Question about Skytech 1001-A Fireplace Remote Control On/Off
I have a Skytech 1001 TH-A thermo remote. Everything was hooked up correctly, but the remote continues not to work. When I turn the remote off, the fireplace comes on and vice versa.
    Brigadier General:
  • 4,736 Answers
Rhonda, if you have the On/Off/Flame Height Remote Control ... from what you have described (it's working in reverse) someone has wired it backwards to the control valve. With this particular remote, there is a positive and a negative. Reverse the wires that are connected to the gas control valve (at the control valve. Not on the Black Remote Box) and everything should be fine. If you need more help contact Skytech Technical Service @ 888-672-8929 Monday - Friday. They are great people to work with.
Posted on Jan 15, 2011
    Problem Solver:
I have the same problem with my 1001 TH remote system. I've tried it all and it works sometime and not at others. I would like to convert the logs over to a manual wall thermostat if possible. Can I do this?
Posted on Dec 25, 2014
  • 72 Answers
The Skytech 1001-TH-A is actually an on/off/thermostat remote control. You can view the product page and owner's manual here: Skytech 1001-TH-A.
It is impossible to wire backwards, as it merely interrupts the millivolt signal travelling to the valve. Before calling Skytech's support line as suggested previously, you could try re-synchronizing the remote to the receiver. The instructions are below:
LEARNING TRANSMITTER TO RECEIVER
NOTE: This receiver can hold up to 3 transmitter codes. This is for the times when a second hand held transmitter or a wall transmitter
is required.
Each transmitter uses a unique security code. It will be necessary to press the LEARN button on the receiver to accept the transmitter
security code upon initial use, if batteries are replaced, or if a replacement transmitter is purchased from your dealer or the factory. In
order for the receiver to accept the transmitter security code, be sure the slide button on the receiver is in the REMOTE position; the
receiver will not LEARN if the slide switch is in the ON or OFF position. The LEARN button in located on the front face of the receiver;
inside the small hole labeled LEARN. Using a small screwdriver or end of a paperclip gently press and release the black LEARN button
inside the hole. When you release the LEARN button the receiver will emit an audible "beep". After the receiver emits the beep press
the transmitter ON button and release. The receiver will emit several beeps indicating that the transmitter's code has been accepted
into the receiver.
Posted on Jan 20, 2013
Skytech 1001 no learn button to reprogram. Red light works, lights the fireplace in "on" mode, but the remote won't turn on it on.
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electro-medical.blogspot.com/
http://electrohelponline.blogspot.com/
Search the site by type in the brand name of your device, in the "Search box at the top right of the Home page display" to see the set-up codes to your device, with different brand remote controls.
Jan 09, 2016 | Skytech...
Remote for SkyTech Un3 will not work, need Manual
I have a direct link to the Skytech 1001-A owner's manual on my site here: Skytech 1001-A Fireplace Remote.
Simply scroll down to the bottom of the page to the "Download Owner's Manual" section. I try to keep it updated if the link ever changes.
Thanks!
Dec 28, 2012 | Skytech 1001-A Fireplace Remote Control...
Need Manual for SkyTech Remote UN3
You can visit my product page here: Skytech 1001-A Fireplace Remote. Simply scroll down to the bottom where it says "Download the Install Manual", I keep an updated link to the owner's manual.
Thanks!
Skytech 3301 thermo
Check to make sure your thermostat is set at a temperature that will turn the fireplace "on".
Double-check what your "swing" temp settings are set at, as this may effect how quickly the unit shuts off because it thinks it's too close to the target temperature.
If needed:Skytech's Tech Support number is 1-888-672-8929They are available Monday to Friday, 8am to 5pm EST.
If your remote needs to be replaced, the 3301 is available here:
Skytech 3301 Fireplace Remote
If you are looking to replace it, I would also highly recommend looking at Skytech's new 3301P2 remote. It adds a programmable thermostat, and a much nicer back-lit LCD screen. This unit is available here:
Skytech 3301P2 Fireplace Remote
Dec 15, 2012 | Skytech 3301 Thermostatic Gas Fireplace &...
I have a 5301. Connected last year, worked fine. Installed new batteries, connects and beeps, but fireplace won't light. All controls are in correct position.
I know it seems obvious, but sometimes over the summer people shut off their pilot light, and when relighting forget to move the pilot knob back to the "on" position after the pilot is going - check this first.
Next, you can slide the switch on the Skytech 5301 receiver from "remote" to "on" and verify that it lights the burner. If it does, you may need to re-sync the remote to the receiver. If it does not, check to make sure your wires are nice and tight on the TH & TP/TH connections of the valve.
If you are still having trouble, Skytech has a toll-free hotline for tech support on the 5301. It is: 1-888-672-8929 8am-5pm EST.
Nov 29, 2012 | Procom SSU320RHN-GB Heater
Cant program remote
I'm going to assume you are meaning that you are unable to set the "target temperature" for the thermostat?
This remote control system can be thermostatically controlled when the transmitter is in the THERMO mode (THERMO must be displayed on the screen). To set the DESIRED room temperature, press the MODE button to place the transmitter into THERMO mode, then press the UP or DOWN button to select the desired
room temperature. The highest SET temperature is 99 degrees Fahrenheit (32 degrees Celsius).
The complete owner's manual can be downloaded from the product page below, just scroll down to the bottom and click the link.
Skytech 3002 Thermostat Fireplace Remote
Sep 23, 2012 | Skytech 3002 Fireplace Remote Control with...
Skytech-3001 Thermo won't work
I am having some trouble! Mine became unconnected and I don't know how to reconnect. There is two wire, red and white, a box that sits inside the fireplace that has an on/off sitch and a box that sits outside the fireplace with a off/remore/on switch. How do I connect it back? Please help!
Jan 28, 2012 | Skytech 3301 Thermostatic Gas Fireplace &...
The remote no longers turns on the fireplace.
  • Is your valve turned "on" and not in the "pilot" mode?
  • If your valve is in the "on" position, try turning the Skytech receiver's switch to "on" instead of remote.
  • If the fireplace ignites when the receiver is "on" then the remote needs to be re-synchronized.
  • If the fireplace valve is "on", the remote's receiver is in the "on" position, and the fireplace will not light, then you most likely have a bad thermopile in your fireplace and need service.
  • Skytech 1001-A product page and manual can be found here.
Dec 09, 2011 | Skytech 1001-A Fireplace Remote Control...
How do I sync my remote to the receiver?
If you don't have your Owners Manual, it's available online in pdf format from SkyTech. I recommend that you download it and print for future reference. These are not hard to program, but having the Owners Manual for other trouble shooting problems you may encounter, makes it worth it's weight in gold.
http://www.skytechsystem.com/editor/assets/installation%20files/1001%20BE%20Instructions.pdf
If, when you click on the link above and it doesn't work .. copy and paste it into you web browser.
Jan 21, 2011 | Skytech 1001-A Fireplace Remote Control...
Open Questions:
Fireplace sparkignitor not activating All of sudden yesterday the remote would not initiate the fireplace spark igniter. First thing I did was replace the D batteries in the FP unit with tested good batteries. That did not resolve the problem when it had in the past couple of months. I replaced the 13v battery in the 1001 remote even though the light on the remote was strong. I went back to the FP D battery case and slipped a battery out to check connection and slipped back in. Just putting the battery back in initiated the igniter. I tested the remote see if would turn off the FP and it would not. So at bed time to turn off the fire I just pulled out one D battery. This morning I decided to trouble shoot the problem. First I slipped one D battery I removed last night back into the holder expecting the igniter to activate like it did yesterday. It did not. I started looking around at the other black box wired to the same place the pair D battery box is attached. I saw a big arrow and slipped the cover off. Low and behold was full four AA batteries I never knew existed. I replaced those four AA batteries correctly inserted and verified good batteries. Watched a Skytech 1001 "learn" button video and followed those instructions since I pulled the four AA batteries out and replaced them. I tried the remote and that did not work. Summary: with new batteries in the remote and both battery cages at the FP (one holding two D and the other holds four AA> I have reached the end of my troubleshooting expertise. Guess it could be the spark igniter but I go back to the strange event of me just popping out one of the NEW D batteries and popping it in and the igniter initiated. And the only way I could turn off FP other then turning off the gas was to pull one D battery. I did this morning spot the on/off switch on a housing that the two battery cages are connected to. Guess if I had known that was there I could have turned that switch off last night instead of popping out one D battery to kill the fire maybe would not have the problem tis morning. Guess it did not like that battery out over night. I did test it couple times yesterday by slipping one D battery out and back in and the fire would die and reignite each time I tested. Was about three times so I expected it to behave same way this morning. it did not. What is my next step? HELP, HELP.
Feb 27, 2017 | Skytech 1001-A Fireplace Remote Control...
See all Skytech 1001-A Fireplace Remote Control On/Off Questions
Skytech 1001-A Fireplace Remote Control On/Off Logo
1,447 people viewed this question
Top Skytech Home Security Experts
Lawrence Oravetz
Are you a Skytech Home Security Expert? Answer questions, earn points and help others
