Question about Apex Digital PF3220 32" TV
The Channels won't stop Changing - Apex Digital PF3220 32" TV
  • 66 Answers
If someone has spilled water or pop around the buttons on the tv itself then the buttons may be sticking if it was just water then it should go back to normal after the water dries out.But if it is soda then you have to manually take it apart and wipe the motherboard where the tv buttons connect to it with rubbing alcohol. have you tried pushing the channel up and down buttons numerous times and sometimes pushing them pretty hard will unstick it. If not the i say it would have to be clean.I would also use the remote and fool around with menu buttons to see if there is a way to correct it that way.But if all else fails then the motherboard tv buttons have to be cleaned .Hope this little bit of knowledge helps at all.GOOD LUCK to you and good fortune be with you.
Posted on Jan 02, 2011
The channels on my ge 32gt720 tv keep changing by them self
Channel change button on the remote or on the side of the TV coule be stuck.
Jul 20, 2014 | GE 32GT720 32" TV
Wont stop changing channels
Check and replace the main system memory IC. It is faulty. It is a very small IC, won't cost more. An eight solder terminal IC. Even though the physical size is small, function to it when the TV works is great. The work is a skilled one.
Jul 29, 2012 | Emerson LC320EMXF 32 in. LCD TV
Won't stop changing channels
The memorey IC to your TV is faulty. It can be located near to main systtem control IC. If you have sound knoledge in electronics, locate it and replace it.
May 08, 2012 | Televison & Video
How can i stop the channels from changing?
if channels only scan up or only down suspect the manual button for this on the set is causing it---it may look perfect but the only way to know is to gain access to it and disable that one button.
Apr 23, 2012 | Televison & Video
On my 47LG5000 The channels keep changing and won't stop at any of them as if the up button is stuck
pull your remote apart and give it a quick clean i use a baby wipe then dry it off before i put it back together that normally works it cleans all the years of dust out of it hope this helps
Feb 22, 2012 | LG Televison & Video
Tv changes channels when turned on.
Be sure your remote hasn't got a button stuck down which is changing channels. If not, take the batteries out of the remote. If this stops the channel changing there is probably some conductve material stuck across the circuit board
inside the remote. If this is the case you have to check inside the remote by openning it up.
Jan 28, 2009 | JVC AV-27530 27" TV
TV WILL NOT STOP CHANGING CHANNELS
Go and "hide" the remote from the set and see if that helps. Rare, but possible is a problem with the phase-lock loop circuit in the TV, or, encoder for that remote that you just hid....accordianman
Aug 10, 2008 | RCA P60920BL 60" Rear Projection...
Tv wont stop changing channels
ok, Sony had this issue on their early production. The problem you are having is called a leaky switch. The volume down switch on the TV is leaky. To fix this you must replace the switch. This part is called the switch block. Part number 1-473-549-21
Average cost $26
Best regards
Circuitcity
Dec 18, 2006 | Sony KV-27V42 27" TV
Apex Digital PF3220 32" TV Logo
59 people viewed this question
Top Apex Digital Televison & Video Experts
Jaime Hernandez
Electro Med Services...
Are you an Apex Digital Televison and Video Expert? Answer questions, earn points and help others
