My CD player says there is a CD player in the player, but there is no CD in there. You can't put another CD in there and nothing will eject. What can I do to fix this?
    Scholar:
  • 82 Answers
There is a problem in the way the connection of your cd player or on the chip of your cd player because it now reads the wrong signal. The best way to fix this is to rewire and reprogram the chip. Have technician in your area fix that.
Posted on Jul 09, 2008
Unit has power and lights up. None of the buttons work and cd wont eject. The CD eject button turns the unit off but won't eject the CD. Cannot change the functions. Have reset the unit and checked th
Remove the face plate and clean the contacts on both the head and the radio. It sounds like a bad connection, The base and head use serial data to talk to each other(control).If one of these connections are bad the unit will not work properly.
Oct 06, 2014 | Sony MEX-BT2900 Bluetooth Car Stereo with...
CD player doesn't work
try another disc make sure it's a cd from a retailer. sometime home made disc don't play on older cd players because of formats. as for eject problems you might find you have to send it back to the retailer for repair
Apr 16, 2014 | Arcam Solo Music System Cd Amp Tuner...
Cd does not eject from kenwood kdc-138
First if your still under warranty return for new player if not carefully remove top and bottom covers check for any clear tape holding cd door shut or Look at LED sensors blocked by strofoam or cardboard that may have gotten inside the home position guide (the tray that holds the CD) the LED's are located at the front where the door first opens and at the rear where the CD goes deepest into the player,lightly clean with cotton ball and alcohal first remove hot wire ,Now turn cd player upside down and tilt side to side listen for loose screws or other debree check make sure belts are all tight by lightly tugging with index finger turn gears only one eighth of a turn never force anything, if they move that is a good sign, by moving the gears out of position when it is turned back on it will try to find home position, reconnect hot wire and try CD player again.Do not get grease on LED's make sure there is nothing on the CD like a sticker making the cd to thick will clog the device.if still no joy hand turn the gears until the cd is all the way out.Try different CD again never force good luck
Aug 26, 2012 | Kenwood Kdc-138 Car Cd Deck Auto Stereo In...
CD player won't work
Firstly is it burnt or factory cd? Most factory cd players won't play a burnt disk.
If you have a store-made cd and it is not reading that, then the lens inside the player is dirty and needs to be blown out with a can of "airduster"
Feb 01, 2009 | Audio Players & Recorders
My cd player in my 2005 chevy malibu wont eject all it does is clicks
we have a 05 malibu. cd got stuck and displayed locked on radio. on the passenger side floor board is a fuse box. u have to pull the panel off takes about 10sec to do. find tha fuse that says radio its a 10A fuse. pull tha fuse out. put key in ignition and turn forward. put fuse back in and hit the eject button cd will come out.
Sep 07, 2008 | Audio Players & Recorders
My Tivoli CD player is ejecting cd's. Those it does accept play badly and jump. I am trying to insert a CD cleaner, but this gets ejected as well!!! Help!!
If it is under warranty simpyl return it to get it repaired.
It seems either there is something stuck inside what makes it think there is already a CD inside or your eject button is stuck internally. If not under warranty and you're a bit handy, try to open it and see if there is anything inside the CD area that makes it eject CD's or if one of the small wires connected to your eject button is loose or if there is a shortcut inside.
Aug 08, 2008 | Audio Players & Recorders
The light on my CD player is on, meaning there is a CD in the player. There is no CD in the player though. You can't put another CD in the player, and nothing will eject from the CD player either. Is there...
Nothing you can do about this. It is the IC on your CD player that reads the wrong signal. The best way to fix this is to have a technician who knows to reprogram your IC.
Jul 09, 2008 | Audio Players & Recorders
When I try to eject my music CD, the display says "Lock" and the CD will not eject.
I turned the player off, then while holding down the STOP button, I pressed the power button. The player made a click noise, but it did not turn on. It must have been resetting or unlocking the player because .... Then, I let go of the STOP button and turned the player on. I was then able to eject the CD. I found this solution somewhere in the posts on your website. Thank you!
Apr 20, 2008 | Samsung Audio Players & Recorders
I have a 1999 Toyota Tacoma and the C.D. player worked fine until a couple months ago. All of a sudden, when I put in a C.D., it simply ejects. I tried a cleaner, I tried blowing it out. Any ideas?
If you haven't done so already, unplug the main power source from the back of the head unit. Wait a few seconds and plug it back in. If it is still ejecting cd's automatically. It will most likely need to be replaced.
Mar 19, 2008 | Audio Players & Recorders
62 people viewed this question
 Grubhead
Grubhead
