Question about Dishwashers
My baumatic dishwasher bdw15 powers up as usual but I can't select a program with the P button. Could you please help? Regards Martin
SOURCE: i need to reset my dishwasher but don't know how!!
bdw13 showing e4 & trying to empty when no water in it
Posted on Apr 16, 2007
SOURCE: Baumatic dishwasher won't start
Had this problem with the Baumatic 13. Perhaps the door is not closing properly. Make sure you push the door hard in the top centre. It should beep once and then start after a few secoonds.
Terry
Posted on Dec 28, 2007
daba2
  • 10 Answers
SOURCE: BAUMATIC BFD47SS dishwasher won't start
Sounds like the water inlet solenoid valve is not opening. Not easy to get at to test, but if water is available at the hose inlet connection as you say there isn't anything else stopping water entering the wash cabinet.
Shouldn't be a lengthy repair - so I'd recommend getting a quote.
Posted on Oct 05, 2008
SOURCE: error code E2
Error Code E2 means the pump is blocked. The remedy is to take the filter out which is underneath the bottom dish basket and ensure its is clean and free from debris. Then use a small container to empty the water sitting in the bottom of the machine/filter housing and ensure that no waste is stuck in the bottom. That should clear it
Posted on Nov 26, 2009
  • 34 Answers
SOURCE: After selecting a program, the
Basically the dishwasher is telling you there is a fault - Not so useful I know! Plug out the machine and leave it for five minutes and see will it reset. If that does not work, you will need to reset it manually. To do this consult the manual. If you don't have a manual, go to http://www.hotpointservice.co.uk/hs/pages/manual/manualSearch.do and down load one. Good luck!
Posted on Aug 13, 2010
Hi, I have error message 20 on BDW14 Baumatic. Dishwasher won't start. What does it mean? Thank you..
Error 20 is not a listed error in Baumatic dishwasher. They only mention E1 to E7.
There is a reset procedure for random errors which can be viewed at this page.
http://www.ukwhitegoods.co.uk/help/fault-codes/dishwasher-fault-codes/3305-baumatic-bdw-dishwasher-fault-codes.html
Please check if this helps.
Apr 25, 2014 | Baumatic Dishwashers
I have Baumatic BDW 3W Dishwasher The programming controller stops rotating automatically at certain points in the revolution. can you advise please.
I have Baumatic BDW 2W Dishwasher The programming controller stops rotating after the first normal cycle revolution. can you advise please.
Aug 24, 2010 | Baumatic 23 in. BDW3 Built-in Dishwasher
Baumatic BFD60SS - Tablet not dissolving
this happened with mine and it turned out that the top shelf was too low, so this meant the spinning arm was being stopped by my plates. When the machine is fully loaded check that the spinners can move freely. if they don't then you can move the top shelf up a level. hope this helps
May 27, 2010 | Baumatic 24 in. BFD60SS Free-standing...
Aug 09, 2008 | Baumatic Dishwashers
Baumatic Dishwasher
http://www.espares.co.uk/parts/dishwashers/baumatic/bdw15/p/1083/1533/0/511574
Jul 15, 2008 | Baumatic 23 in. BDW5 Built-in Dishwasher
Baumatic dishwasher BDW9
This looks to be the same problem I'm having with my dishwasher (BDW15) I have removed the control panel and have noticed the On Off button has started to burn out, thus cuasing intermitant power supply.
Solution is to replace the On Off switch with a new one, which I'm still drying to source as it's Christmas and everybody is shut.
Hope this helps
Craig...
Dec 19, 2007 | Baumatic 23 in. BDW9 Built-in Dishwasher
Baumatic BHD5 works then buttons start flashing and it beeps and stops working
Before buying a new control unit, try to unplug the machine for few hours and plug it back in. It might reset the control panel and solve your problem. Good luck!
Aug 01, 2007 | Baumatic 24 in. BFD60SS Free-standing...
I need to reset my dishwasher but don't know how!!
If it's any help then here is the link to the user manual (when you download it it applies to bdw13 as well even though it is labelled for the bdw14) http://www.baumatic.co.uk/products/discontinued-models/dishwashers/integrateddishwashers/BDW14 Best I could come up with is to try page 19 at the bottom of the "dishwasher doesn't run" section - there are two different types of reset which may do the job. Hope this helps :)
Mar 13, 2007 | Baumatic 23 in. BDW13 Built-in Dishwasher
Dishwashers Logo
Top Dishwashers Experts
