Question about liftmaster Chamberlain Garage Door Opener Transmitter 300MC
I have liftmaster garage door opener P/N 41A-5483-4. It worked normally. but all of sudden, when door closing, it reverses automatically at half way down, and garage door light bulb starts blicking 6 times. It worked normally randomly. Anybody knows why? By the way, one of door obstruction sensor light is orange, not green. Please help me on this
  • 927 Answers
Use the pull cord and disconnect the opener from the door. Operate the opener and let the carrier slide back away from the door. Is the carrier moving smoothly when disconnected? Next, lift the door by hand from the bottom to the top. Is it moving smoothly? If not, lubricate the axles of all the rollers on both sides of the door. Check the cable pulleys at the top sides of the door channel, lubricate them as well. Are all cables in all the pulleys, there are 4. After checking those things, there is a "up force" and "down force" adjustment on the opener, try increasing the "up force" by turning the adjustment in the direction of MORE force.
LiftMaster Garage Door Opener Frequently Asked Questions
Posted on Jan 03, 2011
Which wireless keypad works with a 41A 3627 LiftMaster Chamberlain Garage Door Opener?
The number you posted is the part number for the logic board. What is your model number?
Jun 12, 2012 | Sears Craftsman LiftMaster Chamberlain...
My Chamberlain Liftmaster garage door opener will not stay closed. It will start down and about half way it will stop and reverse itself. At times it will work properly. When the bounce happpens the light...
Anytime the main light flashes 10 times and the door reverses to the open position it is a door sensor problem. Make sure they are pointed at one another and the small light on each one is lit and not flickering. If you cannot get both lights to come on you have bad sensors.
Oct 14, 2010 | Sears Craftsman LiftMaster Chamberlain...
Garage door opening when hitting close button
If the main light is flashing 10 times when the door reverses to the open position it is a door sensor problem. Make sure they are pointed at one another and the small light on each one is lit. Tweak them a little if necessary.
Sep 21, 2009 | Sears Craftsman LiftMaster Chamberlain...
How to switch back to automatic after manually close the garage d
mikey-moore's advice helped me figure out what to do but it's not exactly what I had to do. Manually open the garage door all the way. Then hit the automatic button you normally would use to open and close your garage door. The bracket slides back and locks into place. Hit the automatic button again and the garage door should automatically close.
Jul 19, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door closes and then automatically opens half way
ADJUST THE DOWN LIMIT IT THINKS THERE IS AN OBSTRUCTION AND IS REVERSING LIKE IT SHOULD.
TURN THE LIMIT ABOUT 1/4 TURN AT A TIME.
HOPE THIS HELPS
Mar 15, 2009 | Sears Craftsman LiftMaster Chamberlain...
When I open the garage door it only opens half way and then stops
Gears may be wearing out. Take of panel with light bul (4 screws) and look inside. See white stuff? That is your nylon gear that is worn out. Rebuild or replace,
Jan 13, 2009 | Sears Craftsman LiftMaster Chamberlain...
Liftmaster garage door opener will only work at wall unit
check electric saftey beams. shovel blocking them. dirty. aligned (LED on in each unit)
Jan 12, 2009 | Sears Craftsman LiftMaster Chamberlain...
Liftmaster garage door opens and shuts but when it reaches the closed position on the floor of the garage, it automatically reverses and opens back up again.
is there something jamming it travel of the door?
or does the travel distance of the door need adjusting?
How many remotes do you have?
do their batteries need a changing?
even with the power disconnected you should be able to close the door,
do this and check from there,
any of the switchs sticking down?
If it persists then call some one to fix it,
They are normally bullettproof if installed properly and servicing and lubracating them seems to be a good idea too,
some buildings shrink and contract more than others
Yours seem to be normal movement of the building structure.
winter and summer situtation.
check the adjustments on the travel,
Let me know the outcome thanks .....
Aug 02, 2008 | Sears Craftsman LiftMaster Chamberlain...
liftmaster Chamberlain Garage Door Opener Transmitter 300MC Logo
351 people viewed this question
Top liftmaster Electrical Supplies Experts
Vince Heuser
tamska1102
Level 1 Expert
ray gallant
Are you a liftmaster Electrical Supply Expert? Answer questions, earn points and help others
