Toyostove laser 56 was reading Hi and would not work; we disconnected room temperature sensor(thermostor) now heater works but read lo. Where can I buy new thermostor?
  • 674 Answers
Try a Google search for "Toyostove/the state you're in" and see if you can find a dealer. If you can't, I can get it, but will have to add shipping costs to the price. nitensheaterservice@earthlink.net
Posted on Jan 03, 2011
My toyo L-30 reads the temp then Lo for instance it currently reads 70 Lo. What does this mean?
Lo is displayed when the room temperature is below 14F or the heater thinks the room is below 14F, which would be caused by a problem with the room temperature sensor or the sensor is unplugged. 70 is what you have the heater set to maintain. Check the white wire on back of the heater.
Dec 09, 2010 | Rinnai Toyostove Direct Vent Heater: Laser...
Temp is reading HI so stove won't come on. Figure it is a thermostat problem(?)
This means the room temperature is over 95F. This could be due to the sensor being in the sun or the sensor is shorted. Try unplugging the thermostat wire and see if it goes away. If it does you may need a new thermostat wire.
Sep 27, 2010 | Rinnai Toyostove Direct Vent Heater: Laser...
The thermostat setting temperature of my Laser 56 Toyostove will suddenly jump up to a high setting (86) which in turn causes the stove, when not operating, to start up and/or causes the stove, when...
The reason I asked was to see if it is a power supply problem. If the setback had been set on 86 I would suspect you were having power fluctuations causing the heater to go the setback temperature. I will give this some more thought and post something else soon.
Sep 11, 2010 | Rinnai Toyostove Direct Vent Heater: Laser...
My toyostove says "HI", no matter what the temp is set at and will not ignite. Could this be a problem with the temp sensor or something else. Please help! thanks
Hello Your unit overheated!The highlimit has to be reset.It could also be a (one time) over temp limit in wich case needs replacement limit.
Mar 31, 2010 | Rinnai Toyostove Direct Vent Heater: Laser...
Toyostove laser 56 H burner coating or burn mat
Here's a link regarding burner mat replacement for a 56 if you have not already figured it out.
http://www.rural-energy.com/publications/catalog/document/318
Nov 26, 2008 | Rinnai Toyostove Direct Vent Heater:...
Toyostove laser 30
Could it have to do with the temperature sensor? If it is still coiled up on the back of your heater, it may be turning the heater off. You need to uncoil the sensor wire, and place the sensor somewhere away from the heater. One sight said atleast 8" off the ground. (I have a Laser 73 and mine is about two feet to the right and about 8 foot up on my wall as I have a lot.) You can attach it to a board if you have to, or any other item. Just put it as far away from the heat of the heater as you can so it will only be sensing the room air temp. If the line needs to be longer you can cut in stereo wire (I read this online too). Then play with the heat settings to see at what temp it is most comfortable for you. Hope this solves the problem.
Apr 12, 2008 | Rinnai Toyostove Direct Vent Heater: Laser...
EE2 code for toyo laser 56
Hi sammysamual,
My business is Laser Heating Service in the North Pole/Fairbanks areas of Alaska. An EE2 error code is usually fuel related. What does your Toyo do before the EE2 code shows up? If you let me know the sequence of events, I can trouble shoot the problem for you. toyotech
Dec 13, 2007 | Rinnai Toyostove Direct Vent Heater: Laser...
Heating & Cooling Logo
61 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
