Question about GE (PSS26MSRSS) Side by Side Refrigerator
Our GE model GSH25JSRF SS side by side refrigerator has everything working on the control except the water. We have ice, light, etc. Where is the reservoir that might be frozen so that we might put a hair dryer on it. If you have better solution, please give that. Thanks for help.
I have the exact same question. where is the answer?
Posted on Jan 21, 2011
Ice and Water not dispensing. Light button not working
http://www.repairclinic.com/0100_1.asp
There's an ice- or water-dispensing problem The ice and water-dispensing system of your refrigerator is quite complex. Many components work together to provide the ice and water. Aside from a simple problem of a leaky water tube or a jammed ice chute, most other components are not user serviceable. We suggest that you contact a qualified appliance repair technician for such repairs.
Jul 04, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Model GSH25JSRF SS The fan in freezer clicking and working intermittley, the augor in the ice machine and the water dispensor are only working part of the time. You can hear a clicking sound as the fan...
On this particular model the fan and all operations are controlled by the main board on the back of your Refrigerator. This is part number wr55x10942. Less than $200.00 and not hard to change out.
Jan 31, 2010 | Refrigerators
GE Model GSH25JSRF SS is clicking non stop, the click comes from a small panel on the back right of the fridge. Started out that the water and ice dispenser didn't dispense. Then the clicking just came...
Is it still cooling? I had an issue where there was a clicking noise from the back panel and the fridge did not cool. Pulling off the panel the noise seemed to from a box on the circuit board. Turns out there was a problem with the controler board and after some research I found that the board was covered under a recall. GE ended up sending a guy out to replace the board at no charge. Pretty cool being that if was after the warranty had expired; but I guess it makes sence since there was a recall. Good luck.
Dec 10, 2009 | GE GSH25JFR Side by Side Refrigerator
RE: GE model #gsh25jsrf ss. The water does not dispense from door. Can I fix this? Thank you.
At the bottom of the freezer door ( remove the kick plate ) , there will be a water line . Follow this line , about 6 " to a connector . Push in on the white ring and pull out the line , at the same time . Activate the water dispensor pad and see if water flows from the line under the refrig . If it does , then the line in the door is frozen . Either raise the freezer temp for several days , so the line in the door will thaw , or , I have heard using an air tank will blow the ice out of the line in the door . If no water comes from the line under the refrig , while activating the pad , then replace the water valve , behind the refrig , the piece the wall water line connects to on the refrig .
Oct 31, 2009 | GE GSH25JFR Side by Side Refrigerator
GE Profile Fridge Model No. PSC25MSWA SS not making ice
Check to see if there is any obstruction (object of any kind) in the ice cube mold area. If nothing found, you will have to replace the icemaker, as individual repair parts are not available.
Aug 04, 2009 | GE Profile Arctica 25.4 Cubic Feet...
Ge side by side water will not come out of door dispense
The water switch went bad or the water valve. Switch the two wires on the water valve on the back of the ref. Press water switch on door if water fills ice maker valve is bad,if not,door switch is bad.
Jan 21, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Monogram ZISS480DMCS Ice Maker Problem
i would first check water supply to ref. measure the resistance of coil either open or resistance. if all this is ok then exit side of line needs to be checked for water.
Sep 22, 2008 | GE Monogram ZISS480DRSS Stainless Steel
GE Ref #ESS25LSRCE SS
are you sure it is not a GSS or a PSS model i have the manual on that post your email and i will send it to you
Mar 10, 2008 | GE GSH25JSTSS Stainless Steel Side by Side...
GE GSS22sgrf ss - Side-by-side refrigerator
I need to make sure that your refrigerator model and make numbers are listed correctly. Im having trouble with the information listed above your comments. I have GE data base and want you to look at the hyper link listed below.  and let me know if this or I can help lead you in the correct direction, Thanks, Sea Breeze
http://www.appliance-parts-warehouse.com/general-electric-parts/General-Electric-Refrigerator-Parts-Page-6901.cfm
Oct 25, 2007 | GE GSS22JFMWW Side by Side Refrigerator
GE (PSS26MSRSS) Side by Side Refrigerator Logo
464 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
