Question about Dryers
Hi, My idv65 has stopped heating up so therefore has stopped drying any thing. I've cleaned the filters is there anything else I can try?
  • Dryers Master
  • 43,501 Answers
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Posted on Jan 03, 2011
Dryer heats, tumbles but does not dry. Exhaust has heat.
perhaps the washer is not spinning all of it out therefore making it hard for dryer
Aug 31, 2015 | Dryers
Doesn't dry
Drying consists of removing moisture through heat and airflow. Check to make sure that your venting tube is not kinked somewhere and therefore not allowing the air to flow freely from the dryer.
Apr 11, 2014 | AEG T57800 Electric Dryer
LOW HEAT, SLOW DRY
  • Hi Jim,
    The first thing to check is the filter is clean and not blocked. The air travelling through the dryer is what carry's the water vapor away. The Lint filled filter will block the airflow resulting in forever to dry anything if at all. The second thing to think about is a over full tub of washing to dry will have the same effect as that blocked filter. Two half loads of washing dry faster that the same amount altogether in the same dryer. Last but not least, check that the intake or exhaust is not blocked with fluff or that the dryer is not right up against the wall effectively blocking the flow of air.
    These points are general to all dryers Jim. They are not specific as you have only recorded a fault and no mention of Brand age or model.
    Good Luck
    Regards
    John
Jan 30, 2014 | Dryers
Dryer getting hot but not blowing hot air out
Unplug and stop using sounds like a fire hazard, try cleaning out the lint filter and replacing the exhaust hose, and make sure your homeowner policy is paid, hope this helps,
Nov 05, 2013 | Indesit Dryers
Dryer wont stay lit
if the flame is liting most likely problem is bad air movement.go outside with thedryer running and check the hood to see how strong the air is blowing out,if there's a cage or anything blocking the hood remove it,if the vent line is a long run remove the vent line from the back of the dryer,stick a leaf blower into it and blow out the lint to the outside.also with the dryer unplugged,remove the bottom panel,remove the lint filter and metal duct the filter slides into,clean that out and blow out the blower wheel with a shop vac,you can blow out the gas tube where the flame ignites to make sure it's clean blow off the motor and the cabinet and vac up all lint that blows forwards.you can try running the dryer with the vent line removed to see if it runs any better.when the dryer first heats up the flame will come on until the temp. is reached and it will shut down,one more thing to check,when gas coils start to fail you'll have heat for like the first 15 to 30 minutes,then when the coils heat up the ignitor will glow but no flame,after the coils cool down they will work again.how are you running it on timed dry or more or less dry,if you run it on auto or more or less dry there's a sensor inside where the lint filter is,try cleaning it up or try running it on timed dry to see if it runs any different,when on auto the heat comes on,when it reaches temp. the heat stops and the timer will advance,when it calls for heat the timer stops and the heat comes back on,it will do this until the clothes are dry.your model has an even heat board in it that can also cause problems but if the flame is liting it sounds like you have a block somewhere.go here this will tell you a little more about your model dryer.
http://fixitnow.com/wp/2009/03/17/easy-fixes-for-two-common-problems-with-the-whirlpool-even-heat-dryers/
May 23, 2013 | Dryers
Why have my dryer stop getting hot to dry clothes?
call an electrician to test the element or if gas call a gas fitter to check the gas operation
May 16, 2017 | Bosch Nexxt WTMC 3300 Electric Dryer
My stackable washer/dryer is taking at least 3 cycles on high heat before it will dry one load. It's heating up but it doesn't get hot enough. I've checked the venting and it is clear and...
If your dryer is not drying like it once did or if you just have nottaken the time to give yourself a clean dryer in a long time then youneed to do that. At least once a year the dryer cleaning should takeplace. Lint build up in the dryer duct is one of the main causesfor your dryer to fail.
Here is the rest of this tip about DryerMaintenance
heatman101
Jun 19, 2011 | Electrolux Dryers
My indesit dryer is IDV65, the drum is spinning but the dryer is not heating up and the clothes are still wet.
heatman101
Jan 05, 2011 | Indesit Dryers
Clean light keeps blinking and I can't start a new cycle
Puppa, clear the fault by pressing the keys in this order: high temp scrb--air dry--high temp scrub--air dry. Or, depending on your model..Sani rinse--air dry--sani rinse--air dry. The dishwasher will enter the service mode. Let it do it's thing or advance it through it by pressing the start key. The fault came from the board not sensing a rise in the water temp. Make sure to run the hot water before starting the dishwasher. The heating element runs through the nuetral side of the door switch so make sure the d/w is level and the door switches are all making. The element itself could be at fault. Catriver...post back
Apr 01, 2007 | Kenmore 24 in. 15932 Built-in Dishwasher
Dryers Logo
153 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
