My Magnavox TV VCR/DVD set has problems. #1 you turn it on & it will automaticallly shut off whether using TV button or remote. This does not happen evey single time but most times especially if you have put in a VCR tape/has tape already in the machine. #2 Also the VCR will not FF or REW when the TV has a tape in it only when it is in play mode will it FF or REW. #3 The set will automactically eject the VCR tape time after time when you are trying to watch a tape. Each time that it ejects it makes a horrific noise. This set is only 3 years old. I hope that you can help us! Furstrated owner in Iowa!
    Top Expert:
  • Televison & ... Master
  • 74,251 Answers
Hello
Your Magnavox Combo has mechanical problems in its VCR mechanism, which jams or not run properly. If the Casett tape doesn't run properly, the take up reel sensor inide it will sense this situation ans "Stop", or "End", and will automatically ejects it. If the mcchanism has some trouble with it, there are sensors to detect the trouble. and will stop it from preventing further damages ot the casette tape. It may be due to any motor trouble, shorted or opened low voltage regulators, ans so on. As it is a multi combo, there is no one sentence answer about the detection of this problem. We have to detach section by section to detect which section causes the overload to power supply. The wiring and schematics will be very complicated that you must have well experienced to do this job, otherwise total failure will be the result.
If you have enough awareness in electronics, and have some practical experience, and knoledge in this case, inform me, I'll assist you in this case. Soemtimes we are now thousands of miles apart. There will be a limitation for an online asistance you know.
Anyway if you have confidence and have a concept of soldering, and have a very good quality Digital Multimeter; inform me by Fixya. I'm ready to assit you. OK.
Posted on Jan 03, 2011
I need code(s) for my DVD Video, Model #: NB093 remote control to program my Philips DVD Player/VCR, Model #: DVP3345V/17. Can you please help me? I would greatly appreciate it. Here is a picture of it.
http://remotecodelist.com/remotes/magnavox/magnavox.htm lists the code for your device as possibly being 1000, 1001, 1002, 1003, 1004, or 1005. Of course, you also have the option of using the remote controller's "Code Search" button. 25300580-iv4burzhkawezvl2jbah1xae-2-0.jpg With Codes:
Turn on the DVD/VCR unit directly. Continue to depress the remote controller's "Code Search" button for about ten seconds, release, & the light on the remote controller should stay on. Enter the four-digit code (1000, 1001, 1002, 1003, 1004, or 1005) for the DVD/VCR unit. The remote controller's light should go off. Press the remote controller's power button, & when the DVD/VCR unit turns off, then you will know that the remote controller has been correctly programmed.
Without Codes:
With the DVD/VCR unit on, continue to depress the remote controller's "Code Search" button for about ten seconds, release, & the light on the remote controller should stay on. Continue to tap the remote controller's UP or DOWN channel button ONLY UNTIL the DVD/VCR unit responds. Then, press the power button on the remote controller once the channel has changed. If the DVD/VCR unit shuts off, then press the power button again to turn it back on. If the DVD/VCR unit turns on, then the remote controller has been correctly programmed. Otherwise, repeat this whole process until the remote controller is correctly programmed.
Nov 29, 2014 | Televison & Video
MAGNAVOX UNIVERSAL REMOTE
hi have you tried scanning all codes with the remote untill it picks up the correct signal if you have the manual it will tell you how to do this if its possible it will work after searching the codes.
Also what model remote and what make cable box
Mar 29, 2008 | Philips Magnavox Learning Universal Remote
I have been sturggle with remote rca to my tv sharp how i can do that ?
HI,
Direct Code Entry:
Find the code your device.
1. Press and hold "CODE SEARCH".
2. Press and release the TV, VCR or Cable button. If programming an AUX position, press and release AUX first and then press the device type to be programmed.
3. Enter the 3-digit code number.
4. Release "CODE SEARCH".
5. With the device on, press another button to test (volume control/power button).If it does not work, repeat steps 1 to 5 with other codes which you have.
follow the below steps to set remote without codes
Code Search:
1. Turn on the device you wish to control.
2. Press and hold "CODE SEARCH".
3. Press and release the TV, VCR or Cable button. If programming an AUX position, press and release AUX first and then press the device type to be programmed.
5. Press ON/OFF repeatedly until the device turns off.
6. When the device shuts off press and release ENTER.
7. Try using the remote. If it does not function repeat steps 1 through 6
To Get The Code Please Go To Below Website:
http://www.rcaaccessories.com/remotefinder/
You need to select the following information from the drop down list
1.Model of the remote
2.Type of device to which you want to program(TV/DVD/VCR)
Thank you
Jan 25, 2011 | RCA RCRN04GR Remote Control
I use URC-3021 w/ Magnavox TV. I bought a
It sounds like you would like to re-assign one of the function buttons on the remote to control a different device. If you would like to program the CBL/SAT button to control a DVD player, here are the steps:
  1. On the remote, press and hold SET until the LED blinks twice, then release SET.
  2. Enter 9 9 2. The LED will blink twice.
  3. Press DVD/VCR once.
  4. Press CBL/SAT once. The LED will blink twice. The CBL/SAT key is now ready to be set up to control your DVD player.
To setup the CBL/SAT button to control your Magnavox DVD player, follow these steps:
  1. Turn on your DVD.
  2. On the remote, press the CBL key once.
  3. Press and hold SET until the LED blinks twice, then release SET.
  4. Enter the first four-digit code from the following list: 0503, 0675. The LED will blink twice. If it does not blink twice, go back to step 2 and try the same code again.
  5. Aim the remote at the DVD and press POWER. The device should turn off. If it does not turn off, repeat steps 2 through 5 with the next code in the list.
I hope that helps.
Dec 09, 2009 | One For All URC-3021 Remote Control
How do i program my hamton bay universal remote to wor with my magnavox vcr/dvd recorder combo unit
Magnavox VCR codes are 007, 011, 028, 032, 059
Magnavox DVD code is listed as 001 only.
Manually turn on the device. Press and hold the SET button then press and release the VCR button, then release the SET button. Enter a three digit code then press power. If it does not turn off the device, try the next one.
You might also try the 'code search' if none of the above codes work. Press and hold SET then VCR and release both. Then Press and release the SET button again. The indicator light should begin blinking. Press and release the POWER button until your device turns off. You may have to go through up to 200 different codes until it turns off. Once the device does turn off, press the VCR button again to store the code.
Jun 19, 2009 | Universal Remote Control Hampton Bay...
VCR WON'T RECORD
you may have the outputs hooked up correctly however you may need to set the inputs to the selected type of cable you are using. S video 1 cable or video input witch is an rca adapter yellow in color. you will find these setting in the "setup section" on the remote set up button will get you there and then input or source.
Dec 04, 2008 | Philips Magnavox MWR10D6 DVD Recorder
Magnavox TV/VCR COMBO
Im thinking that maybe you a have a timer recording set. The whole unit wont function at all if you turn it on via power button (remote or unit). There should be a button at the top of the remote called 'timer set' pressing this will disable that mode and allow complete use of everything. but make sure u press timer set again when powering down, otherwise simply turning off the machine will leave the timer recording disabled.
Oct 17, 2008 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Setting up DVD/VCR
Depends how you have connected to the TV.
You will need to set your TV to the relevant socket you have connected the DVD/VCR into.
S-Video, Component , composite etc
These will be EXT 1 , EXT 2 or AV 1, AV 2 etc.
Feb 18, 2008 | Philips Magnavox DVD/VCR Dual Player
Need codes for the RC450 remote
took me awhile but I figured it out
ok
Put your TV/DVD/VCR on
hold in what you want to program TV/DVD/VCR BUTTON
(you dont need codes or anything)
then while holding in what you want to program (TV, DVD, VCR) hold in ON/OFF
both at the same time
when the light comes on and stays on
keep hitting ON/OFF BUTTON
do it slow, when the TV turns off hit the STOP button at the bottom
then hit the button you just programed
then hit the ON/OFF button, the TV/DVD/VCR will turn on
if it doesnt work, repeat. make sure you hit the stop button when the TV/DVD/VCR shuts off, if you hit it an extra time while the TV/DVD/VCR is off it wont work.
took me about 30 mins to figure it out.
I lost my codes too, but I wanted to help all you other people too.. now since I helped you.. check my band out... www.myspace.com/jumpercablenj
Nov 13, 2007 | RCA RCR450 Remote Control
Televison & Video Logo
46 people viewed this question
Top Televison & Video Experts
Electro Med Services...
