Question about Whirlpool LTG5243D Top Load Stacked Washer / Dryer
How do I get my washer basket back on track? - Whirlpool LTG5243D Top Load Stacked Washer / Dryer
    President:
  • 3,113 Answers
Any can't the Basket engage in drain step?
When the washer fills, the basket floats allowing it to engage to the wash mode, when the washer drains the basket needs to drop back down inorder to engage to the spin mode. Pleazer Appliance...
Jun 28, 2014 | Whirlpool Cabrio WTW6600SBT Top Load...
Replace washer spin basket kenmore elite 110
sounds like a bad bearing on the rear of the tub. If you remove the rear access panel you will see a large pulley and belt. That attaches to the inner drum (basket) and spins it. It floats on a bearing just behind the pulley. If the bearing is bad then you will be able to move it up and down about .25 to.50 of an inch.
Jun 25, 2014 | Kenmore Elite 45986 Front Load Washer
What does the F51 code mean ?
What washer do you have? The F51 code is a failure of the RPS sensor at the bottom of the motor on the Kenmore Oasis or Whirlpool Cabrio.
This can occur if you overload the washer or if there are foreign objects under the washer that prevent the motor from turning.
If you set the water level for a small load but put in a large amount of laundry, you can get the error. If the drain hose is incorrectly positioned in the drain, the fill water can get siphoned and cause the error. Make sure that the basket turns freely when you lift the lid. Items stuck between the baskets or a problem with the basket hub can also cause the error.
If the unit isn't overloaded and the basket and motor move freely, you need to find where the circuit is failing. See this URL for details on tracking the fault: http://www.managemylife.com/mmh/questions/110568-does-f51-code-indicate-washer . You need to measure the resistance on the cables to the control board from several sensors and the motor itself. These tests will lead you to the parts that need to be replaced. If you aren't sure of your ability to do these diagnostics, call for service.
I hope this helps.
Jul 26, 2011 | Washing Machines
My washing no start and display view f34 Thanks
The F34 code normally only occurs when you are trying to run the CLEAN WASHER cycle. The washer should be completely empty of laundry when you are attempting to start this cycle. If the washer is empty and you are trying to run this clean washer cycle then you could have a friction problem with the spin basket that is causing the F34 code. Try turning the spin basket by hand with the washer empty and dry. The basket should turn relatively easily. If the basket will not spin easily you could have a problem with the bearing in the back of the outer tub or you could have an item stuck between the spin basket and the tub inside the washer.
May 04, 2011 | Washing Machines
Basket has fallen loose in front of washer. basket sags loose in front. belt in back is on okay and basket turns freely.
take off the top of the waher and look at the suspensions springs and make sure they are attached.you may also need to remove the back panel and look at the shocks to see if they are in good working order.
Oct 09, 2010 | Frigidaire ATF6000ES Front Load Washer
Duet Washer spin cycle makes noise
if it was from a heavy load more than likely 2 screws came off of the tripod on the back of the metal basket.
take of the front lower panel of the washer and clean out the drain pump, if the screws came out they should be in there. to actually fix the problem you would have to take the entire tub assembly out and apart to get to the baskside of themetal basket.
but in general, its not that hard to fix if you are mechanical savvy. i fixed mine myself and im a 27 yo female who has never looked inside a washer before this experience.
Mar 26, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Bowl off track
Spring missing or skid plate out of place. if the basket has excess movement separate of the tub or agitator then the hub nut is loose or tub rusted out.
Jan 19, 2009 | Whirlpool Inglis IP4400 Washer
Tub is very loose bangs and wobbles
suspect basket support broke basket will need replaceing and possible rear tub section if bearing/seal damaged overloading not usually not the cause
Nov 27, 2008 | Kenmore 43052 Front Load Washer
Burning Smell - smoking coming out of it
I believe we tracked it down to the pressure switch mounted on the drain pump. The device had a strong electrical burn smell and is positioned where it could easily have smoked the basket. We're putting the washer back into service and if I have a recurrence I will post the information. BTW ... Replacement was simple and the part was $26 including shipping.
Jul 02, 2008 | Maytag Neptune MAH5500B Front Load Washer
Frigidaire Upright freezer Baskey
remove the basket sliders frome each side and install a couple of nylon washers between the slide and the side of the freezer on each side it will narrow the distance and the nylon washers will not rust
Mar 24, 2008 | Frigidaire 20 cu. ft. / 566 liter Upright...
Whirlpool LTG5243D Top Load Stacked Washer / Dryer Logo
402 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
