Question about Sentry 880CD Headphones
How do i make the right headphone work - Sentry 880CD Headphones
Right channel not working
An idication of a faulty headphone socket if the headphones being inseted cuts off the speakers. Otherwise a faulty switch that switches the speakers off.
Jan 27, 2013 | Cambridge Audio Azur 640A Amplifier
I got these headphones and they were working perfectly but one day the right side just stopped working. even after plugging it into my ipod and laptop the right side still doesnt work. what should i do?
The wire carrying the signal to the right side has probably been damaged. You have to be careful with the wires and should not wind them up too tightly. Try seeing if you can get a sound by moving the wire close to the point where it enters the right earpiece. If you can, then it may be possible to resolder the broken connection to fix them otherwise, I'm afraid you'll have to get a new pair of headphones
May 17, 2011 | Sony MDR-RF970RK Headphones
Have Philips wireless headphones SBC HC 8445. Batteries appear to be charging and there is power. Works on left side but no sound on right side.
The speaker on the right side of the headphone is dead and shorted or might have lose wiring requiring repairing like resoldering or just tapping on the right on the right side it headphone might work.
Mar 21, 2011 | Televison & Video
My jvc foldable headphones the right side is not
you have to take off wire casing near the split and resauder
May 11, 2010 | Audio Players & Recorders
The Right side does not work.
i just bought the turtle beach x1's and had the same problem only it was the left side not the right and i was pushing the green audio connector cable to close together with the av componet connector and just slightly removed the audio cable from the av connector cable basically just slightly remove the headphones from the connection port on whatever you are connecting it to if that dosent work then most likely you have a lose connetion port on your device and will need to replace it or replace the device alltogether if the port can not be replaced.
Jan 30, 2010 | Skull Candy Lowrider Headphones
Right headphone broken
hi there, the right headphone is broken. Replace the headphones and you should be set.
Jan 26, 2010 | Skull Candy Lowrider Headphones
Sound only in right ear
Its either the jack or the connector in the device is the problem. You can try connecting other headphone, if this works, then the problem lies on the jack of the old headphone.
May 03, 2009 | SanDisk Sansa e200 MP3 Player
My Logitech headphones mic won´t work with windows xp. Can hear, don´t hear me.
Your headphone mic is all right. The problem is with the sound driver you are using. Many a time the headphone jack are not properly connected so it may be another issue for not working of your headphone. Your operating system is all right check out the sound driver setting from the control panel.
Good Luck
Mar 02, 2009 | Logitech (980361-0403) Headphones
Right speaker malfunction
try blowing the headphone jack hole. One hard puff should do the job
Nov 01, 2007 | Logitech X-230 Computer Speakers
Sentry 880CD Headphones Logo
Top Sentry Audio Players & Recorders Experts
 Grubhead
Grubhead
Tom Chichester
Are you a Sentry Audio Player and Recorder Expert? Answer questions, earn points and help others
