Question about Magellan Maestro 4000 GPS
Dropped unit and broke on off switch - Magellan Maestro 4000 GPS
  • 944 Answers
You have to replace the switch alone. It can be done, they do it in all Magellan service center. Itcosts very less only. It has a rubber spring which would have jumped off. Soyou cant switch on without repairing it.
Please do rate the solution if the issue is resolved or post a comment forfurther assistance.
Thank you for using fixya have a nice day:-)
Posted on Jan 04, 2011
I DROPPED MY VERIZONE CELL PHONE. NOW IT IS NOT WORKING. HELP!
U broke it! If under warranty see if they will exchange it - hopefully it will not show the ravages of the fall because warranties do not include abuse or dropped units.
Nov 09, 2015 | Cell Phones
How to fix power switch?
you need the following tools
soldering iron, solder, grounding strap ground the unit and you.
soldering plunger to remove old solder, the right switch, buy a new switch, solder,
disassembly the unit, find the broken switch unsolder, clean contact area, solder new switch, with out over heating the board or new switch, reassembly, test, your done
Oct 02, 2015 | Tablets & eReaders
Weider Platinum xp600 won't change weight
I just finished fixing this exact problem on my XP600. I also could increase the weight, but not lower it. Both wires (grey and orange) were cut from the lower limit switch (it's in the upper right corner). The way the harness was jammed into the unit, it broke the wires. The limit switch fell apart as I was taking it out, so I soldered the grey (there's two) and the orange wires together. The display now works properly. Because the switch is now bypassed, I just have to be careful and not drop the weight past 15/20 lbs. If you raised the weight when the display wasn't reading right, it will reset once you increase the weight to the max. Then you can decrease and it will read the right weight.
Jan 05, 2014 | Weider PLATINUM XP600 Console
Craftsman air compressor model 191.135131 wont build pressure
I can not find a Craftsman compressor with that model number anywhere so here are a couple things to look into. If the compressor fills to 70psi and keeps on running check the valve plate and piston/cylinder assemblies. Check that the valve reeds on the valve plate are not bent, broken or warped from heat. Then check that the wiper (oil less) or pistion rings (oil splash) are not damaged and that the cylinder wall is not scarred up. Any of these will let the compressor fill up to the point where the air pressure leaks past the valves or piston and won't fill any further. If the compressor fills to 70psi then shuts off the problem is in the pressure switch. Some have an adjustment screw or bolt to control when it turns on and shuts off. If you had a drop from 100 to 70 the springs may be weak or broke and you'll have to replace the switch.
May 22, 2012 | Craftsman Air Tools & Compressors
Window has dropped douwn in drivers door.how do i remove interior
  1. i had the same thing happen on drivers door. it was the window motor. it has a cable on it that broke and allowed the window to drop into the door. the motor and cable is all one unit.
Jul 20, 2010 | 1999 Jeep Cherokee
IQUE M5 Antenna broke off
BUY PART NUKMBER 010-10702-00 FROM GARMIN IT IS A EXTERNAL ANTENA THAT PLUGS RIGHT INTO THE UNIT.
Feb 06, 2009 | Garmin iQue M5 GPS Receiver
Broke the ear hook for the Motorola h500 bluetooth headset
They do not make earhooks alone. You must send it back and they will replace the whole unit.
May 12, 2008 | Motorola Mobility H700 Headset
Stylistic LT C500
I had a similar issue, the inverter has a component that broke, had to order a new one. I opened the unit and saw the component that broke, its a long ferrite piece that I guess acts as a capacitor. anyway, I took the part number off the board and did a search on ebay where I found one for about $25, this fixed my problem. good luck.
Sep 19, 2007 | Fujitsu Stylistic LT C-500 Tablet PC
Magellan Maestro 4000 GPS Logo
15 people viewed this question
Top Magellan GPS Experts
Jungle Ghost
Jungle Ghost
Are you a Magellan GPS Expert? Answer questions, earn points and help others
