Question about HP PhotoSmart 1215 InkJet Printer
Ink system has failed. Error:0xc18a0001 - HP PhotoSmart 1215 InkJet Printer
  • 1 more comment
  • ddupere Nov 29, 2008
    Ink system failure
    ERROR 0xc18a001
    - Can this be fixed?
  • Anonymous Dec 02, 2008
  • jkrw Feb 15, 2009
    ink system failed
Posted on Oct 28, 2008
    New Friend:
Ink system failure
ERROR 0xc18a001
Posted on Feb 06, 2013
SOURCE: Ink system has failed.
ok i got it...
Press and Hold the “Print Photos” &”Red Eye Removal” buttons. Release both buttons. Display should say”Enter Special Key Combo”
Press and release in sequence”Red Eye Removal”,”Print Photos”,”Red Eye Removal”
Display should say “Support” and display the FW rev: COxxFN0723BR (or something like that)
Press and release the right arrow button until the display says “System Configuration Menu"
Press and release the “OK” button.
Display should say “Hardware failure status: Clear. Press OK to clear”.
Press and release the “OK” Button. Message changes to “Hardware failure status Cleared. Press Cancel to continue”.
Press and release the “CANCEL” button as many times as necessary, so that, either the “Welcome to Photosmart Express” screen appears, or, the “Ink System Failure” screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE.
Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet.
Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer
Turn the unit on. The printer may display message “USE POWER BUTTON TO SHUTDOWN THE PRINTER” followed by “PRESS OK TO CONTINUE”. Press OK.
the printer will get ready as if it were starting perfectly for a first time, it will say something like: printer preparation occuring - do not interrupt
print a test page:
1) Load letter, A4, or legal unused plain, white paper into the input tray.
2) Make sure that the printer is on and loaded with unused plain, white paper.
3) Press Setup . The Setup menu appears.
4) Press the down arrow button to select Tools , and then press OK .
5) Press the down arrow button to select Self-test Report , and press OK . The self-test report prints.
if this doesn't work, i'd call hp support.
Posted on Mar 24, 2009
  • 154 Answers
SOURCE: HP photosmart C5180 all in one: Ink system has failed
Here's a link to a procedure that one individual used to fix the same problem with his printer. I can't guarantee this will work in your particular case.
HP C5180 All-In-One Printer HARD RESET:
  1. Hold down HELP + OK button and unplug printer (could experiment with regular power-off, but I opted for brute force)
  2. Hold down HELP + OK button again as you plug the printer back in. Then power it on, if it doesn’t power on automatically. Be Safe: keep holding the buttons until the printer turns itself off. (It took mine less than a minute.)
  3. Now you can release the buttons and simply power it back on. (I held my breath, but that’s not required.)
    • I got an error message about “improper shut down” since I unplugged it w/out powering down. After I clicked “OK” the printer was just fine and didn’t mind anymore. And now I can print.
reference: http://www.mlnarik.com/jewel/2009/05/21/how-i-fixed-my-hp-c5180-printer/
Posted on Aug 07, 2009
SOURCE: my hp photosmart D7145 printer
my photsmart 6180 error 0xc18a0001
Posted on Sep 16, 2008
SOURCE: error message 0xc18a0001 Ink system has failed.
Easy fix. I found elsewhere on this site that the solution is to RESET the printer via the following instructions from HP...
1) Unplug Printer
2) Simultaneously press and hold the HELP & OK buttons
3) Re-plug in printer, while still holding the two buttons.
That's it ! You are reset. It will take a little time for the printer to re-configure, but you'll be printing in 5 or so minutes.
Posted on Oct 29, 2009
pineworks
  • 4041 Answers
Hi may work I found this I know your error not in here but it may work for It worth a try nothing to lose and it may work. I know your error code is not in this but it some times it clean the error with this type of error number you can gave it a go try not harm it Error code: 0xc18a0201, 0xc18a0206, 0xc18a0306, 0xc18a030a, 0xd0620130, 0x887dd03a, 0xd05d010d, 0xf0af8004, 0xc19ac3ff, 0xc18a050...
Reset the product:
1. Without turning off the product, disconnect the USB cable from the rear of the product.
2. Remove the cartridges from the product.
3. Wait for the 'Insert Cartridges ' message to display on the control panel.
4. Disconnect the power cord from the back of the product.
5. Wait 60 seconds.
6. Reconnect the power cord. If the product does not automatically turn on, press the Power button ( ).
7. Reinsert the cartridges, and then close any open doors on the product.
8. If you receive a prompt to print a calibration page, do so.
9. Reconnect the USB cable to the rear of the product, and then try printing again.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Feb 08, 2010
Error Oxc 18a00001
you may need another print head with that error code message. I would contact HP Total Care (1800-474-6836) and check to see if your printer or print head is in warranty, and it could be replaced.
Error 0xc18a0001
Jan 20, 2016 | HP Photosmart D7260 Printer
Ink system has failed. Error:0xc18a0001 my printer is HP Photosmart 8250All-in-One System Failure) I refer to printer documentation Error:0xc18a0001 Turn power off, then on again. I dId this command but...
Try taking out the cartridges, and turning off then unplugging the printer. Leave it unplugged for about five minutes, the plug it in. Wait a few more minutes, and turn it on. Wait for it to completely start up, then put the cartridges back in (make sure you are putting them in correctly, I think this is your product here). If it still shows the error, contact HP customer service. They will probably say something similar, though.
Jul 06, 2011 | Office Equipment & Supplies
ERROR 0xc18a0001 Ink system has failed Quite new
Try the link below. This error is related to air in the lines between the print head and the cartridges. It is quite common and HP are very aware of this.
http://fix-your-printer.blogspot.com/2009/03/ink-system-failure-on-hp-photosmart.html
I hope this helps. Regards GM
Apr 16, 2011 | HP Photosmart D7360 All-In-One InkJet...
Ink system has failed error : 0xc18a0001 how do i fix this problem?
  1. Press the On button to turn the printer off.
  2. Unplug the power cord from the back of the printer.
  3. Remove all the ink cartridges.
  4. Wait two minutes.
  5. Plug the power cord into the back of the printer.
  6. Press the On button to turn the printer on.
  7. Install the ink cartridges when prompted.
If the error code does not display, the issue is resolved. If the 0xc18xxxxx ink system error code displays on the front panel, service the printer.
Apr 01, 2010 | HP Photosmart 3310 Printer
HP PhotoSmart 1215 InkJet Printer Logo
3,312 people viewed this question
Seeker5211
Seeker5211
