Question about HP Pavilion 754n PC Desktop
754n will not hold memory when shut down and powered back on
  • 2,229 Answers
This is a little confusing. Memory clears out when you shut down your computer. When you start back up, you'll start filling the memory with what you are doing. There is no way to recall what was in memory. var fctb_tool=null; function FCTB_Init_e1fd0454766b4afcbb0ab2235b4516a3(t) { fctb_tool=t; start(fctb_tool); }
Posted on Jan 02, 2011
Clearing memory on Pentair vs pool pump
To reset the pump;
You will need to hold down all four speed buttons for a few seconds, then release them, then push select twice, you will see "0" highlighted, push the arrow up button to "1" then press enter, then shut the power down to the pump for about one minute, then power it back up and your pump should be back to factory settings.
Dec 03, 2016 | Pentair Pool & Spa
How do I replace the power button on a 754N HP?
What's the reason why you need to replace it?
Jun 15, 2014 | HP Pavilion 754n PC Desktop
Dell Inspiron 6000 powers up, caps lock flashes 9 times, then laptop shut down. Why???
Unplug power cord from laptop, remove battery from laptop. Open memory access panel on the bottom of the laptop. Remove memory module(s) (SO-DIMM). Plug power cord back into laptop. Turn laptop on (with the memory removed), the caps lock and scroll lock LEDs light, then the laptop shuts itself off. Unplug power cord from the laptop. Reinstall the memory modules. Make sure they are seated correctly. Put the battery back in, plug the laptop back in, and power on. Laptop should power on and boot up properly.
May need to hold the power button down to get it to power on properly.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Dec 03, 2011 | Dell Inspiron 6000 Notebook
Hello. I have a Toshiba c650-18k laptop . I was playing on it.and wen i went to shut down before shutting down it just went off.and wen i tried to turn it on again it is not turning on.I put my laptop on...
Is there any lights indicators lit up on the laptop?
remove the battery and the ac adaptor and press and hold the power button (for 10-15 sec) with the battery and power cable unplugged
now try powering up the laptop
check whethere the bluetooth and the power light is lit up
this indicates that there is a memory dump issue in this case you need to reseat your memory strips
for that underneeth the laptop there will be memory door
unsrew door the and open the door and you can take the memory strips out and reseat it back
Dec 26, 2010 | Computers & Internet
I shut my laptop down and it would not start back up. The green battery light is solid but the light bulb power light now longer display. The way it's put together; I can get to the connection to see if...
Remove the battery the memory the ac cord .Press and hold the power button for twenty seconds.If you cant get to the memory don't worry about it. THE OBJECT OF THIS EXERCISE IS TO TRY TO RESET THE COMPUTER.
GOOD LUCK
Sep 17, 2009 | Acer Extensa 5420-5687 Notebook
Flashing Green Power Light on Tower
Try holding down the power for a full minute or two then start it up again. The power button may be set for sleep and not shut down. You may have to hold the button longer. If that doesn't work it could be RAM, or a serious problem with the motherboard.
May 06, 2009 | Dell Dimension C521 PC Desktop
I have an hp 754n that will not turn on.. the green led on the back is lit up but when i hit the on off button nothing happens
i would say there is a problem with the motherboard, you could check to make sure the power supply is connected, if you don't know what a motherboard or power supply is, i would advise that you take the computer to a technician, you could injure yourself, or ruin the computer completely if you attack it with a screwdriver
Jan 20, 2009 | HP Pavilion 754n PC Desktop
My 754n will not turn on
Make sure that the power wolts is as per required.
and try connecting to different wall outlet and also check the CPU fan. if it is firmly fixed.
Jan 19, 2009 | HP Pavilion 754n PC Desktop
Tower intermittently loses power
you need a new power supply !!!!
Jul 05, 2008 | HP Pavilion 754n PC Desktop
HP Pavilion 754n PC Desktop Logo
26 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
