I have a foxconn n15235 motherboard that will not do anything. It shows blue screen F10 Setup, esc Boot Menu etc. can't access cmos to get to boot from cd rive. What do I need to do?
    Master:
  • 389 Answers
You can try to manually reset the CMOS by locating the CMOS jumper on the motherboard, unplugingg the computer and removing CMOS battery (small watch style battery). Move the jumper over to the empty and center pins. Re-install the cmos battery for a minute. Then remove the CMOS battery again and put the CMOS jumper back to it's original position. This should reset the bios. If you can get into the CMOS memory settings before the computer tries to boot to windows, you can use the reset option thru the BIOS. Get to the bios usually by hitting either the delete key or F2 key right after the computer starts up.
Sometimes, a computer will do this if a piece of hardware goes bad. So, you can try to remove all drives, except for the hard drive, from the motherboard and try starting the computer. If this works, you can connect one piece of hardware (CD drive, etc) at a time until you get the same problem to find the bad hardware.
There is a possbility that your motherboard is damaged, which is the reason for your symptoms. All you can do is use a process of ilimination to be certain.
Please let me know if this information is helpful and if I can assist you further. Please provide as much detail as possible so I can give you the best possible assistance. Also, I attempted to get some information on your particular board and was unable to find anything under N 15235. Is there any other identifying information on your board?
Brian
Posted on Jan 02, 2011
My HP Pavilion is stuck on the blue screen
While your system is still booting from start, keep hitting F11 to get past that point then proceed with the system recovery.
Nov 12, 2013 | HP Pavilion a6110n PC Desktop
Compaq Presario pops up a system boot menu everytime at startup.
This comes up mostly when it requires a BIOS save. Try that. If that does not help, sometimes setting the default settings and saving will help.
Dec 04, 2012 | Computers & Internet
Cant open bios
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS
after you make any changes in BIOS press Esc then press the F10 button save to cmos to restart
cmos is located in BIOS
hope this helps
Oct 01, 2011 | AOpen AX4C Max (91.8AU10.201) Motherboard
Would like to reset CMOS on inspiron 6000 - will not boot up to BIOS How do I reset CMOS
scroll to load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart this will reset your cmos after you make any changes in BIOS press Esc then press the F10 button save to cmos to restart
cmos is located in BIOS or
you will need to remove the cmos battery for 15-30 mns this will reset your cmos
im not sure where its located on this motherboard or whether its soldered in
hope this helps
Aug 08, 2011 | Dell Inspiron 6000 Motherboard - W9259
I can't boot from sata CDs with my motherboard asus p5rd1
http://majorgeeks.com/ASUS_Update_Utility__d4435.html
ASUS recovery
hope this helps you
Aug 03, 2011 | ASUS P5RD1-VM Motherboard
None of the keys work on hp logo screen F10, f11. f9. esc system won't boot from hard drive or cd
are you using a usb keyboard? A lot of systems require a ps/2 (purple round connector) keyboard to access the bios settings and anything on the startup screen unless you have set usb on boot in the bios settings. I would try connecting a ps/2 keyboard and see if it helps.
May 06, 2011 | HEWLETT-PACKARD Pavilion Desktop with AMD...
Need to get into bios settings on 8k3a motherboard
hope this helps
Feb 26, 2011 | EPoX computers10: Mainboard EP-8K3A...
I can't find the CMOS
hope this helps
Dec 28, 2010 | Dell (04U621) for Latitude D600, Inspiron...
I have a foxconn n15235 I get a blue screen F10 setup,esc Boot,F11 exc. Nothing happens How do I access the cmos. took battery out.
Press and hold that key during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to cd,press escape then press f10 to save to
cmos to restart (this is only a guide on how to enter BIOS)
it sounds like you have a faulty lead
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your motherboard to your hard drive make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
hope this helps
Dec 26, 2010 | Foxconn 6627MA-RS2H Motherboard
I have an HP Pavillion a1250n which has a MS-7184 V1.0 that will not boot. When turned on the HP Invent logo screen appears with thw following at the bottom:(Esc=Boot Menu)(F1=Setup)(F10=System...
It sounds as though you might have a problem with BIOS.
You should remove your motherboard battery (little round silver disc) and if you can find (or Google motherboard model#) the CMOS reset jumper, you can remove the battery for 30 seconds and put it back in and reset the CMOS, then see if it boots. If it doesn't, you might need to flash the BIOS, which is not recommended unless you know what you are doing.
Nov 16, 2009 | Intel Motherboard
Computers & Internet Logo
3,201 people viewed this question
David Payne
David Payne
