Question about RCA RP5430 Clock Radio
How do you set the time on the RCA RP5430A clock radio?
SOURCE: RCA RP5420 clock radio
The Point - Thank you it worked for me!
Posted on Mar 06, 2008
Bob, My auto-set worked fine. I'd suggest setting the time manually (by sliding the top-rear slider all the way to the right and using the '<<rev' and 'fwd>>' buttons) if you are still having problems.
Posted on Mar 28, 2008
SOURCE: Changing time on RCA CD clock radio
UNPLUG!!! Wait 15 seconds. Plug in again, CLOCK will flash 12am.
Press "set" button ONCE.
Press Double Back Arrows |<< to go backward from Midnight
or
Press Double Forward Arrows |>> to go forward from Midnight
(Either press-hold the Double Arrows for quick minute-scroll or repeat-press Double Arrow for a slower minute-by-minute change.)
Posted on Nov 02, 2008
SOURCE: need operating instructions for RCA clock radio Mod. 5430
The instruction manual will not help you, because it doesn't address this problem head on.  You're having this problem because the time changed, and the clock has an automatic setting.    As long as the batteries are in the clock and it's plugged up, it automatically computes the time. I just discovered the solution.  Unplug the clock, take out the batteries and WAIT about an hour.  Plug it back up, and the time will flash, allowing you to change the time.  You do this with the button on the top back which says wake up 1 and wake up 2.  Push that button all the way to the right to the setting that looks like a little clock, then press the forward button on the top of the clock to set the correct time.  Then put your batteries in and you're good to go!  (til the time changes again:)  Good luck!
Posted on Nov 05, 2008
Acuraking
  • 42 Answers
SOURCE: How to change the time on clock radio
I'm not 100% sure if this is right or not, but i used to have one similar and the way to reset it was:
  1. Press the SET button.
  2. After the time blinks, press the REV or FWD button to adjust the time. (Press and hold the REV or FWD button to fast reverse or fast forward time.)
  3. To save settings press the SET button.
  4. Once you have the clock set and have press the SET button, the time should be done blinking.
Give this a try and hopefully it works, good luck
Posted on Nov 10, 2008
How do I set the time on a RCA USB Charging Clock Radio RC142?
Setting clock manually
1. Press and hold Set Time to enter the clock setting mode.
2. Press HOUR+ and MINUTE+ to adjust the time.
• Press and hold to adjust the time value quickly.
• The digits on the display ? ash in clock setting mode.
• The clock is in 12 hour format. The AM or PM indicator will illuminate to indicate the current time setting.
3. Press Set Time again to save the time setting
RCA RC142 User Manual General Controls
Mar 18, 2016 | RCA RC142 AM/FM USB Charging Clock Radio
How do I change the time one hour ahead for an RP5430A model clock radio?
Slide the Wake 1/Wake2/Clock switch to the Clock position. Then press the forward button to advance the clock by the needed amount of time. Then slide the switch back to the side with the key icon.
If you set the DST switch to ON, you can move the time zone switch to one time zone further east for a few weeks until the DST change in the program takes effect. Then move the time zone switch back to your current time zone. (Repeat this in the fall to correct for the later change in DST again). The exact length of time between when DST starts and ends versus when the clock will change the program will depend on when the clock was manufactured. Clocks built after July 2006 should have the correct DST programs. Clocks from earlier have a much shorter period of DST (April through Oct).
I hope this helps.
Mar 13, 2011 | RCA RP5430 Clock Radio
How do i set the time on this product
Press the Clock Set button on the top of the clock radio. Press either the forward or reverse (skip) buttons to change the time. Press and hold the button to get the time to change faster. Make sure the AM/PM indicator is correct for the current time. Then press Clock Set or wait 5 seconds without pressing a key to exit the time set mode.
You set the alarm time similarly after pressing Wake Time. Make sure the Wake Mode is set to alarm, radio or CD.
The manual for the clock is available at the RCA site: http://www.rcaaudiovideo.com/search/?km=RP5605 .
I hope this helps.
Feb 05, 2011 | RCA RP5605 Clock Radio
I have RCA Clock Radio #RP3710A, How do you set the time without unplugging the clock/radio?
Press "set" one time to set alarm one, two times to set alarm 2, and 3 times to set the time using the "tune/time" buttons for forward and backward. If you wait too long to push one of them or stop too long, it will time out and go back to the last setting.
Mar 14, 2010 | RCA RP3710 Clock Radio
I just inherited an RP5430A. I don't know how to
You can download the user manual by clicking this link
  • You'll require Adobe PDF Reader installed on your PC to view this manual. If it is not already installed on your PC, download it free from: http://get.adobe.com/reader/
Hope this solves your problem. Thanks for using FixYa
Feb 18, 2010 | RCA RP5430 Clock Radio
Set the time? ge model #75350.
Download the manual here:
http://www.devicemanuals.com/guide/CD%20Player/RCA/RCA-75350-User-Manual-==TVRJMk1UZ3k=.html
Or open the battery compartment on the right side and press the clock button, >> or << to set time, and press clock button again to save.
Mar 30, 2009 | GE Spacemaker (74290) Clock Radio
Need operating instructions for RCA clock radio Mod. 5430
Oct 27, 2008 | RCA RP5430 Clock Radio
Setting the time on my clock on radio Model # RP3755B
Well, I have an RCA clock radio/CD player and just figured it out. Press the "Time" button and hold it down while pressing the CD "Forward" button. Hope it works for you! Ron
Jul 03, 2008 | RCA Alarm Clock w/CD Player, AM/FM Stereo...
Help
Possible solution for some of the problems listed: Turn the clock upside down so that the label is readable in the upper left area. On the right side you will find a compartment which may have two "AA" batteries installed. These back up the setting when the clock is unplugged.
To reset the clock, you will have to BOTH remove the batteries AND unplug the AC power cord. Also, make sure the batteries are not dead.
Finally, although I cannot confirm this, there is an opening directly under the label (still looking at the bottom of the clock) which appears to be a "Reset" switch. A pointed object such as a ballpoint pen or toothpick will be needed to press this recessed button. Hope this helps. Mine is working just fine.
Apr 06, 2008 | RCA RP5430 Clock Radio
or
Sep 20, 2007 | RCA Radio Alarm Clock
RCA RP5430 Clock Radio Logo
109 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
