Question about Sharp LC52LE810UN 52 in LCD TV
Change aspect ratio on LC-52LE810UN (Sharp Quattron - 52' LED).
4 Suggested Answers
  • 61 Answers
SOURCE: i have a Sharp LC-52-d64u tv and it wont turn on
I have this same tv... Have you played any video games on it cause the xbox360 makes the screen blank... Put an hdmi cable in you tv and connect it to your cable box or dish box... this might fix the problem
Posted on Aug 02, 2010
gopakumarg43
  • 75404 Answers
SOURCE: What do I need to
Hello
1 Press MENU to display the MENU screen, and then
press [=> or <=] to select "System Options".
2 Press [Up or Down] to select "Input Terminal Setting", and
then press ENTER.
3 Press [Up or Down] to select "PC input", and then press
ENTER.
4 Press [Up or Down] to select a specifi c adjustment item,
and then press ENTER to set each item.
5 Press [Up or Down] or [=> or <=] to select or adjust the desired
setting, and then press ENTER.
Adjusting the PC Image
Auto Sync. (for Analog PC Input Mode Only)
For automatically adjusting the PC image.
Yes: Auto Sync. starts and "Now adjusting the image."
displays.
No: This function does not work.
When "Auto Sync." is successful, "Completed" displays. If
not, "Auto Sync." failed.
"Auto Sync." may fail even if "Completed" displays.
"Auto Sync." may fail if the computer image has low
resolution, has unclear (black) edges, or is moved while
executing "Auto Sync.".
Be sure to connect the PC to the TV and switch it on before
starting "Auto Sync.".
OK.
Posted on Mar 14, 2011
bshldn
  • 736 Answers
SOURCE: How to adjust for best picture a Sharp Aquos
This sounds like a setting that can be adjusted. What I like about some of the Sharp televisions is the av mode setting (preset brightness/contrast adjustments). I am not looking at the manual for this model so I'm not sure if this is an option on this television. However with this being a high end aquos model there is free assistance available to you. You can register your television at aquos advantage and chat live with an aquos advisor at Sharp's Midwest Corporate Headquarters. The agent may advise you to call in if your television need and Industry Initialization because you have to be talked through it. I advise the chat reps initially because when you call you aren't able to speak with the Midwest Corporate Sharp reps unless your call is being escalated.
http://www.aquosadvantage.com
Posted on Apr 22, 2011
Reset secret number on sharp aquos
ROFLOL and we are supposed to know it .or guess ,or read your mind from afar .
Nov 21, 2015 | Sharp Aquos Quattron LC-46LE810UN 46-inch...
TV won't turn on?
Fault to its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Oct 11, 2015 | Sharp LC-52LE700UN AQUOS 52 Class 52-1/32...
How do i adjust the picture size
Refer its user manual to get more details about setting the aspect ratio to picture.
Aug 12, 2015 | Sharp Aquos LC-52SE94U 52 in. LCD HDTV
How to change aspect ratio on sharp tv?
You cant change the aspect ratio. You can stretch and zoom programs . Some programs like movies are in letterbox and you can stretch to fill the screen, but the results are not perfect. Circles will be oval and you will cut off some of the viewable picture. This is normal
Jun 29, 2014 | Sharp LC-32SB21U 32 in. LCD TV
Connecting LC-52LE810UN to internet
Connecting to the Internet
To connect your TV to the Internet, you must have a broadband Internet connection.
Use an ETHERNET cable (commercially available) to connect the ETHERNET terminal on the TV to your
broadband router (commercially available).
If you do not have a broadband Internet connection, consult the store where you purchased your TV or ask your
Internet service provider or telephone company.
you need to have a cable connected to the ETHERNET port and then you will get more options. You need to connect it to your router ports. hopefully you have DHCP enabled on the router and then all will program automatically
Feb 01, 2014 | Sharp LC-52LE810UN LCD TV, 52 - widescreen...
Power and OPC blinks, TV will not change Input modes
Try removing set and or a box if used from power for several minutes.
Dec 23, 2012 | Sharp LC-46SB54U LCD TV 46 inch Class,...
Screen is not full on tv
Try to go to menu settings,, and change aspect ratio and make it auto or full screen ,what suits your vision
May 15, 2012 | Sharp Aquos Quattron Led LCD TV
What is the aspect button on a sharp remote?
there should be a button labelled "P.size" and that should show you the aspect ratios but if not go to the menu and access picture and look through the options until you get size and it should allow you to change aspect ratios.
May 20, 2011 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Sharp LC52LE810UN 52 in LCD TV Logo
287 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
