Question about PANDIGITAL PAN 70-0 7.0" LCD Digital Picture Frame With Remote
I need to replace the battery in the remote. How do I open the remote?
    President:
  • 489 Answers
The battery on the remote is on a 'tray" that can be pulled out. The tray is on the back of the unit, at the bottom. There is a click-catch that you need to squeeze while you grab the edge of the tray. Use your fingernail to hold/squeeze the catch laterally before you pull the tray out.
Make sure you replace the "button battery" on the try with the correct side up. Then slide the tray back into the slot and make sure it snaps into place.
Posted on Jan 02, 2011
Testimonial: "As of now, the "plastic" is winning. But I am taking the directions along with the remote to school tomorrow to ask a co-worker to help. "
My remote for Centrex CTPL42S5 batteries leaked. Can I get it fixed or need replaced? If need new where and how much pls?
It should be replaced. Before replace, clean the remote control well.
https://www.youtube.com/watch?v=F8oYoZslgbs LG Remote control - Open - Search [How to open LG Remote control]
https://www.youtube.com/watch?v=do41DlsZHmA [ open, battery change Toshiba]
https://www.youtube.com/watch?v=jsSCNCW3IbQ [open and clean]
https://www.youtube.com/watch?v=Qp-l1uh-5gE [open and clean]
Jan 06, 2016 | Televison & Video
Are the battery replaceable? Or do we have to buy a new remote opener?
Yes you change the batteries in a garage door opener remote. You can find on at your local pharmacy. If you have to push the button several times and the batteries don't help you may need to replace the remote.
Feb 10, 2015 | Building Materials
If my battery went dead on my remote for my gagage door opener do I have to reprogram remote when I put in new battery?
WIth car remotes they do not need re-coding if the battery is replaced within a few minutes of the old one being taken out.
source: car remote battery sales assistant.
Dec 24, 2014 | Genie gict390-1bl new g3t-bx garage door...
Keyless Remote Activation
The remote batteries are dead and need replaced. Most remotes are held together with clips or screws and are easy to open if done carefully. Then replacing the batteries is easy and put remote back together.
Jan 23, 2014 | 1996 Ford Thunderbird LX
My garage opener remote on my 2003 santa fe just stopped working. How can I fix it?
There is a battery in the remote.If the battery gets old the remote will stop working.Replace the battery and check.Also if your battery is new but still the problem is there then,try to open the garage door by keeping less distance between remote as well as the garage door.Also there is a sensor in the garage door.If that sensor is not functioning then this can be one issue.In some cases the internal remote circuit gets short,in that case the remote needs replacement.But does the garage door sensor light shows any sign of getting connection from remote when you press the remote button.Open the door and try to close the door with remote and check.As per the problem,in most cases its weak battery related problem,and replacing the battery solves the problem.You can try all the possibilities and see which one helps.Thanks.Helpmech.
Nov 12, 2010 | 2003 Hyundai Santa Fe
Just replaced the battery and it doesn't work...any advise?
If the battery didn't fix it is probably has just quit working.
Jun 07, 2010 | Sears Craftsman LiftMaster Chamberlain...
Liftmaster 973LM. Remote opener does not work. Replaced battery - still does not work. Original owner left no manuals. Works with outside pad and inside button.
ONCE YOU REPLACE THE BATTERY YOU NEED TO REPROGAM THE REMOTE.
WATCH THE LED NEXT TO THE PROGRAM BUTTON WHILE YOU PRESS THE BUTTON ON THE REMOTE IF IT FLASHES THE REMOTE IS SENDING A SIGNAL AND SHOULD WORK.
IF IT DOESN'T FLASH THE REMOTE BATTERY MAY BE IN BACKWARDS OR THE REMOTE MAY BE BAD - IT IS NOT SENDING ANY SIGNAL AT ALL.
HOPE THIS HELPS
Jan 12, 2010 | liftmaster Chamberlain Garage Door Opener...
I need to replace the battery on a Genie GICT-390 garage door opener. How do I open the case?
If its a lighter grey colored intellicode remote: There should be a small slot on the side of the remote. Use a coin such as a dime or a penny, stick it in the slot and twist. The remote should split in half and you'll see the coin-shaped battery. After you replace the battery, you can snap the 2 pieces of the remote back together.
If its a dark grey/black intellicode remote: The back cover should partially flip open to reveal the battery. This remote takes a 12volt N-size battery.
If its a keypad remote you are referring to: The bottom half of the keypad's face should slide straight down to reveal the battery (you should see and arrow and some thumb grips). All Genie keypads take 9volt batteries. Source(s): I am a genie technician
Oct 24, 2009 | Genie Company IntelliCode GICT390-1BL...
Keypad lights flash, wont open with code. Wall button and remote work.
You need to do a remote and opener re synch, because your rolling synch codes were lost when you replaced the batteries. Go to manufacturers web site for re program instructions.
Apr 18, 2009 | Computers & Internet
PANDIGITAL PAN 70-0 7.0" LCD Digital Picture Frame With Remote Logo
372 people viewed this question
Top PANDIGITAL Photography Experts
LP
Bill Eager
Are you a PANDIGITAL Photography Expert? Answer questions, earn points and help others
