010 | Gateway 4525GZ Notebook
Please let me know how to Operate Function keys on the Key Board (Teclado Intel A27982).
Close F6: Closes the document or the file in the active window. Forward F8: Forwards the e-mail in the active window. Function Lock (F LOCK) Switches between the standard function key commands (F LOCK light on) and the Microsoft keyboard enhanced commands (F LOCK light off). Leave it on or off, or alternate between modes for increased key press functionality. Help F1: Opens the Help system for the active window. New F4: Creates a new document in programs that support this command. Office Home Starts the Web browser and goes to the Microsoft Office Web site. (This is not available on all keyboards.) Open F5: Opens a document in programs that support this command. Print F12: Prints the file in the active window. Redo F3: Cancels the previous undo action. Reply F7: Replies to the e-mail in the active window. Save F11: Saves the file in the active window. Send F9: Sends the e-mail in the active window. Spell F10: Starts the spell checking program in the active document, if the document's program has this feature. Task Pane Shows or hides the Office task pane that was previously displayed. (This is not available on all keyboards.) Undo F2: Cancels the previous action.
Jan 05, 2010 | Intel Dot Station (INTC300AIO) PC Desktop
Keyboard `problem `strange `dash `appearing
Many programs extend the usefulness of the function keys by using key combinations. The most common combinations are Shift + a function key, Alt + a function key, and Crtl + a function key. These combinations can be very useful. For instance, in Microsoft Word, when any text is highlighted, pressing the Shift key plus the F3 key will change the case of the text from all caps, initial caps, to all lowercase. Shift + F7 will choose the Thesaurus command. These shortcuts allow you to access such functions with one keystroke rather than three or four mouse clicks.
Dec 23, 2008 | Gateway 2520915 Keyboard
I can't copy & paste properly i XP.
im guessing that an alternative function key is depressed or pressed, locate said key and depress or press it. that should resolve your problem. alternativley check your keyboard location settings, usa, uk, etc, this can make the difference as different locations have different shortcuts.
hope this helps
kev
Nov 28, 2008 | Gateway 2520915 Keyboard
Gateway 2520915 Keyboard Logo
1,048 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
