Question about HP 640 Inkjet Fax Machine
Can this fax machine be used as a printer? - HP 640 Inkjet Fax Machine
  • 42 Answers
Lexmark is one of the industry leaders in printers. Over time with use your printer may require maintenance and you will need to replace the ink cartridges, print heads and ribbons in your printer. If your printer is displaying the 935 printhead error here are some things to look into.
you cannot use fax machine as a printer because it is different specific programmed.
please rate me by telling how helpfull it is.
Posted on Jan 03, 2011
When receiving fax, it won't print
make sure the property settings for the fax are not on the Microsoft printer make sure it is set to the local usb printer
Jan 28, 2014 | Brother MFC-J625DW Wireless All-in-One...
How do i fax with this unit
Unlike many all-in-ones, this model can be used as a standalone fax machine. Just connect the printer to a phone line and set up the usual basic information (your name and the phone number that will print on the receiver's fax machine, etc.). After that it's like using any other fax machine. This page at Canon has links to helpful information about faxing.
Aug 03, 2011 | Canon PIXMA MX340 Wireless Office...
How to receive fax documents
You cannot receive fax using this printer, because this printer doesn't support fax sending/receiving. Only fax supported printers can receive fax documents. You will know if a printer is fax support if you see a Fax button there or if you can see a numpad buttons where you can dial numbers.
These are the photo examples of fax printers
Hope my solution helps. Thanks for using Fixya!
Jul 11, 2011 | Canon PIXMA iP4000 InkJet Photo Printer
I am using Samsung SCX-4521F machine in which I am able to receive fax messages but unable to send fax using this machine. what should I do to get the problem resolved and to use the machine for both...
Please to assure that the cable from your wall connection go into the printer first and then from there with another cable to your phone. Second set up the printer as fax by using the original soft ware cd or download the programm from samsung webside. Make sure the phone and the fax are compatibile!
Apr 18, 2011 | Samsung SCX 4521F All-In-One Laser Printer
Hello can this fax print out from the computer
the only way that u can use the fax machine as a printer is if it has either a parrallel port, or usb port that u can connect from the fax machine to the computer.
Apr 14, 2010 | Brother IntelliFAX 560 Plain Paper Fax
My HP M1319f fax machine is having trouble sending faxes only to certain phone numbers. Is this a problem with the actual machine, or the phone line?
I have purchased the HP M1319f multipurpose machine 1 year ago and expected it to print as well as fax. Sadly to say 1 year later, the printing works as expected but the fax never worked consistently for me. The solution I found was to buy a used fax machine and only use the HP M1319f as a printer.
The problem I've read about this problem on HP forums was the fax speed of the M1319f. It is locked to 28.8k which means it is only able to communicate with some fax machines. Older machines that doesn't support 28.8 will get errors and the fax will fail. This is definately an HP problem but considering I purchased this 1 year ago, this problem will never be fixed. Avoid this printer at all costs if your considering to use the fax machine.
Oct 19, 2009 | HP Laserjet M1319F Laser Multifunction...
Peoplel are sending me very imp. faxes and idk how to recive it..
If your printer has FAX capabilities. Good way to tell is if you have a phone number pad on the front of your printer.
You must have this connected to a phone line for it to receive a fax.
Setup the fax application through your installation CD that came with the Printer/fax machine. Often you set the fax machine to pick up after so many rings. This allows you to leave the printer/fax machine on and gives you time to answer BEFORE the fax machine does. If uncle Bob or Aunt Susie should call to say Hi!
Basically what is happening:
You turn on the Printer/Fax machine it sits idle waiting for a phone call.
Someone now sends you a fax using your phone number.
YOUR printer/fax machine is sitting there listening for the phone to ring.
Lets say you have your printer/fax machine setup to answer after 5 rings.
After 5 rings, your Printer/fax machine will pick up and listen for signal tones from the the other machine. If it gets these, it will "handshake" and send a confirmation fax tone. Then the data will be transferred and printed out on your machine or held in a fax program for you to print or save later.
It is critical that you do not pickup the phone too early or the two fax machines trying to communicate will fail.
If you do this, you will hear an awful squeal and a serious of tones.
You can often hang up quickly and the two machines will transmit again the handshake signals and resume business as usual.
Short answer:
Two fax modems are talking to each other over your phone line to transmit data.
and hope this is helpful.
Oct 04, 2009 | Canon MX310 Office All-In-One Printer
Need to download installation disk
No can do. It's a stand alone fax machine. If it has a printer port, that's only for using the fax machine as a printer. (I don't think it does)
Sep 10, 2008 | HP 920 Plain Paper Fax
Printer busy
sounds like the faxes are stuck in memory
look in the Troubleshooting section of the manual
http://www.retrevo.com/support/Brother-FAX-4100-Fax-Machines-manual/id/386bh847/t/2/
Jul 17, 2008 | Brother IntelliFAX 4100 Laser Fax
Fax
i need simple instructions to operate the receiving and sending of fax information on this lexmark 4270 fax machine .
Jan 16, 2008 | Lexmark X4270 All-In-One InkJet Printer
Open Questions:
See all HP 640 Inkjet Fax Machine Questions
HP 640 Inkjet Fax Machine Logo
80 people viewed this question
Seeker5211
Seeker5211
