I have an old nvideo graphics card installed and I dont think its compatible with my computer. If I try using my USB drive or my printer the PC just freezes and I have to restart it, also there is no picture on my TV when I connect it. Shall I just get a newer card or is there a way to fix it?
    Scholar:
  • 135 Answers
Sir,
if u dont have a compatible graphix card, pl get a compatile one mentioned in ur manual
thakn u
Posted on Jul 09, 2008
USB 3.0 upgrade
You might need to upgrade you graphics card.
USB 3.0 is the newest connection port upgrade, arriving on the market in 2010.
The cable port connection is far superior to the USB 2.0 port, as it is able to transport up to 5 gbps (gigabits per second), instead of the previous version's max speed of 480 mbps (megabits per second).
However, most computers do not yet have this connection port installed, in which case you are left to upgrade your own computer system to the newer, faster connection method.
Turn off your computer, then disconnect all of the cables running into the computer.
Remove the Phillips screws from the back side of the computer.
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL.
http://www.kitchentablecomputers.com/static.php - rules
Only work inside the computer case when the power has been switched off and disconnected. Never open the power source.
Some of the below steps recommend removing physical parts within the computer.
While in the computer it is highly recommend that you be aware of ESD and its potential hazards.
This unlocks the case, allowing you access to the interior of the system.
Slide open the computer case.
Inside the middle is a longer circuit board.
This is the motherboard of the computer.
On the back side of the motherboard, facing the rear of the computer, are PCI card slots.
These allow you to install additional hardware onto the computer.
Slide the USB 3.0 connection port into one of the open PCI card slots, then push down the plastic levers along each side of the slot to lock the card into place.
Close the computer cover, then tighten the Phillips screws and reattach the cables.
Power on the computer, then insert the driver installation CD into the disc drive of the computer.
Once the installation wizard loads, follow the prompts of the wizard to install the drivers.
Restart the computer once finished and the USB 3.0 connection ports are ready for use.
http://www.pcworld.com/article/186566/usb_30_finally_arrives.html
Compatible graphics cards for Gateway Computers
Just as a processor handles data and a sound card outputs sound, your computer's video card is responsible for processing graphics and displaying them on your monitor.
The video cards manufacturers build into computers typically have enough power for the average user, but it may be necessary to upgrade your video card for better performance in games or graphics heavy applications.
Understand which types of video cards are compatible with your Gateway computer and learn about all your options.
PCI Express Graphics Cards
Many newer Gateway computers have a Peripheral Component Interconnect (PCI) Express slot in which you can add any PCI Express compatible video card.
These devices range from budget cards suitable for everyday tasks to high end models for gaming that cost hundreds of dollars.
AGP Graphics Cards
Older Gateway computers likely have an Accelerated Graphics Port (AGP) slot for AGP compatible cards.
The AGP bus provides sufficient bandwidth for high performance graphics cards, but the technology is no longer in use and AGP cards are difficult to find.
PCI Video Cards
Nearly all Gateway computers should have at least one PCI (Peripheral Component Interconnect) slot regardless of age.
This slot has enough bandwidth to support a wide range of peripherals like sound cards and modems, but is not suitable for high end video cards.
You can find a number of low and mid-range cards for PCI slot computers, however.
USB Video Cards
USB video cards are also compatible with Gateway computers sporting USB 2.0 or USB 3.0 ports.
These external cards sit outside the computer and allow you to connect additional monitors to your system.
They are a good option for people who feel uncomfortable working inside computers.
http://www.pcmag.com/article2/0,2817,2371083,00.asp
How to buy a video card
http://support.gateway.com/us/en/support/default.aspx
Gateway Support
Upgrade My Video Card on My Gateway Desktop
Gateway desktops are affordable computers, but they often do not come with top-of-the-line video cards.
Computer games may run slowly or not at all on your Gateway desktop.
One way to solve this problem is to upgrade the video card.
Video cards come in PCI, PCI-E and AGP interfaces, so you should be able to find a video card upgrade no matter what Gateway desktop model you have.
Click "Start" and right-click "My Computer."
Select "Properties" from the menu that appears.
Go to the "Hardware" tab.
Choose "Device Manager."
Click the plus sign next to the Device Manager entry listed "Display Adapters."
Find your graphics card in this list.
Double-click it.
Go to the "Drivers" tab and click "Uninstall Drivers."
Click "OK" to confirm the uninstallation process.
Shut your Gateway desktop down.
Pull the power cable out of the back.
Look at the back of the Gateway computer tower for screws on the right side panel or on top of the case for a cover release handle.
Nov 29, 2013 | Gateway DX4200-09 PC Desktop
I have windows 7 I uses creata cars gold in my old computer but now it won't run in windows what do I need to do
You can either upgrade to the latest Broderbund greeting card software. (See this site for a list of all the Broderbund Design and Print products: http://www.broderbund.com/c-6-design-print.aspx . You may not be able to import old projects into the new software.)
Creata Card Gold 8 was for Windows XP and older OS versions. I suspect the compatibility mode will not work but you can try it. Right click on the installer. Then choose Properties and then the Compatibility tab. Turn on Run program as Compatible with the appropriate OS. Then right click again on the installer and choose Run as Administrator. Then check if the program itself is running in the compatibility mode by right clicking again and choosing Properties. This is more likely to work if you have Windows 7 32-bit.
I do not know if this will work. A method that will work is to use a computer (virtual, dual-boot, or true second machine) with an older version of Windows installed. If you have Win7 Pro or Ultimate, you can create a virtual XP computer for free. Download and install Virtual PC and XP mode from Microsoft. Install them in order. Then install the XP software from your CD in the virtual computer and it will work. (Other virtual computer programs are Parallels and VMWare.) All of the other options will require a licensed version of the older Windows OS. Please note that the virtual computer can't share files directly with the main computer. You'll need to save files to external or removable media (optical media or flash drive, for example) to share them to print them. A printer can be installed to either the real or virtual machine at a given time. You will be asked to uninstall the printer if you try to install it in the virtual computer with it installed on the main computer.
I hope this helps.
Apr 04, 2011 | Broderbund American Greetings Creatacard...
What video card are compatable with SR1620NX ? The graphics card is not working right anymore and I need a compatable video card.
A PCI Express graphics card.
Doesn't matter if the PCI Express graphics card uses the PCI Express 2.0 technology, or the PCI Express 2.1 technology.
The PCI Express graphics card, will insert into the PCI Express x16 expansion slot on the motherboard.
Supporting data;
1) View of the motherboard in an illustration,
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00378480&tmp_task=prodinfoCategory&lc=en&dlc=en&cc=us&lang=en&product=1127351
Scroll down the page to view the motherboard illustration.
A) Looking at the illustration, view the BATT. (CMOS Battery)
To the left of the CMOS Battery (BATT) are three white PCI slots.
Above them is a longer expansion slot. This is the PCI Express x16 slot.
Above it is marked > PCIX16X1 (PCI x16 times 1 slot)
NOTE* When installing the PCI Express graphics card, lift up gently on the Lock 'handle'.
It looks as though you should push down on it, but you need to lift up on it instead.
Also go above the motherboard illustration, and read to the right of the heading > Internal Connectors
In the list you will see > One PCI Express x16 graphics slot.
WHEN installing a graphics card, ALWAYS install the software from the CD disk provided, First!
Computer on, and Windows running, insert the graphics card's Installation disk, (CD) into the optical drive tray.
Install the software by following the directions.
THEN shut the computer down normally, and unplug the computer from power.
OBSERVE Anti-Static Precautions.
Install the graphics card.
Close the computer case, and plug the monitor into the graphics card.
Turn the computer on.
When you install a device (Such as a graphics card for example), Windows will try to find compatible drivers.
IF, THE driver is not installed First, Windows will match up one of it's thousands of generic drivers.
This = No.
You want THE driver installed first, so that Windows will find it, and Not try to match on of it's generic drivers.
NOTE 2*
It DOESN'T MATTER what graphics ram memory the graphics card has.
The graphics card's Processor and Ram Memory operates independent of the system resources.
Example:
The computer uses DDR Sdram ram memory.
The graphics card uses GDDR5 graphics ram memory.
It will work just fine.
NOTE 3*
It does NOT matter if your computer uses the PCI Express 1.1 technology, and the graphics card uses the PCI Express 2.0, or 2.1 technology.
PCI Express 2.0, and 2.1 technology is Backward Compatible with PCI Express 1.1 technology.
Will you get the full capability of the PCI Express 2.0, or 2.1 graphics card?
NO
Will you notice?
NO
What you need to look at it, is how much power will the graphics card use. Look at the system requirements for the graphics card, and be sure your Power Supply has enough power for that graphics card.
Also, IF, the graphics card requires additional power cables from the Power Supply, make sure your Power Supply has the required power cable, or power cables.
IF the Power Supply does not, use a power adapter cable.
NOTE 4*
Graphics card manufacturer's base the power needed for the graphics card, Not just on the graphics card itself, but on an entire computer system, AND the graphics card.
The graphics card manufacturers use a test computer system, that is a powerful computer system.
Gamer motherboard, Dual Core, or Quad Core processor, 4GB of ram memory, and at least two harddrives, and two optical drives, PLUS the graphics card in question.
This complete computer system uses a LOT more power than just the graphics card by itself.
There isn't a single graphics card out there, that uses more than 150 Watts by itself.
Recommendations for a graphics card that is compatible, with a Compaq Presario SR1620nx desktop computer?
Budget to medium:
Good enough to watch videos, older games, and some newer games.
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=4675217&CatId=3670
Medium:
Higher level games, and large screen monitors,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=6642574&CatId=3669
For questions post in a Comment.
Regards,
joecoolvette
Dec 18, 2010 | HP Compaq Presario SR1620NX...
How do i set up my R300 printer to my H.P laptop,I have the C.D.for it but i am getting old and a bit slow on the uptake,also i have only had the laptop for a few months. Bob Butterfield.
HI there,
Here are some steps to install your printer.
  1. Power on the PC or the Laptop
  2. Make sure that you have completely remove all the protective tape on the printer. You can see this factory tape on the top cover and the other was inside the printer.
  3. Connect the USB cord to the computer and the other end at the printer.
  4. Power ON the printer
  5. The computer will now detect the plug n play device that you have connected.
  6. You will need the driver Cd that you have.
  7. Insert the cd on the CD tray.
  8. The Installation wizard will appear, and the rest of the process will be easy for you. Just follow the on screen setup instruction and your done.
Let me know for further clarification and assistance.
Thank you for using fixya.
Jun 23, 2010 | Epson Stylus Photo R300 InkJet Printer
I want a compatible video card for my pc
This sounds like your computer may be several years old and the hardware a little outdated. It will depend on the game since today's latest games require not only 3d-acceleration but super fast acceleration as given by "NVIDIA" or "ATI"'s latest graphic cards.
If you are running a relatively simple game, you need to see if your computer uses which type of graphic card connector.
In the old days it was PCI, then came AGP and later PCI Express.
What the above will tell you is which 3d graphic card type to buy. You can get a graphic card at newegg.com or lots of other places varying in speed and capacity.
Aug 11, 2009 | 3dfx Voodoo2 1000 (12 MB) Graphic Card
Trying to install Geforce Verto 8400 GS card on Dell GX260 and cannot get computer to start in safe mode when card is in computer! HELP!!
Seems like the graphics card simply isn't compatible with your motherboard either. However, have you tried installing the drivers for the new card with the old one still in, then inserting the new one, and booting up? That's the only thing I can think of that you didn't try yet...
Jun 07, 2009 | XFX NVIDIA GeForce 8600 Graphics Card
I have bought and installed a new HDD. I have partitioned it. I'm running windows xp setup. XP Setup begins installing windows gets completed...then system restarts and monitor looses display. this is the...
Hi there
I think it may be a graphics problem. May be the XP drivers are not compatible with your machine graphics card.
You could try this to solve it ...
From the web, possibly on another PC that's got the internet, download the graphics driver for your machine and save it to a USB disk.
Once the set up is complete, try booting into safe mode (press F8 on boot, then select boot into Safe Mode)
Now try running the driver from the USB disk (or copy it to C: drive first then run it).
Jan 09, 2009 | E-Machines (T2824) PC Desktop
Want to try to utilize an old sony Vaio PCG-F520
OK you can certainly add wireless to this machine. But be careful which type you buy. If this machine has windows 98 you have to ensure the wireless adaptor will be compatible. . you have two choices for the adepter type either USB or PCMCIA (aka PC Card) I'd go for the PCMCIA version, it will be more likely to play well with the older system. Also, Dont buy a MIMO card, a simple 802.11B or 802.11G compatible card will work. these are in the sub $40 price.
Dont attempt to install XP or VIsta on this PC, it will be unbearably slow. Stick with 98 or better yet windows 2000.
-Good Luck
Jan 05, 2009 | Sony VAIO PCG-F520 Notebook
Computer freeze on saving files to USB 2.0 External Hard Drive (and USB2 flash drive)
Suggest you look at the motherboard book to check if or how many USB connections are in fact USB 2 compatible. Most modern Motherboards only have 2 USB 2.0 Compatible connections, most are 3.0 or 4.0 compatible. Hope this helps, Malcolm Campbell.
Mar 12, 2017 | Belkin Hi-speed USB 2.0 5-Port PCI Card [...
Computers & Internet Logo
37 people viewed this question
David Payne
David Payne
