The remote or power switch will not turn the TV on, does it have a reset switch
  • 66 Answers
Most likelly you have had a power surge through your house and it blew the fuse inside the tv. If you take the back panel off the fuse will be by the power cord becarefull and pop out the old fuse if its burnt or the metal wire is missing on the inside then you just need to replace the fuse with the same amps and voltage as the old fuse. If you read the motherboard where the fuse goes it will tell you what type of fuse it calls for.And when tvs work fine one dau and then the next wont even make a sound when hitting the power button 9 out of 10 times the fuse is the issue. GOOD LUCK too you and HOPE this helps!!! Good day!!
Posted on Jan 02, 2011
How do I reset Sony Wega KDF-60XS955
SELECTED PRODUCT: KDF60XS955 (change your search)
How to reset the television to the original factory settings.
Article ID: 42994 ' Last Updated: 08/15/2015
WARNING: FOR LCD AND PLASMA TELEVISIONS: This procedure will reset the video calibration settings of the TV. If you paid to have your TV screen specially calibrated, you may want to first try performing a power reset instead. Otherwise, any special calibration settings will be lost.
A Video Tutorial is available with information about this topic.IMPORTANT:
  • The supplied remote control is necessary to perform this procedure. Then be sure to point the remote control towards the front and center of the television.
  • If lights on the front of the TV are blinking or flashing, follow the steps in this answer.
  1. Unplug the TV power cord from the electrical outlet.
  2. Allow the TV to remain without power for one minute.
  3. Plug the power cord back into the electrical outlet.NOTE: The TV should turn on automatically. If it does not, turn it on.
  4. Wait approximately 40 seconds for the TV to completely start up.
  5. On the TV remote control, press and hold the UP ARROW button.
  6. While holding the UP ARROW button, press and release the POWER button on the TV set. NOTES:
    • The TV may turn off and then back on.
    • The button may be on the front, top or side of the TV. If your TV has an Energy Saving switch, be sure to press the POWER button rather than the Energy Saving switch.
  7. Release the UP ARROW button.NOTE: The initial setup screen displays if the above procedures were performed correctly.
  8. Follow the on-screen instructions to complete the initial setup.
IMPORTANT: If the reset did not complete successfully, disconnect all devices from the TV and turn off or disable the network connection the repeat these steps.
Sep 24, 2015 | Sony Televison & Video
I have a Sharp flat panel model LC-20SH4U. The units power LED light is red. No effect (sound or picture) when remote or on/off switch is activated. The LED light slightly blinks.
Resetting the TV
If the buttons on the remote AND the buttons on the TV case do not work (channels do not change and you cannot open or navigate the menu), the TV has stopped responding. Reset the TV as follows:
NOTE:
Some TVs have a reset button. If available and accessible, try using the reset buttons before using the steps below. Using the reset buttons can save time.
1. Unplug the TV power cord from the power outlet.
2. Unplug any connected devices (DVD, Set-top boxes, etc...)
3. Press and hold the TV power button for five seconds.
4. Plug the TV power cord back into the power outlet and turn on the TV.
5. Open the on-screen menu to confirm that the TV is responding again.
6. Turn off the TV and reconnect the devices.
7. Turn on the TV.
Hope this may help;
Regards,
VOTIT
Aug 09, 2008 | Televison & Video
Moved from New Zealand to UK. Is it possible to reset TV to start up afresh and choose UK as region?
SELECTED PRODUCT: KDL40EX720 (change your search)
Article ID: 42994 ' Last Updated: 03/19/2015
May 03, 2015 | Sony 40 BRAVIA KDL-40EX720 Full HD LED 3D...
When pressing the remote's 'on' button tv won't come on
does it power on using the power switch on the tv itself instead of the remote? if same thing happens when pressing the power on switch on the tv directly, try to test it on another power outlet. if it is connected through a surge protector or avr, see if connecting it directly through the outlet works.
try to also check if the power on switch of the tv is somehow stuck which may cause it to try to cycle on and off and same thing on the remotes on/off button.
now if this is specific to the use of a remote, replacing the battery might help.
Mar 09, 2014 | LG 60PK550 TV
Reen turned wite with power only v8.03.6
From the remote select menu and reset the settings to factory default. It might become alright. Else, switch off TV manually, switch off power, remove plug and retry after 48 hours.
Aug 01, 2012 | LG 42LE5400 42 in. LCD TV
Remote wont turn tv on
If your remote serves multiple units, make sure it's in the right mode for your TV. (not dvr, dvd player, tuner, other source...). If the TV will not turn on manually (with the power switch on the TV), then make sure it's plugged in and there is power at the plug (try a different power source). If your remote has been out of battery power, sometimes it needs to be reset / reloaded with the correct code for your TV. Check your remote and / or your TV manual for the procedure.
Apr 09, 2012 | Car Audio & Video
Panasonic PV-DR2714 will not turn on and i lost the remote
Hello Bobby
You haven't given enough details about the fault to your Combo. What do you mean my 'power button has coninuity on board'. I assumes that you get power LED at the front of your device lights up when you switch ON the main power switch, and the unit refuses to power ON and work further. If so, just make a factory reset to this set as it will reset the memory IC. To reset the unit to its factory reset do the folloing. But to do this, the power LED on the front panel of the unit should light up. Otherwise, the fault will be to its power regulator section. To reset the unit to factory reset:
[1] Turn the Power ON.
[2] Hold down both PLAY/REPET and FF on the unit more than 5 seconds. The power will shut OFF. Please ignore "NO CASETTE" warning.
[3] Perform initial set up refering to its user manual. You can see instructions to initial setup at page [16] of the user manual to your device. OK.
Dec 07, 2011 | Panasonic PV-DR2714 27 in. TV/VCR/DVR...
I forgot parental control passcodep
Hello
Just reset your tv to factory settings. By doing this all the settings will be set to its orginal factory mode, and you have to reset all the settings including V-Chip settngs. To set it to factory settings do the following.
Switch off the TV wiith its front panel power ON-OFF switch and wait for about 5 minutes.
1 Press POWER to turn on the TV.
2 Hold down RESET on the remote control.
3 Press TV POWER on the TV. (The TV will turn itself off, then back
on.)
4 Release RESET.
OK.
Jan 12, 2011 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Insignia NS LBD32x-10a blue ray/dvd
Try power-cycling your TV (e.g. turn it off and unplug it for several minutes). If the TV then powers on, reset to factory defaults. If the problem persists, your TV will require repairs. Service can be obtained by calling 1-888-237-8289 in the U.S. or 1-866-237-8289 in Canada.
May 14, 2010 | Insignia IS-LCDTV32 32 in. Television
Brand new LG plasma stuck on test screens
Resetting the TV
NOTE:
7. Turn on the TV.
Hope it may help you;
Regards;
VOTIT
Jan 29, 2009 | Televison & Video
Televison & Video Logo
Top Televison & Video Experts
