Question about ATI Computers & Internet
I recently purchased a graphics card for my PC. The new graphics card required me to upgrade my power supply, which I did successfully. However, the graphics card isn't working. When it is installed, the monitor will not acknowledge that it is receiving a signal. I have tried both the original vga plug and the new plug in the video card, nothing. It just remains black then tells me that it's going to sleep. Help! What has gone wrong? I have tried disabling the onboard chips, still nothing. I have an HP PC with Intel, running Vista. The computer is a couple years old. The newly purchased graphics card is an ATI Radeon 5550 (recommended to me by an associate at Frys)
  • mistress_nig Jan 06, 2011
    The reinstall did not work. I do not have another computer to try the graphics card in, so I am having to deal with the manufacturer to determine if there is an issue with the card. This may take some time. I am worried that the card I purchased may not work with my computer. Is there reason this may be the case? Or could the power supply be the problem? Is it not powerful enough? I opened the computer while it was running, can could see the fan on the graphics card running, so I don't know.
    President:
  • 3,278 Answers
Hello.
Since you successfully disabled the onboard video card and the card is not working, remove the card, enable your old card and re-install the drivers for ATI Radeon. Disable your on board card again and install the new card.
Also, try the ATI card in another computer to see if the card is faulty.
Hope this helps.
Posted on Jan 03, 2011
  • NinaE Jan 06, 2011
    If you installed the Vista drivers for your ATI Radeon 5550, the card should work. Sorry that you don´t have another computer to test (most people don´t, but I thought i´d ask). Perhaps it is time to return the card.
Can I change my graphic card for another make, without changing my power supply
Totally. You just need to be mindful of the power demands of potential new card when choosing that card, selecting a graphics card with similar power rating. If it requires more power - then you may have to consider p.supply mods. If you are going to have to change one thing, then another to offset the first change (rob Peter to pay Paul), look at overall cost V. complete pc upgrade
May 06, 2015 | Sony VAIO PVC-RS502 (PCV-RS502) PC Desktop
DO I HAVE TO PLUG THE POWER FOR ASUS ENGTS450DI1GD5
Yes, newer, high end, high performance graphics cards are now requiring two power cords. So it might be time to upgrade your power supply if you don't have another rail to hook up to it. Some are 6 pin, some are 8 (total). I think it takes two (4 pin) power cords. I also recently got a better graphics card and had to get a new power supply.
Jan 09, 2012 | ASUS ENGTS450DI1GD5 Geforce GTS450...
I recently purchased a new wide screen monitor. As the onboard graphics of my 4600 don't support the 16:9 format I wanted to upgrade with a video card. As far as I can see from the specifications required...
Hi there,I understand your issue and would be glad to help you..
Soloution 1:Make sure that your Video card is firmly fitted into your AGP slot and that if you have a DVI slot(And if both your monitor and system handle DVI)try using that rather than DVI..
Soloution 2:It could be possible that your video card is not campatible with your current motherboard,out of intrest,What motherboard have you got?
good luck
Jan 10, 2011 | XFX GeForce 6200 Graphic Card
I am trying to play a pc game but it keeps saying my graphics card does not meet the minimum spefications how do i upgrade it?
graphic cards usually are made to a DirectX level the most up to date cards are at DirectX 11
check your game and see what direct X level it requires. it may well be that you can download and install direct x to the level of the game, if the graphic card you have will accept it.
if not the next steps could be expensive, if you are looking to buy an new pc soon anyway then i would not bother to buy a new graphic card, then better a new pc with a decent graphic card installed. if not you have to be aware of the upgrade.
firstly you have to have a power supply that can give power to the new graphics card, if you opt for PCI express these usually have a secondar power connector and your power supply will need to have the connector for this.
also *********** board will have to have a slot that accepts your new graphics card.
check with your computer store to ensure you get the right one. and that your pc will work with it ok.
I hope this was helpful.
Dec 12, 2010 | Computers & Internet
I just bought a new pc. It worked in the store. I also purchased a graphics card and power supply upgrade. I switched out the components exactly as they were. I now have no power. what might be cuasing...
either the graphic card is not compatible or the power supply that you changed is not fit for the motherboard....
check this
1 switch on the machine....if u can view / hear the fan on the power unit at the back of the PC running then the power unit is working.
2 do u get any msg or charecter on the screen when you power on the manchine ? if yes then the graphic card is the issue....
3 the cables inside the PC that you connected of the power supply are not properly joined in the MB
well at the last i will ask if the PC was new why did u make an upgrade....u could have bought a better PC with the extended features ??? well that's ur choice...!!!
ok then....
just put back the original power supply and original graphic card to c if it works now....
then let me know pls...
regards
Oct 15, 2010 | Computers & Internet
Hi im looking to upgrade my dell dimension 4700 graphics card. I currently am running a radeon x300. the minimum improvement im looking for is 512mb. also wondering if ill need to increase my psu as I...
Since you want to upgrade your video card to a much powerful one, you can check this out ATI Radeon HD 4670 HD4670 512MB DVI PCIe Video Card.
Doing the upgrade a power supply upgrade is also advisable since new video card like now requires a high power supply, upgrade the power supply to at least 500W and for a additional fan is already recommended to avoid any overheating problem.
Oct 02, 2010 | Dell Dimension 4700 PC Desktop
ATI Radeon 1650x Problem in Installation
This one is simple, the computer's stock powersupply which is probally at about 250 or 180 watts isnt generatiing enough power to the Vcard. Basically you need to purchase a higher watt power supply, you can get a decent 400+ watt for under 40 dollars almost anywhere.  Just a simple swap will do the trick.
Sep 22, 2009 | Computers & Internet
Upgrading motherboard
Dual graphic cards aka SLI require a SLI Power Supply. This is a good option if you want to start building a new system. Another option is just to get the new Nvidia 280 graphic card. Check out Tomshardware.com for a killer article on the latest graphic cards.
Jul 13, 2008 | Medion M3 Composer 5100 PC Desktop
3D Video Card
what would the price range of the video card would you be looking for?
depending on the price range is depending on the card i would suggest.
Apr 07, 2008 | Computers & Internet
UPGRADE GRAPHICS CARD
Hey,
From the looks of your system, Its a pentium D 915 CPU, with integrated graphics.
From the spec sheets, you should be able to upgrade to even an 8800 series, although that would require you to purchase a higher wattage power supply.
My recommendation is:
if you want graphics grunt for later model games, (i.e shooters like CoD4) the card you need (without needing a new PSU) would be the 8600gt. This is an excellent card and does not require external power.
If you want a cost-effective option, go with the 8500gt or an ati (amd) something equivalent. They arent the fastest cards out, but they will do a better job than the integrated graphics.
Hope that helps,
Sincerely,
mister_apocalypse, aka <<CKS>>DRpyro
and
maxicube, aka 'monsieur'
Tech Support A team
Feb 07, 2008 | Computers & Internet
Computers & Internet Logo
61 people viewed this question
Top ATI Computers & Internet Experts
David
David
Computer Links
Alun Cox
Are you an ATI Computer and Internet Expert? Answer questions, earn points and help others
