Question about Brother MFC-465CN InkJet Printer
Printer doesn't print letters dark enough..changed cartrideges alread
How do you increase darkness of print using ep470dn
You can go inprinter preferences, and select "Print in greyscale"
Mar 06, 2014 | Kyocera new ep 470dn monochrome laser...
Refilled 940 Cartridege At Costco
Everyone listen!!!
The HP 940 style cartridges have an inherent design issue that they collect air inside the black rubber pump. When enough air gets inside the black rubber cartridge pump they get soft/spongy - they must be firm (try pressing on it). The printer presses on the cartridge pump with a foot (gray plastic pad back inside the cartridge compartment) when it wants more ink to the printhead. If it presses and doesn\'t feel enough electrical resistance it thinks the cartridge is empty and errors "empty".
When a cartridge is truly empty, the black rubber pump will **** up inside itself, thus the foot does not feel any resistance. The only way to fix this is by occasionally remove the excess air from the cartridge pump. We recommend the AdaptiveInk Cartridge and Printhead Re-priming Kit. Yes, the Printheads also have an inherent design issue where they collect the air that is pushed from the cartridges. Excess air inside the printhead is what causes the majority of print quality issues you have when printing and this kit resolves this issue very well.
Feb 16, 2014 | HP Officejet Pro 8500 Wireless All-In-One...
My eltron ip2844 wont print dark enough. I went into setting and turned the burn darkness to 15, but still not dark? Help!!
This may be due to your thermal paper.
This printer doesn't deliver enough heat to your paper or you have a problem with the head pressure.
Press on the bloc while printing to see if it's this reason?
You may also have a mis-alignement of the thermal head.
Try also to change the print speed?
Aug 05, 2011 | Zebra Eltron LP 2543 Thermal Label Printer
Dymo QX50 printer, letter not printing dark enough and some striking. How can I fix the problem.
Try fresh batteries. Otherwise, please contact our help desk. The numbers are at dymo.com.
Jul 02, 2011 | Dymo LetraTag QX50 Thermal Label Printer
After repacing cartrideges --it constantly states to press enter to allign cartridegs--and the printer will not print
I have the same printer and it does the same thing... make sure you have paper in and click the ok button on the face of the printer. It will print out a pattern, put the pattern upside down facing back in the scanner and hit ok again. This will align your cartridges and allow you to print once again.
Oct 10, 2010 | HP PSC 2175 All-In-One InkJet Printer
Zebra Z4MPlus not printing dark enough
In your label software there should be a setting option for print darkness (I assume it adjusts the head temperature) In ours (bartender) you can get to it when you select 'print' and a window appears with a 'documents properties' button. Click on this and select options and a darkness bar appears which you can adjust. You may also need to slow the label print speed if the darkness adjustment is not enough. I suspect it isn't in the printers best interest to run the print head at maximum darkness/heat so a sensible balance of darkness and print speed is best.
Another, less likely, possibility is an incompatability between the label material or surface finish, and the ribbon type. We did have a problem once whem Homebase changed their price label design and we had to test a load of other ribbon types until we got one that did the job. A chat with the label or ribbon supplier is always usefull, they sent us several sample bits to test.
Sep 30, 2009 | Zebra Z4Mplus Label Printer
The black is not printing dark enough. It shows it
it is problem your printer black cartridge
you change it or
technicaly you drop your black cartridge in water withen two days after tow days you dry black cartridge and clean head printer maintai nence software then solve your problem
Jul 30, 2009 | HP DeskJet 5550 InkJet Printer
Printer not printing dark enough
go to the print settings select the dark scale
u can get print darker than the previous
May 27, 2009 | Samsung CLX 3160fn All-In-One Printer
My hp 1200 printer is not printing dark enough. this problem just started/ I can barely read the print. MY hp 1200 printer is not printing dark enough I installed a new toner cartage but it still does the...
If you have installed the toner cartridge correctly then it is a hardware problem called the Fuser and is the most common problem with printers...the fuser is a part of the printer which actually melts the toner onto the paper. The fuser has to get up to a high enough temperature to be able to melt the toner, if it is malfunctioning then it cannot give you a dark print. You may search google for Fuser information: Recommendation is change out fuser to repair problem. Pls rate this solution.
Apr 20, 2009 | HP LaserJet 1200 Printer
My Kyocera FS-3830N isn't printing certain letters
Updating the driver will solve your problem. Go the Kyocera web page and look under legacy printers in the download area
Jan 21, 2009 | Kyocera FS-3830N Laser Printer
Brother MFC-465CN InkJet Printer Logo
66 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
