Question about LaCie Hard Disk 1TB Desktop with Hi-Speed USB2.0 USB 2.0 Hard Drive
I got this hard drive about 5 months ago and it has been working great until a few days ago, I try to plug it in and the blue light turns on and it squeaks a few times and the light stays on but the computer 10.5.8 Macbook is not recognizing it. I have been trying many different cords but it is not working. The External hard drive does not move from it's spot on the desk. I have been traveling this week but i keep it in a wooden box lined with cotton and kept the drive in a suitcase only containing clothes. I've broken drives before and I have made extra efforts to take care of this one, is this problem one that can be fixed?
  • 98 Answers
Possibly yes, but you would have to send it back to it's manufacturer.
If you don't want to do that, but want to rescue your data, you could remove the casing. Inside it there is an actual HD that can be connected to any desktop.
But to be honest, i believe that you should send it to the manufacturer.
Posted on Jan 02, 2011
My black calvary external hard drive won't turn on.
Would be great if the next time you also place the model number, because Cavalry makes dozens of different drives.
When the bleu light does not go on, you have to assume the drive is not getting power.
If the drive has only one cable, (small drives like 2,5 inch most of the time only have one cable) it could be the USB cable is defect and can't give through the 5 Volt coming from the computer USB connector. It also could be the 5 Volt supposed to be in the computer has gone.
If you have to connect an external power supply, with a small cable to the drive, I would check the power supply. A 5 Volt 2 A supply, with the round plug can't be that expensive.
If both don't work, it also could be inside the housing of the drive is something defect.
If you need to have the data on the drive, you always could but an universal USB connection for hard drives. I have one for IDE and E-SATA, in the box came a set power cables and a power supply, but that one was almost 50 dollar. There are cheaper ones on the net.
Be aware drives don't live forever and make sure you always have at least two backups. (that is more than one origin; and one back up)
Jun 16, 2014 | Cavalry Storage Computers & Internet
I bought it about 5 months ago only used it few times to store some data other and that was it, i pluged it few days ago and it was working fine and i left it connected to my laptop on idle and when l
do you mean the HDD doesn't get recognized ? if yes den as per your info you mentioned that the hdd is 5 months old and Sony or any other manufacture have a warranty for them so you can easily ask them for a repair
But that's the hardest part .. download parttion mini home wizard named software and install it and connect your hdd and open the software and look that does the hdd gets recognized in it ? if yes then check its size and partition type and if its all ok then try to see if it works and also try it on another pc or Go for the first part
Mar 26, 2014 | Sony HDE1/B 1TB External USB Hard Drive...
Hard clunk when switching from reverse to drive?
I would not drive at all, if I thought any possible transmission
issue existed
Any other problem with a check light, you could go 5 miles to work,
for a few days, until they take your car in.
May 17, 2012 | 2010 Toyota Corolla
1996 chevy 3500 7.4 vortec. the ecm fuse blows at the turn of a key
One of the power wire going from your ecm to a sensor or solenoid is shorting to ground. Get a wiring diagram and an ohm meter. disconnect the battery and start checking each wire measuring from the wire to ground. as you wiggle you will see the meter show 0 ohms when it is shorted. These are the hardest and most time consuming kind of electrical problems .good luck
Nov 21, 2011 | Cars & Trucks
Computer is not recognizing my external hard drive
If the light won't blink, there could be problem with the power source. Do scanning hardisk for errors manually ( take off the hardisk from the case, assemble it on other PC Desktop)
May 06, 2010 | IO Magic Corporation GigaBank (I250HD35)...
My harddrive just stopped working one day...I didnt drop it or anything. Once it is plugged in the blue light comes on and it whirrs for a few seconds but then nothing...it goes quiet and nothing comes up...
this happens when the card of the hard disk becomes faulty check for the warranty status of your hard drive generally hard disk have 2 to 5 years of warranty it will be changed
Oct 08, 2009 | SimpleTech 250GB USB2.0 7200 RPM External...
My Acomdata (HD250 UE5-72) external hard drive isn't working
The hard drive is probably faulty, how is the drive? if it uses a external powersupply the power adapter may have worn out and is not providing enough power for the drive to function.
Do you hear clicking from the drive?
A possible solution would be to remove the hard drive from the case, note that it may void your warranty if its still on warranty. And connect it to your computer directly to see if it functions.
Jan 14, 2009 | Acomdata (HD320UFAPE5-72) (HD320UFAPE572)...
TrekStor 160gb Harddrive wont turn on
Try to turn it off and quickly turn it on again in a split second.
And buy a second hard disk just in case.
Sep 28, 2008 | Trekstor (21202) 160 GB USB 2.0 Hard Drive
My iriver shit itself
once your iriver is plugged into the charger and then you hold the power button for a few seconds (if dosn't work, try and try again)
Jan 21, 2008 | iRiver E10 Digital Media Player
LaCie Hard Disk 1TB Desktop with Hi-Speed USB2.0 USB 2.0 Hard Drive Logo
107 people viewed this question
Top LaCie Computers & Internet Experts
Raj Patel
Tony
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
