Question about Goodman GMS90703BXA Heater
I have a gms8 furnace that will not light. The error code that I get is 3 fast blinks
  • 1,772 Answers
Sorry to read about your problem, I hope this helps you out.
3 Blinks represent a problem with the combustion fan, pressure switch or a vent blockage.
if you have snow, it could be blocking the intake vent. if not that, most likely a defective preassure switch.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question's. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Posted on Jan 02, 2011
  • 1,420 Answers
Check air filter, condensate hoses and pump for blockage or not pumping, check the air intake pipe as well as the exhaust pipe for blockage.
My Xenon high efficiency furnace has a red blinking led light that blinks 4 times and my furnace will not light. What could be the problem?
Gas furnace fault or error codes for common furnaces - Gray ...
www.grayfurnaceman.com/-ifc-failure-codes.html
Each color will also flash a specific number of times to signify a specific error. ... 4 redcolored flashes may be signaling that the "high-limit" switch might be open. ... 3 green colored flashes on your furnace has the same meaning as 2 green colored flashes. ....If a system problem occurs, a blinking LED shows a fault code.Missing: xenon
7 Tips and Tricks to repair your Furnace DIY - YouTube
? 13:25
https://www.youtube.com/watch?v=rAtcvPqUsBA
Dec 18, 2012 - Uploaded by JRESHOW .
Flash sequence codes 1 through 11 are as follows: LED will turn "on" ... 4 RED FLASHES: This indicates that the main limit switchhas opened ... This no-light condition occurred 3 times (2 retries) during .... My furnace trane xe80 is only flashing once my manual says something about flame being locked out ...Missing: xenon ‎efficiency
Nov 21, 2015 | Heating & Cooling
I have a GMS8 furnace and it will not kick on.. No heat coming out of heater vents..
Is inducer motor running. If not change it. If it is then remove vacuum line from it and blow through the line on start up. If this works change the pressure switch. If not start jumping the sensors around the burner until you find the bad one
Jan 23, 2013 | Goodman GMS90703BXA Heater
On my Carrier Furnace the trouble shooting light has 3 fast blinks and 3 small blinks what does that mean?
Hi, this is a code telling you that something on the furnace has failed. You will have a chart with a list of codes and the amount of blinks fast and slow that will tell you what the problem is and what you can do to solve this. The chart may be glued to the panel, or on the control module it self. The code might be a 33. It might be a roll out switch has tripped and needs to be reset, or what ever, you will need to look for what it is saying. To reset when you find the problem, unplug power or shut off breaker, and turn back on in a minute or 2.Let me know the out come.
Shastalaker7
A/C, & Heating Contractor
Mar 30, 2011 | Heating & Cooling
Bryant furnace plus 90 led code is blinking once then 3 times fast. What does it mean?
these codes are on the inside panel of the front cover of the furnace. lift off and look inside.there should be a code explain chart on the panel by the light. this panel will need to be replace correctly for the furnace to work as there is a door switch.
Jan 31, 2011 | Heating & Cooling
Furnace faults out for water blockage in Coil front cover
I think the drain is restricted and not allowing the water to drain fast enough. As the inducer collects water it is normal for the vacuum to increase. Is there a vent on the condensate drain to break the vacuum? If not, add one by cutting in a tee on the drain line as it exits the furnace and put a 4or5" stand pipe above the tee. Is the unit displaying any blinking lights by viewing thru a small window? If so, remove the lower panel and look on the wiring diagram for an error code to give you a starting point where to look. If you are getting a 3 blink error code, what I mentioned above may help. There should be no water leaking into the furnace, you need to figure where the water is coming from and need to stop it.
Dec 11, 2009 | Jandy Lite2 LJ125 Ceramic Gas Heater
Carrier Gas Furnace runs fine randomly stops blowing LEDs flash
That blinking light may be the diagnostic light. Count the blinks next time it fails. Carrier units will have two different blinks depicting the error code such as one blink followed by a pause than 3 blinks giving you an error code of 13. Then look at the wiring diagram, it will have an error code chart telling you where to start with your diagnosis. You already know that if you remove the cover it erases the error code, so look thru the small window first.
Nov 30, 2009 | Carrier XHB123D X/Y Series Heat/Cool Air...
Weatherking WRKA heat not working control board
U need to supply more info.There will be a sticker on the furnace likely in the lower Fan Compartment which will have a legend that explains each error code...ie: 3 blinks = Pressure switch etc....and u will need to provide more info on how the furnace is operating (whats it doing ) when it stops working or just prior to that
Oct 16, 2009 | Heating & Cooling
Glow light blinks once
One thing to try is to check the voltage coming to the furnace to see if it is correct. They do have separate furnaces for California because of the NOX compliable laws but the boards according to my vendor are all the same. Look on the new board to see if you see any of these numbers # PCBBF112S or 01030F00005S. If you do have one of these numbers it is the correct board. If not change the board or if voltage is wrong get that corrected and you should be fine
Jan 08, 2009 | Goodman GMS90703BXA Heater
Goodman GMS90904CXA Wont ignite, light blinks 3 times
Ok, you either have a inducer fan issue or a pressure switch issue or a plugged vent pipe. The inducer turns on to establish a draft for the exhaust. If it is not working you will get this error code. If the pressure switch does not sense pressure caused by the inducer, it will give this code. If either the intake pipe or exhaust pipe is blocked (even y just a little) it will give you the same error code. If the condensate hose or receptical is plugged, again it will give you this error code. Good Luck!
Oct 20, 2008 | Goodman GMS90703BXA Heater
Goodman GMS90703BXA Heater Logo
126 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Brandon Berry
Brandon Berry
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
