Question about Sanyo DP42746 42 in. Plasma Television
No picture or sound. The led on back of set blinks 12 times which corresponds to # 12 diag. D12V on board next to blinking led. Sanyo DP42746
  • Sanyo Master
  • 6,993 Answers
The issue you describe is consistent with a power supply board issue. This is the board where the AC goes to. This problem may have occurred as a result of irregular power supply, or excess power supply or power surge.
The TV is receiving current but cannot circulate or transfer the current to other necessary part of the TV because of the defective power supply board.
I do not think it needs replacement, rather some defective capacitors are causing this issue.
Open unit up and take a look at the power supply board.You will probably see one or more electrolytic filter capacitors that are bulged up in the top-not perfectly flat like the others.
The value of these capacitors will be different, most likely they will be somewhere around-820 to 2200uF/25 V( or /10V sometimes)
You can replace them with same values but I would recommend the voltage rating to be higher(like 35V for an original 25V) for reliability purposes.
What happens is,these bulged top capacitors will cause a low and unfiltered DC voltage=main board will malfunction(the relay will keep clicking until the caps are holding enough charge to bring the voltage up over a threshold point).
You can buy these capacitors at any Fry's or Radioshack store or you can order them online at vendors like "mcmelectronics.com"(look for electrolytic capacitors).
After replacing these capacitor(capacitors) most likely the normal operation will be restored.
Note: There may be also some other causes for this symptom ,like a defective T con board ,or main board,but the bulged top capacitors are the most common cause for this issue.
If you don't know about TV repairers, take the TV to the nearest repairman to fix the fault for you. Also, note that TV stores a lot of current, so wait a while before opening the TV back cover.
I hope this helps.
Posted on Jan 03, 2011
I have a sanyo 42inch plasma tv that is giving me the error code D12V what does the code mean? The model number on the tv is dp42746. Thank you for your help.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/ Error code details to many popular brand TVs are given.
Apr 20, 2015 | Sanyo DP42746 42 in. Plasma Television
Sanyo plasma tv led 8001 blinking 12 times, indicates d12v code
Check and replace the damaged component/s at its main board. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Oct 20, 2014 | Sanyo DP42746 42 in. Plasma Television
Sanyo DP42746 LED blinks 12 times
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power led, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating, to many popular brand TVs and other devices. Viewing it in "Mosaic" will make surf easy.
Blinking codes details to many popular brand TVs are given.
If you fail to detect the fault, it will be best to contact the authorized service center for Sanyo, in this case.
Gopakumar Gopalan Google
Mar 11, 2014 | Sanyo DP42746 42 in. Plasma Television
No picture or sound. Power board led flashing in sequence of 12. Says D12V on legend.
For what it's worth, you can download the official Sanyo repair manual for this TV (DP42746) at http://www.eserviceinfo.com/downloadsm/43343/sanyo_dp42746.html. It might give you some insight you need especially directing you towards the D12V. Hope this helps
Jan 03, 2011 | Sanyo DP42746 42 in. Plasma Television
Green light comes on no picmor sound
Hello Afox5, hi, make sure that there are no user controls or setup that are out of order. as a backgrounder, TV of this type mostly has two boards, power supply and main board. On the power supply board, this has two section, primary that deals with mains voltage and secondary that deals with TV supply current requirements, if you see green light mean that power on the secondary section of the power supply board of your TV is working, but it does not mean that the power supplied to the main board is correct, the supplied current produced by the power supply section to the main board that controls sound and picture needs to be checked, so voltages are needed to be checked and loose wiring, or screws needs tightening, are a common trouble, but some go to extremes like replacement of any boards.
Aug 31, 2010 | Sanyo DP42746 42 in. Plasma Television
The green led blinks 12times. local repair guy guy said somthing about taking out the y.
Power LED blinking it about 90% power supply board is dead.The other 5% are both boards some time are dead.The power supply board and the Tuner siginal board is dead.Replaced the power supply board it ur best bet to get power back.After power is back should get picture too.Not than the Tuner board also need it replaced.Tries Websites Shopjimmy.com,Ebay.com for boards parts.
Feb 16, 2010 | Sanyo DP42746 42 in. Plasma Television
Sanyo dp42746 low volt power problems
The power supply is failing, or there is another circuit area that is pulling too much current, and the supply is going in to protect mode.
This would require proper troubleshooting by an experienced tech. If the problem is very involved, or the tech is not familiar with the set, he will require the service manuals and service information.
Jerry G.
Apr 25, 2008 | Sanyo DP42746 42 in. Plasma Television
Sanyo DP42746 42 in. Plasma No Video
to test all y sub boards remove the main power connection to the y main and turn the tv on if it powers on one of those boards are bad.. remove both sub boards. and plug in the y main. if it powers on then that board is good either, put your multimeter on 2k omh and test the upper ysub boards black connector, the top 2 pins with negative to the 5th pin positive. you should read 500-1k ohm if its way under 100 there is a short.
the bottom ysub board place the multimeters black probe on the bottom 2 pins of the black power conection and the red on the 4th pin.. results are the same.
low resistance means theres a short in the board.
Apr 12, 2008 | Sanyo DP42746 42 in. Plasma Television
Sanyo DP42746 42 in. Plasma Television Logo
304 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
