Question about Colorado Memory Systems Colorado Jumbo250 250mb QIC SCSI External (Jumbo250), Condition Refurbished Tape Drive
JUmbo250 Hi Tried to clean the device the other day. Did something wrong and apparently damaged the transport mechanism. It is only possible to restore small backups. Get errors like "seek error" or the drive hangs, moving forward and backward indefinitely. I think the mechanics need a fix/repair. What to do? Yours honestly, Bob
  • 13,433 Answers
Yes it needs repair, I suppose the tapes are fine them selfs so they should work fine in another one, you will have to service the tape drive, you can get another tape drive and the tapes should work.
Posted on Jul 09, 2008
  • 2 more comments
  • Ekse Jul 09, 2008
    well in my opinion, get another tape drive or take it to a tech to fix it. I can't imagine getting in there my self, most likely will need to replace a few parts.
  • Ekse Jul 09, 2008
  • Ekse Jul 09, 2008
    Id really suggest to buy that 20 usd right above, the repair man would take more than that probably.
  • Ekse Jul 09, 2008
    even if you want to repair it the parts will cost so it will come around or more the price of a new one (20usd on ebay) Just get the new one and your problems should be solved.
    Let me know if you need anything else
Machine suddenly shuts off during playback or record - is this fixable?
When something goes wrong during playback etc, all VCR's will shut down to prevent tape damage, or further mechanical damage.
There are two possible causes for this problem. One is there is some sort of damage to the mechanism, possible a plastic part that is broken. The second cause is the mode switch. This tells the electronics what position the mechanism is in. If that goes wrong the electronics might think it is in eject mode when it's in playback, for example, with things going very wrongs as a result. All are fixable if you can get the parts!
May 02, 2016 | Toshiba Televison & Video
Why is the unit Magnavox vet/DVD recorder turning off when I insert the tape, and when power back on it ejects the tape.
There is something wrong with the mechanism, either the main drive mechanism, or the cassette holder part. Possible physical damage to the plastic parts. When the tape is inserted a device called a mode switch tells the electronics which position both mechanisms are in. If they go out of sequence, due to damage, or a faulty mode switch, the electronics shut the system down to prevent tape damage. When you power it up, the system thinks it is eject mode and chucks out the tape.
Apr 17, 2016 | Magnavox Televison & Video
My vw transporter van has lost its power
something went wrong on the electronics and put your automatic gear box on Safe Mode.Call your mechanic.Do not do anything as a scanner is required for a solution.
Aug 19, 2012 | Volkswagen Transporter Cars & Trucks
Canon MP560 paper jams and device reads error 5100. I have tried pulling out the crumpled paper, used the device's "clean paper roller" setting, with no luck. The paper still jams. Any...
This seems to be fault in the transport of the paper in the rollers. So if you have used any adhesive sticker printing, it is possible that some glue has got clogged into the rollers. If not there can be some jammed paper in the rollers or the mechanism.
So start this work only if you are mechanically able with the right tools.
Remove the covers to get access to the mechanism . Remove the motor drive assembly , the fitting of the motor to the mechanism. Once this is removed the rollers can be turned manually so that you will be able to feed a paper to see the progress of the movement while studying if there is any obstruction or damage to the paper.
There is a in-detect sensor, usually an opto-coupler , make sure this is not clogged or dirty as this IR detection feeds the signal to the processor for starting the motor drive feed.
Reassemble but make sure the rollers are aligned to be in equal gap to feed the paper without a side pull. Now you must print and see if the fault has changed. If not repeat the above work to confirm the area of obstruction
Nov 01, 2010 | Office Equipment & Supplies
Hi. My Jag head lights have started this blinking thing. As I am driving they will blink for no apparent reason. There doesn't appear to be anything going on otherwise. Any ideas where to start?
I had an S-Type too, I found this blinking when battery charge was low. So my opinion is something wrong with charging, you have to check battery contacts, measure battery voltage and check alternator. A possible case, contact problem at ECU. THe ECU under the house of pollen filter at engine end. You need some car mechanic ambition to remove the house of pollen filter and to clean ECU connectors with contact cleaner spray.
Of course this is just my experience, no guarantee, this works at you.
Aug 21, 2010 | 2000 Jaguar S-Type
My Sentinel CCTV monitor will not come on. It
It seems that something is wrong with the dvr. Maybe transport damage. You need to get it checked by a professional.
If you own website, add live support almost free
Real security guard to watch your cctv for $1/day
Apr 05, 2010 | Home Security
Tomtom 930 does not find Iphone 3g bluetooth for connection.
The following has worked for me FLAWLESSLY :
1) Remove any old "pairing information" that you may have both on the iPhone and on the TomTom - both should be "clean" not knowing about each other..
2) Put iPhone into airplane mode.
3) Go to settings, and turn on Bluetooth
4) Do the regular "search for bluetooth device" and pair the two
5) Turn off airplane mode
After I did this, I have never had a problem with iPhone 3GS / Tomtom - they find each other now every time, and all is happy..
Mar 14, 2009 | Tomtom GO 930 GPS Receiver
I have a Canon i860 printer. The color printing is coming out wrong... full of bands of color and no blue at all. Are the heads dirty? How to clean? Thanks.
Before you do something which could potentially damage the machine. Use the printer software to do a nozzle test, make sure you have the correct paper settings, and make sure that you have color management enabled in the driver properties. If you have exhausted all other possibilities carefully clean the docking pads as some leeching across colors has always been apparent even from the first Canons.
Dec 09, 2008 | Office Equipment & Supplies
My earphone plugin
Sounds like your stereo jack got damaged. Mine has the same problem. Possible to fix......worth it?
Dec 05, 2008 | Philips GOGEAR SA6045 MP3 Player
well you can contact them and ask about it, maybe the would have a simple solution to it, or possibly repairs, don't know about the price but surely over the 20usd.
you could also try contacting the seller of the product if they would ship it overseas, I've ordered a few things from over there shipped over just fine to Finland.
Jul 09, 2008 | Colorado Memory Systems Colorado Jumbo250...
Open Questions:
See all Colorado Memory Systems Colorado Jumbo250 250mb Questions
Computers & Internet Logo
65 people viewed this question
Top Colorado Memory Systems Computers & Internet Experts
David Payne
David Payne
Are you a Colorado Memory Systems Computer and Internet Expert? Answer questions, earn points and help others
