Question about Sony VAIO PCV-RS310 PC Desktop
What video card comes with this computer? - Sony VAIO PCV-RS310 PC Desktop
  • 21 Answers
Hi According the Sony Support this PC was Shipped with Integrated Video.
Intel® 82845G/82865G Graphics Controller Driver
So according to them there is no video card in this its basic integrated video.
Download Link for Windows XP:-
This link is from Sony Support they haven't updated since 2003.
http://esupport.sony.com/US/perl/swu-download.pl?mdl=PCVRS310&upd_id=900&os_id=7
From Intel :- Last Updated 2005
http://downloadmirror.intel.com/9034/a08/win2k_xp14103.zip
Download driver info for Vista / Windows 7.
http://www.intel.com/support/graphics/sb/CS-030907.htm
Posted on Jan 02, 2011
  • 600 Answers
Intel® 845GV Integrated Graphics
64MB max. Dynamically Shared Graphics Memory
How do i get my asus model ul80j to switch from integrated graphics to nvidia
From my years of working with computers most of them only work with one video card at a time. If you have two video cards on the computer and if you have them both connected, a lot of computers get confused and can't handle that.
I've seen computers where there is a VGA Port (that normally comes with most computers) and the user goes out an purchases some heavy duty graphics video card and installs it. When they try use the VGA port, the computer refuses to switch to it as long as that other video card that they purchased is in the computer.
I've down countless of house calls to repair a computer where the purchased video card has gone bad and the customer thinks they are up the creek without a paddle until they get a new video card. Not so, I just remove the bad video card and plug into the vga video port that came with the computer.
Mar 30, 2012 | ASUS UL80JT-A2 Notebook
My Sony Vaio PCV J100 turns on but no nothing comes on the screen/monitor. I have checked the monitor but it works fine on other computers. What could be the problem?
If your monitor works fine on another computer then most possibly its your video card since you said nothing comes on. Usually if its the operating system you should see the computer info before it goes to a blank screen. If you have an add on video card try using the integrated video card or vise versa. You can also use a known good video card from another computer.
Jul 18, 2011 | Sony VAIO PCV-J100 PC Desktop
Hi I hada Saphire HD 2600 Pro video card installed on my computer and I smelt a burning smell and the fan on the video card stopped turning. I also had problems starting the computer but once removed from...
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line dust causes static to build up in a computer causing it to overheat any many other problems
are you sure its the video card and not the fan that is faulty you could remove the fan and install the video card again and see/smell if any smoke comes from the video card if it does you will need to buy a new one
hope this helps
Jun 05, 2011 | Sapphire RADEON HD2600Pro AGP Video Card
My computer has been working fine. I powered it on today and I had no signal on my Sceptre monitor and the tower was runnning. I unpluged all cables on the monitor for 30 sec. Plugged them back and...
shut your computer down for 1 minutes with the power unplugged, and try it again.
depending on if your savvy with computers or not depends on how indepth you want to be.
You need to determine if your video card has gone bad or not. try to remove everything attached to your motherboard, memory, hard drives, any cables, and see if your screen turns on. Take out any network cards, video cards, modems etc, that is inside your comptuer. So you need to have your motherboard, cpu and fan+ power supply connected, and try to turn it on. If the screen comes up,l something you removed is bad. If it does not, and your computer is running, bad video card.
Most computers today come with an integrated video card, meaning everything is 1 piece. You might be able to bypass your motherboards video card port, by installing a separate card. You can get these at any computer store.
Hope this helps!
May 02, 2011 | Computers & Internet
My biostar g31 -m7 te motherboard does not boot when i try to add a msi rx800 pcie video card,,sometimes i get a overclock fail message after i remove the card and reboot,,,how do i get this card to work...
Turn the computer off.
Remove the PCI-E video-card.
Boot the computer.
Press DEL to "enter BIOS setup".
Disable the "onboard video" adapter,
or set the highest video-priority to be the PCI-E slot.
Save settings, but do not "exit" from BIOS setup.
Install the PCI-E video-card.
Disconnect the video-cable from the onboard VGA-port,
and connect the video-cable to the new video-card.
Turn the computer on, and the video-output through the new video-card should be displayed on your monitor.
Nov 05, 2009 | Biostar G31-M7 TE Motherboard
When i install my win fast px6200 td video card and turn on the computer the video does not come up and the computer just beeps at me.
Did you check if the video card specs is can be able to use in Motherboard Specs. If your video card is not supported when power is ON mb give you beep sound.
Jul 27, 2009 | Leadtek WinFast PX6200 TD nVIDIA GeForce...
3 year old computer won't accept video card
No, it means the computer guy sold you the wrong card. Get your money back, go to a different, reputable shop.
Jul 01, 2009 | Computers & Internet
Clicking noises coming from monitor with hdmi cable attached to computer have no problems with other connections that came with monitor
Try getting a video card, if not look for a new monitor.
Reason i say get a video card your motherboard is probably working to hard depending on how old your pc is. When getting the video card it takes stress off the board when monitor is plugged into video card.
Apr 21, 2009 | Computers & Internet
Acer screen saver keeps coming on while I'm working
It appears that you are losing the video connection between your computer and the the monitor. Remove the conector from the video card and reconnect it again, make sure the connector is firmly secure. If the problem still persists you could have a faulty video card and it needs to be replaced.
If the video card is built in on the motherboard, you still need to purchase a new video card (buy a AGP graphics card), insert into the AGP slot of your computer, you may need to disable the onboard graphics card - go into the BIOS to do this, and you need to install the new graphics card driver.
Dec 28, 2008 | Acer AL1916W 19" LCD Monitor
No display (black) - power light is amber color
The video signal is not reaching your monitor, check the pins on the connector from the monitor to the computer, then check the video card:
Turn off your computer, unplg the power, and then take out the video card. Wait 5 minutes and then put the card back into the computer and turn it on. For onboard video; turn off the computer, unplug the power, then hold down the power button on the front for 5-10 seconds, then plug back in and turn on.
Make sure the video card is snug in the AGP/PCI slot. If this is built-in video, try borrowing a video card from another computer and install it in this one. If the borrowed card works, then replace you card. If video is built in, then you can disble the onboard video and use the new card without having to replace your motherboard.
Jul 14, 2008 | ViewSonic VX910 19" LCD Monitor
Sony VAIO PCV-RS310 PC Desktop Logo
229 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
