Question about HP Office Equipment & Supplies
I have a hp psc 2710. It doesn't print in a straight line. I opened it up and I can see there's lots of gooey, sticky ink all around the cartridge contact points on the unit. There's too much to clean out by hand using q-tips over and over again. Is there a way to disassemble the unit enough to get the assembly out and clean it that way?
  • 24 Answers
Go to radio shack and purchase electronic spray cleaner approx 11.00 a can and will go a long way.. spray a little in and around the contacts electronic spray is safe on electrnoics will not screw up the parts .. the ink may so try not to spread it around.. and soak up the remaining goo with a soft cotton cloth not terry towel or anything that will leave particles. try to remove as much of the excess junk from around the contacts . it appears that the pump is on the way out and this can be caused by purchasing sub generic brands of ink cartridges which leak out excessive ink or defective name brand cartridges.
i learned the hard way that buying cheaper does not save money as the quality is not as good .. but some name brands are defective sometimes and will cause the same issue. as far as dis assembly i would avoid this unless you are mechanicly skilled.... is it under warranty of any sort? like they have them anymore..lol but working for two name companies i learned that Dell and Hp are notorious for poor quality when it comes to printers..may be switch brands when time to replace..
Posted on Jan 02, 2011
How to change ink cartridge hp psc 750
1- Open the printer
2- Remove the ink cartridges from the print head.
3- Use cotton swabs dipped in hot water to thoroughly clean the print head.
4- Repeat this until there is no ink residue coming off on the cotton swab.
5- Once finished, allow to dry and replace the cartridges
Mar 19, 2013 | HP PSC 750 All-In-One InkJet Printer
HP PSC 2355 print cartridge not supported?
If this is not a factory new cartridge then that may be the reason it is giving this error.
Apr 17, 2017 | HP PSC 2355 All-In-One InkJet Printer
I have an hp psc 1215 all-in-one. My black cartridge won't print. It recognises if I swap it out for a new one, and goes through all the motions. It registers the correct ink levels. The cradle...
The problem is not with the ink-cartridges. You've proved that, by swapping BLACK cartridges.
The problem is that the ink-jets that spray the BLACK ink onto the paper are clogged.
Thus, no BLACK ink reaches the paper.
Open the HP Printing Assistant, and open Utilities, and run a few "print-head-cleaning" cycles, to try to unclog the print-head.
Jul 19, 2011 | HP PSC 1215 All-In-One InkJet Printer
How do i change the cartridges of hp psc 1215
1. Turn on the unit, then open the print cartridge access door by lowering the handle. -- The print carriage moves to the center of the unit.ionstorm_0.jpg
2. After the carriage stops moving, push down on the print cartridge to release it, and then toward you out of its slot.
3. Remove the new print cartridge from its packaging and, being careful to touch only the bright pink plastic tab, gently remove the plastic tape to uncover the ink nozzles.
Caution! Do not touch the copper contacts or ink nozzles.
Once you have removed the plastic tape, install the print cartridge immediately to prevent the ink from drying in the nozzles.
4. Push the new print cartridge into the appropriate slot at a slight angle until it clicks into place.
Caution!
Do not attempt to push the cartridge straight into the slot. It must slide in at a slight angle.
The tri-color print cartridge goes on the left and the black cartridge goes on the right.
5. Close the print cartridge access door.
May 06, 2011 | HP PSC 1215 All-In-One InkJet Printer
I have a brand new HP PSC 1410 and after having to buy a black ink cartridge my printer still doesn't print in colour. The printer came with a preinstalled colour cartridge.
The product software print setting is probably designated as grayscale. Follow these steps to check this setting:
  1. In the software application you are trying to print from, click File , and then click Print . The Print dialog box opens.
  2. Make sure your printer is selected, then click Preferences . The printer Preferences dialog box opens.
  3. Select the Color tab, then make sure that the Print in grayscale option is not selected.
Step 2: Check ink levels
NOTE: If you have installed a refilled or remanufactured print cartridge, or a cartridge that has been used in another printer, the ink level indicator will be inaccurate or unavailable.
  • Open the Printer Toolbox . There are two ways to open it:
    • Open HP Solution Center , select the Settings menu, then the Print Settings submenu, and finally the Printer Toolbox .
    • If the HP Solution Center method does not work, open Printers and Faxes in the Windows Control Panel , then right-click your printer icon and click Properties . Click Printing Preferences . Click the Services tab, then the Service This Device icon.
  • The Printer Toolbox opens. Click the Estimated Ink Level tab. A cartridge might be running out of ink even if the graphic shows ink remaining (see the note at the start of this section). Lines or streaks always appear in printouts when the cartridges begin to run out of ink. Replace print cartridges that are out of ink or low on ink.
    Dec 07, 2010 | HP PSC 1410 All-In-One InkJet Printer
    Prints but can't read it
    Buy a new ink Cartridge.
    Take it out shake it a bit, put it back, if it prints darker for a little bit. You need a new ink cartridge..
    Oct 25, 2008 | HP PSC 1210 All-In-One InkJet Printer
    Ink lvels
    Hello holliston,
    You can try the following steps that should help you determine your ink levels.
    1. Open the Printer Toolbox . There are two ways to do this:
      • Click Start and select HP Solution Center . Select the Settings menu, then the Print Settings submenu, and finally the Printer Toolbox .
      • In your printing application, click File , click Print , and click Properties . Click the Services tab, then the Service This Device icon.
    2. The Printer Toolbox opens. Click the Estimated Ink Level tab. A cartridge may be running out of ink even if the graphic shows ink remaining. Lines or streaks always appear in printouts when the cartridges begin to run out of ink. Replace print cartridges that are out of ink or low on ink.
    If you do not mind, please rate my help I would greatly appreciate it. Thanks
    Sep 06, 2008 | HP PSC 1510 All-In-One InkJet Printer
    HP PSC 1300 All in one Printer
    1. Turn on the HP PSC and lower the print-carriage access door.
      The print carriage will move into the access area. Figure 1: Opening the print-carriage access door
    2. After the carriage stops moving, push down on the top of the print cartridge to release it, and then pull it toward you out of the slot.
        NOTE: The black cartridge is on the right side of the print carriage.
      Figure 2: Removing the print cartridge
        NOTE: It is normal to see ink buildup in the print cartridge slots.
    3. Remove the new print cartridge from the packaging and gently remove the plastic tape by using the pink pull tab.
        CAUTION: Do not touch the copper contacts or ink nozzles. Install the cartridge immediately upon removing the tape to prevent ink from drying in the nozzles.
      Figure 3: Removing the plastic tape
    4. Push the new print cartridge into the appropriate slot at a slight angle, until it clicks into place.
        CAUTION: Do not attempt to push the cartridge straight into the slot. It must slide in at a slight angle.
      Figure 4: Inserting the print cartridge
    5. Close the print-carriage access door.
    Using a photo print cartridgegtabtop.gif To use the photo print cartridge, remove the black print cartridge and insert the photo print cartridge in its place.
    The photo print cartridge can be purchased separately and will optimize the quality of printed photos.
    With the tri-color print cartridge and photo print cartridge installed, you have a six-ink system, which provides enhanced quality photos. For printing regular text documents, use the black print cartridge.
    Use a print cartridge protector to keep either print cartridge secure when it is not being used. Figure 5: Storing the print cartridge
    c00034854.jpg 1 - Inserting the print cartridge
    2 - Removing the print cartridge
    Aligning the print cartridgesgtabtop.gif After installing or replacing a print cartridge, the HP PSC will automatically print a cartridge alignment page.
    1. Place the alignment page face down on the left front corner of the glass with the top of the page facing the left side.
    2. Press Scan .
      The HP PSC will align the print cartridges. During the alignment the button LED will blink until the alignment is complete.
    Aug 04, 2008 | HP PSC 1350 All-In-One Thermal Printer
    Black Ink Cartridge alignment problem
    I have never heard of that happen before. I know if they have been refilled they lose there effectiveness causing leaks to happen.
    Jun 14, 2008 | HP Photosmart 2710 All-In-One InkJet...
    Hi I have just inserted a new HP ink cartridge 94 into my HP PSC 2350, as the ink was running low. I was printing photos, which keept printing with a red line throughout the picture. After inserting the...
    Try opening the printer properties and cleaning the print heads (should probably be done each time a cartridge is changed), it uses some ink up but should clean the build up from running the previous cartridge dry and hopefully solve your printing problem.
    Good luck.
    Mar 29, 2008 | Computers & Internet
    22 people viewed this question
    Ben Johnson
    mukhtar21 shaikh
    mukhtar21 shaikh
