Question about Water Heaters
I noticed my water wasn't staying hot long to shower and wash dishes. The water continually runs out of the relief valve to the outside of house. Had to shut-off water to unit and turn off breaker. What could be causing this?
  • 1,772 Answers
Sorry to read about your problem, I hope this helps you out.
most likely you have a defective relief valve, since you turned off a breaker, i will assume it is electric. water heater.
Their is a off chance, the the water heater is defective and getting to hot..but the thermal protection should kick in.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question's. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Posted on Jan 02, 2011
Testimonial: "thanks so much for the quick response. I sent in additional info but did not know how to ask you in particular. Thanks again!"
1) Open link below for troubleshooting leaking water heater:
http://waterheatertimer.org/Leaking-water-heater.html
TP valve leaking is probably different cause than low amount of hot water.
The reason is TP valve releases pressure when tank is very HOT, not when tank is underheated.
Raise TP lever and lower back down to see if sediment is causing valve to stick open.
Next, replace TP valve and see if that clears up leaking problem.
2) Your electric water heater has some hot water.
That says electricity is working correctly.
Tank is not overheating, and ECO reset button is not tripped.
And it says upper element is working.
If upper element is not working, then tank has no hot water.
http://waterheatertimer.org/How-electric-water-heater-works.html
That leaves 3 suspects:
a) Upper or lower thermostat is bad: Solution, Replace both thermostats for $28. If problem persists, then replace lower element.
http://waterheatertimer.org/How-to-replace-thermostat-on-electric-water-heater.html
b) Lower element burned out
http://waterheatertimer.org/How-to-test-water-heater-element.html
http://waterheatertimer.org/How-to-replace-water-heater-element.html
c) Loose or shorted wire located between upper thermostat and lower part of tank.
Open tank panels and inspect for burned wire and loose screws, especially on lower element.
When finished, put insulation and covers back so thermostat not exposed to cooler air, which will cause overheated tank.
If you want to test parts before replacing anything, then take 30 minutes and do complete troubleshoot:
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html
Buy cheap multimeter at home center.
When testing continuity or elements, rotate multimeter dial to Ohms.
When testing for voltage,, rotate multimeter dial to 240-250-277 VAC
Add a comment for more free help.
Also take advantage of fixyas phone service.
For a price, fixya expert speaks with you over phone while you work on water heater.
Testimonial: "Thanks so much for your quick response. Will try the No. 2 solution as that sounds more like what is happening. "
  • Anonymous Jan 02, 2011
    And also sounds like No. 3 Solution. Appreciate your response.
  • Anonymous Jan 03, 2011
    Defective relief valve that runs all your hot water out of tank, can cause tank to have less hot water. So the problem could be relief valve.
I have a Rheem Stella 850 series 360 L which is one year old. I have noticed the last few days that the hot water pressure is dropping and water flow is fluctuating in and out.
Did you do back flow? Suggest you perform back wash via the hot water outlet of your heater by plugging a hose. What is the tubing size that flows thru the heating elements? If it's small, maybe you need to apply higher back pressure to remove the soil. Does it have a built in pump? If it has, check the ******* strainer, maybe it's cloaked up with debris, you never know what's in the line.
Jun 21, 2016 | Rheem Water Heaters
My water heater has a leak only when it is turned on.
it could be a leak around an element if it is an electric heater.
Jun 04, 2014 | Suburban Direct Spark and Electric Water...
Relief valve buzzing noise
Add an extrol expansion tank to the piping. You can get one for about thirty dollars from the hardware store.
Apr 06, 2014 | Rheem 82V40-2 Fury Electric Residential...
Low flow trough the heater
follow this steps and fix it. God bless you
Drain a tank:
  1. Shut off power at the electric panel and post a sign warning others not to turn it on.
  2. Close the cold-water supply valve and open a hot-water faucet somewhere in the house (to speed draining).
  3. Attach a garden hose to the drain valve and run it outside the house.
  4. Open the drain valve and allow all water to drain out.
  5. To refill the tank, close the drain valve tightly and open the cold-water supply valve. Also open a nearby hot-water faucet. When a steady stream of water flows from that faucet, the tank is full and the faucet can be closed.
  6. Once the tank is full, turn the electrical power back on.
Test and replace a relief valve:
  1. Lift the spring lever on the valve to fill a small cup. Check the cup for sediment.
  2. If no water spurts out, or if water continues to drip after the valve is released, replace the valve.
  3. Cut power at the electric panel and post a sign warning others not to turn it on. Close the cold-water supply valve.
  4. Drain a few gallons of water from the tank.
  5. Unscrew and remove the discharge pipe if used.
  6. Loosen the relief valve with a pipe wrench, then remove the valve by hand.
  7. Apply pipe tape to the threads of the replacement valve and screw it into the tank by hand. Tighten it with a pipe wrench. Screw the discharge pipe (if any) into the valve outlet.
  8. Refill the water heater and restore electrical power.
Oct 08, 2013 | Water Heaters
Why does water suddenly go cold during shower? It only happens in master bath... guest bath shower does not cause same problem. I have to go outside and unplug and plug back in heater to get it to start...
Try running the hot water in the sink while you have the shower. If the water in the shower stays hot, then the problem is not enough flow through the water heater to keep the heater running. I am guessing that the master bath is further away from the water heater than the guest bath. If not I would check the shower nozzle in the master bath to see if it is clogged a bit or if it is a water saver nozzle because this will slow down the water volume and then cause the water heater to shut off the heat.
Feb 24, 2011 | Rheem RTG-74PVN-2 Natural Gas Pronto Whole...
I can get the water to stop running from the water heater to the outside of the house.
If this water is coming from the pressure/temperature relief valve on your tank type water heater, and it is piped from inside to outside of the house, you could try pulling up on the lever atop the pressure/temperature relief valve and releasing it. See if it sets properly. It may have to be replaced if I understand your problem accurately.
Gary
Dec 27, 2010 | RTO W4 A.O Smith Gas Hot Water Heater...
Water will not stay hot long enough to shower...not familiar with any of these thermal expansion tanks and can't find any info on vacuum relief valve---40 gal water heater is 18 months old....any...
Turn the gas knob up. There's a dial on the front (probably red) and it will have settings on it. A B and C. Turn up to desired temp, but be careful of faucets if there are children in the house. Good luck
Dec 30, 2009 | Rheem 40 Gallon FVR NATGAS Low WATER...
Running out of hot water with Vulcan Freeloader 300
hi i need help with mi Vulcan 300 hot water main gas pressure...
our kitchen tap got broken and we turn off our main water pressure in front off our house and now our hot water gas not working ....please help
thank you ...
Sep 24, 2009 | Water Heaters
Fluctuating temperatures
Sounds like there is not enough flow in order to keep the burner in the heater firing continuously
Jul 09, 2009 | Rinnai Webstone The isolator EXP tankless...
At shower time in the morning the hot water varies from cold on one day medium on another and hot on any given day. What's wrong?
Do you share your hot water with anyone? Is anyone washing dishes, laundry, etc before you shower? How old is your hot water heater? If it has filled with sediment, your hot water is limited. Try turning up the heat control valve on the hot water heater, only go up one notch today, then if not enough another the next day. Be cautious of scaulding hot water after turning it up.
Apr 10, 2009 | Water Heaters
Water Heaters Logo
203 people viewed this question
Top Water Heaters Experts
Donni Steen
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
